ImportError: No module named queue
Sun Jul 25, 2021 10:37 pm
Bleasel offline
Hi Dave
I am getting the following error:
Starting plugin "Matplotlib 0.9.50" (pid 96854)
Matplotlib Error Error in plugin execution InitializeMain:
File "plugin.py", line 72, in <module>
Stopping plugin "Matplotlib 0.9.50" (pid 96854)
Stopped plugin "Matplotlib 0.9.50"
I have deleted the plugin and preference file, and reinstalled, and the error still occurs.
Marcus
Indigo 2021.1.0
Mon Jul 26, 2021 4:25 am
Re: ImportError: No module named queue
Okay, that's a bit of a strange one. The Python queue library is a standard library and should be included with every Python install. Please try these steps to see if it solves the issue:
  1. Restart the Indigo server computer (and thus the Indigo Server). Do you still get the error?
  2. From within Indigo, select the Plugins menu and then Open Scripting Shell. At the prompt, enter `import queue` (without the single quotes). Do you still get the same error? Enter `exit()` and them `CMD-Q` to close the shell.
  3. Start the Terminal app and enter `python'. Do you get a Python 2.7 instance? If yes, enter `import queue`. Do you get the same error? Enter `exit() and then `CMD-Q` to close the shell.
Let me know how these steps go and then we'll work from there.
Mon Jul 26, 2021 7:34 pm
Bleasel offline
YES
import queue
File "<console>", line 1, in <module>
Python 2.7.6 (v2.7.6:3a1db0d2747e, Nov 10 2013, 00:42:54)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import queue
File "<stdin>", line 1, in <module>
Mon Jul 26, 2021 7:58 pm
Bleasel offline
I have found this online
The Queue module has been renamed to queue in Python 3.
if I type "import Queue" I do not get the errors seen above
Python 2.7.16 (default, Mar 25 2021, 18:52:10)
[GCC 4.2.1 Compatible Apple LLVM 10.0.1 (clang-1001.0.37.14)]
Connected to Indigo Server v2021.1.0, api v2.5 (localhost:1176)
>>> import Queue
Mon Jul 26, 2021 8:43 pm
Are you by any chance running on a case-sensitive file system?
Mon Jul 26, 2021 8:45 pm
In Disk Utility, what does it show?
Screen Shot 2021-07-26 at 10.45.02 PM.png (44.86 KiB) Viewed 5127 times
Mon Jul 26, 2021 9:20 pm
Bleasel offline
APFS Volume . APFS
My quick test to create the same folder with same name but in different cases, shows that the file system being used is not case sensitive
Mon Jul 26, 2021 10:08 pm
You appear to have a Python version issue:
This is a very old Python and shouldn't be on more recent macOS versions that are completely patched with Apple updates.
I believe that in 2.7.16, the Queue module has at least been aliased to queue since I can import queue on all 2.7.16 instances I have on my various devices. It's possible (maybe likely) that they did that in the later dot releases of Python 2 to help with Python 3 migration, and that earlier versions of Python 2 may not have done it. I further believe that if your OS has all it's security updates, that you likely have 2.7.16 installed unless you're on a very old OS. High Sierra and newer, for instance, has it.
Dave, if you want to support older Python versions, I'd recommend:
    import queue
except:
    import Queue as queue
I believe that most of the module features are the same so hopefully that'll work.
Tue Jul 27, 2021 4:57 am
Thanks Jay. I came up with the same solution and will push it out as a dot release. However, I want to also add a note of caution about whether this change will allow the Matplotlib plugin to run error free on Python 2.7.6. The Matplotlib library is version-sensitive and is not stable across Python versions and Matplotlib versions. For example, recent releases of macOS have irretrievably broken the Polar Chart device (which I'm hoping will be fixed in the eventual migration to Python 3).
So, I will make a change to silence the `module not found error`, but can't guarantee that the plugin will work on Python 2.7.6.
Tue Jul 27, 2021 4:56 pm
Bleasel offline
I am running mac 10.14.6 (that is the latest version that my Mac Pro (Mid 2012) with upgraded Graphics card will run.)
Tue Jul 27, 2021 10:15 pm
Bleasel offline
New version 0.9.51 seems to have removed the error
Many Thanks
MODERATOR EDIT: Corrects version number.
Wed Jul 28, 2021 5:04 am
Terrific. Thanks for reporting back.
Wed Jul 28, 2021 10:27 am
Unfortunately, the basic macOS version isn't enough since Apple doesn't increment the dot releases for each security update, and that's likely where Python gets updated. To find out the more specific macOS release, open the System Information app, select the Software item in the outline view on the left, and look for this line:
System Version:   macOS 10.14.6 (18G9216)
That last part is the build number. The one above has all the Mojave security updates installed and it has Python 2.7.16. If you don't have all the security updates installed, you should if for no other reason that to make sure your Mac is as secure as possible.
Wed Jul 28, 2021 7:15 pm
Bleasel offline
I seem to have the same build number, but an earlier version of Python then.
Kernel Version: Darwin 18.7.0
Wed Jul 28, 2021 8:04 pm
Bleasel offline
Latest security update
System Version: macOS 10.14.6 (18G9323)
But no change in python version
Last login: Thu Jul 29 11:50:20 on console
XXXXXXXXXXXXX:~ X$ python
