Battery Chart - Text Colour
Tue Mar 19, 2019 11:56 am
Hi Dave,
As always, thanks for all your effort on this plugin. :D
It would be useful to able to specify the text colour when selecting Show Battery Level. At the moment if you select a light green colour for the Healthy colour then the white text gets lost.
Also, I can't remember whether I have suggested this before, but it would be useful to set the whole bar to red if the battery is zero - so it stands out.
I am running the latest Github release = v0.7.33 :)
Tue Mar 19, 2019 12:20 pm
Re: Battery Chart - Text Colour
autolog wrote:
Hi Dave,
Hi Jon - thanks for the nice words. I have a new build up on GitHub (not an official release) that I'm currently testing for release. I'll add your suggestions to the list for the next one. A couple notes:
Adding a separate text color control gets away from a core design principle that I have with the plugin which is to adjust most chart colors with a single change within the plugin config dialog. That said, there are unique color controls for lines, bars, etc. What about a "override text color" control for battery health devices? Another option here would be, instead of changing the text color, have the numeric value be an annotation (on or off) with a background like other chart annotation settings. (This would be my preference, actually.)
I will try to come up with some way to highlight batteries at zero percent. Great suggestion.
Tue Mar 19, 2019 3:10 pm
norcoscia offline
How about this :-)
_______
Norm
Tue Mar 19, 2019 3:54 pm
That’s awesome. I know you’re at least half kidding, but I haven’t used image files in plots yet. There’s issues with scaling—both DPI and bar size within the chart.
Right now, in my mind at least, I’m leaning towards a “patch” (term of art in Matplotlib.)
Tue Mar 19, 2019 3:58 pm
norcoscia offline
Would using SVG file(s) - (assuming that is possible - I don't know) solve the scaling problems?
Yes, I was kidding, for some reason when I read the post that graphic came to my mind :-)
_______
Norm
Tue Mar 19, 2019 4:03 pm
It's one of those things that's probably technically possible, but I suspect the amount of effort to make it work well would be non-trivial.
