Re: Looking for Beta Testers
Posted: Sun Feb 10, 2019 1:45 pm
DaveL17 wrote:
It sounds like there are three things going on.
1. Fill when fill turned off.
Yup correct
DaveL17 wrote:2. Too many ticks error - this may be related to all data being zero.
No
All data valid and created by latest version of MapPlotLib
Even with one entry ten minutes a go it is reporting data from 1968 - this bug is deep....
This bug is showing up in logs - will attach compressed log
DaveL17 wrote:3. rgba error with color "Invalid rgb arg".
This was the problem with data = 0.0
No longer get this issue as I turned on the device - it created some data - but may well return once threes days of 0.0 are all thats left in csv file
DaveL17 wrote:I'll see what I can do to recreate the errors you're seeing with the data you've provided. If you can share the plugin private log file it would be super helpful.
- Code: Select all
/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/plugin.log
I really appreciate the help!
