- Posted on
Sat Aug 29, 2020 12:28 pm
DaveL17
offline
There's nothing built into the plugin to do that; the onOffState state is toggled when the device's communication status changes (i.e., when you tick/untick Comm Enabled). What you can do, however, is create two Indigo schedules to set the communication state to what you need. Under Actions, use Server Actions --> Enable/Disable/Reload Actions --> Enable (or Disable) Device.
This should do what you need since the CSV device should only update if it's enabled.
