Starting from Scratch
Sun Jun 12, 2022 4:21 am
boisy offline
I just downloaded this plug-in. My desire is to plot temperatures for some data I'm acquiring.
I've turned on the SQL Logger within Indigo, but this plug-in appears to want to source data from CSV files. Is there a way to source the data from the SQLite database that Indigo is writing to?
Sun Jun 12, 2022 4:56 am
Re: Starting from Scratch
Unfortunately, no. There is a built in device type within the plugin called a "CSV Engine" which is used to create CSV data sources directly from Indigo objects. Of course, you can also create your own CSV data directly if you like. So for example,
  • I use the CSV Engine to plot indoor and outdoor temperatures every 15 minutes and retain the data for about 3 days. I'm not necessarily interested in plotting each marginal temperature change.
  • I use a separate trigger/script combo to log each time my sump pump fires (obviously, time-based logging would be meaningless).
