Are Area charts supported
PostPosted: Mon May 20, 2019 7:56 am
by norcoscia
Two questions Dave, first -- are area charts supported (see below) and second, is there a way to chart values but only the values that are greater than 0?
Norm
Re: Are Area charts supported
PostPosted: Mon May 20, 2019 10:23 am
by DaveL17
Hi Norm - Area charts are not supported. I'll add them to the list for future updates. You can do something similar, though. For example, for a 2 clamp Aeotec Energy Monitor, you could plot clamp 1 as the first line and total energy usage as the second line.
There's no way to do this other than to set the minimum Y axis limit at zero. The data will still be plotted, but you won't be able to see it.
PostPosted: Mon May 20, 2019 10:28 am
by norcoscia
so If I use lines and fill it will just be random which one is on top or will they be in some order depending on the line number?
PostPosted: Mon May 20, 2019 11:02 am
by DaveL17
They will be plotted in order of the line number.
PostPosted: Mon May 20, 2019 11:51 am
by norcoscia
Thx!!!
PostPosted: Thu May 23, 2019 6:02 am
by DaveL17
Still a ways to go, but I've started work on the Area Chart type.
PostPosted: Thu May 23, 2019 6:51 am
by norcoscia
Looks cool - are you going to do stacked or added with the smaller amounts amounts forward ?
I may not have the right words but if (in my mind) they are stacked and one line is 75 and the other is 50 - you would have the top of the chart at 125 with the 50 line inside. If added-- the top would be at 75 with the 50 in front. And the positions (front to back) would be determined using a function of average values over the whole line.
PostPosted: Thu May 23, 2019 2:00 pm
by DaveL17
Hi Norm - using Matplotlib parlance it's called a Stacked Plot. That is if you have a 50 and a 75, then the second is stacked on top of the first and the top would be at 125.
For example, for a two clamp energy monitor, line 1 would be clamp 1, line 2 would be clamp 2, and the top would be total energy.
Dave
PostPosted: Thu May 23, 2019 2:03 pm
by norcoscia
OK, thanks Dave!!!
