2019-03-02 20:18:14.090 INFO Plugin.processLogQueue [Chart Motion - Downstairs - Bar] chart updated successfully.
2019-03-02 20:25:03.413 DEBUG Plugin.debugLog: Initializing DLFramework...
2019-03-02 20:25:03.414 DEBUG Plugin.pluginEnvironmentLogger DLFramework pluginEnvironment method called.
2019-03-02 20:25:03.414 INFO Plugin.pluginEnvironmentLogger
2019-03-02 20:25:03.414 INFO Plugin.pluginEnvironmentLogger ================================================ Initializing New Plugin Session =================================================
2019-03-02 20:25:03.414 INFO Plugin.pluginEnvironmentLogger Plugin name: Matplotlib
2019-03-02 20:25:03.414 INFO Plugin.pluginEnvironmentLogger Plugin version: 0.7.28
2019-03-02 20:25:03.414 INFO Plugin.pluginEnvironmentLogger Plugin ID: com.fogbert.indigoplugin.matplotlib
2019-03-02 20:25:03.414 INFO Plugin.pluginEnvironmentLogger Indigo version: 7.2.0
2019-03-02 20:25:03.415 INFO Plugin.pluginEnvironmentLogger Python version: 2.7.10 (default, Feb 7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
2019-03-02 20:25:03.418 INFO Plugin.pluginEnvironmentLogger Mac OS Version: 10.12.6
2019-03-02 20:25:03.419 INFO Plugin.pluginEnvironmentLogger Process ID: 67310
2019-03-02 20:25:03.419 INFO Plugin.pluginEnvironmentLogger ==================================================================================================================================
2019-03-02 20:25:03.419 INFO Plugin.pluginEnvironmentLogger ======================================================= Matplotlib Environment ========================================================
2019-03-02 20:25:03.419 INFO Plugin.pluginEnvironmentLogger Matplotlib version: 1.3.1
2019-03-02 20:25:03.419 INFO Plugin.pluginEnvironmentLogger Numpy version: 1.8.0rc1
2019-03-02 20:25:03.420 INFO Plugin.pluginEnvironmentLogger Matplotlib RC Path: /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/matplotlibrc
2019-03-02 20:25:03.421 INFO Plugin.pluginEnvironmentLogger Matplotlib Plugin log location: /Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib
2019-03-02 20:25:03.421 THREADDEBUG Plugin.pluginEnvironmentLogger Matplotlib base rcParams: {'figure.subplot.right': 0.9, 'animation.frame_format': 'png', 'mathtext.cal': 'cursive', 'font.fantasy': ['Comic Sans MS', 'Chicago', 'Charcoal', 'ImpactWestern', 'fantasy'], 'grid.alpha': 1.0, 'xtick.minor.pad': 4, 'tk.pythoninspect': False, 'pgf.texsystem': 'xelatex', 'svg.fonttype': 'path', 'font.cursive': ['Apple Chancery', 'Textile', 'Zapf Chancery', 'Sand', 'cursive'], 'figure.subplot.hspace': 0.2, 'keymap.fullscreen': ('f', 'ctrl+f'), 'mathtext.bf': 'serif:bold', 'savefig.extension': 'png', 'xtick.direction': 'in', 'axes.facecolor': 'w', 'mathtext.fontset': 'cm', 'animation.mencoder_path': 'mencoder', 'keymap.pan': 'p', 'animation.writer': 'ffmpeg', 'path.snap': True, 'svg.image_inline': True, 'animation.bitrate': -1, 'lines.markersize': 6, 'figure.dpi': 80, 'text.usetex': False, 'image.origin': 'upper', 'patch.edgecolor': 'k', 'legend.labelspacing': 0.5, 'animation.convert_path': 'convert', 'examples.directory': '', 'text.antialiased': True, 'animation.ffmpeg_args': '', 'lines.solid_joinstyle': 'round', 'savefig.bbox': None, 'mathtext.rm': 'serif', 'axes.formatter.limits': [-7, 7], 'xtick.minor.size': 2, 'font.serif': ['Bitstream Vera Serif', 'DejaVu Serif', 'New Century Schoolbook', 'Century Schoolbook L', 'Utopia', 'ITC Bookman', 'Bookman', 'Nimbus Roman No9 L', 'Times New Roman', 'Times', 'Palatino', 'Charter', 'serif'], 'image.cmap': 'jet', 'lines.marker': 'None', 'tk.window_focus': False, 'axes.formatter.use_mathtext': False, 'ytick.major.width': 0.5, 'path.effects': [], 'figure.subplot.wspace': 0.2, 'backend.qt4': 'PyQt4', 'webagg.port_retries': 50, 'axes.xmargin': 0, 'savefig.facecolor': 'w', 'pgf.preamble': [''], 'ytick.minor.size': 2, 'savefig.pad_inches': 0.1, 'font.stretch': 'normal', 'text.dvipnghack': None, 'path.sketch': None, 'savefig.directory': '~', 'figure.subplot.bottom': 0.1, 'ytick.color': 'k', 'image.aspect': 'equal', 'lines.linestyle': '-', 'axes.ymargin': 0, 'xtick.color': 'k', 'savefig.jpeg_quality': 95, 'savefig.frameon': True, 'xtick.major.pad': 10.0, 'patch.facecolor': 'b', 'figure.figsize': [8.0, 6.0], 'axes.linewidth': 1.0, 'backend': 'agg', 'legend.handletextpad': 0.8, 'mathtext.fallback_to_cm': True, 'lines.linewidth': 1.0, 'savefig.dpi': 100, 'font.family': 'sans-serif', 'svg.image_noscale': False, 'docstring.hardcopy': False, 'font.size': 12, 'ps.fonttype': 3, 'path.simplify': True, 'keymap.all_axes': 'a', 'keymap.quit': ('ctrl+w', 'cmd+w'), 'polaraxes.grid': True, 'toolbar': 'toolbar2', 'savefig.edgecolor': 'w', 'animation.mencoder_args': '', 'legend.frameon': True, 'figure.autolayout': False, 'figure.facecolor': '0.75', 'figure.max_open_warning': 20, 'animation.convert_args': '', 'ps.usedistiller': False, 'legend.isaxes': True, 'animation.ffmpeg_path': 'ffmpeg', 'figure.edgecolor': 'w', 'mathtext.tt': 'monospace', 'contour.negative_linestyle': 'dashed', 'savefig.format': 'png', 'axes.formatter.use_locale': False, 'lines.markeredgewidth': 0.5, 'legend.fontsize': 'large', 'keymap.home': ['h', 'r', 'home'], 'axes3d.grid': True, 'legend.scatterpoints': 3, 'axes.edgecolor': 'k', 'lines.solid_capstyle': 'projecting', 'ytick.minor.width': 0.5, 'axes.titlesize': 'large', 'image.interpolation': 'bilinear', 'keymap.zoom': 'o', 'xtick.major.size': 4, 'keymap.xscale': ['k', 'L'], 'animation.avconv_args': '', 'legend.shadow': False, 'mathtext.it': 'serif:italic', 'keymap.save': ('s', 'ctrl+s'), 'font.variant': 'normal', 'text.hinting': True, 'xtick.labelsize': 'medium', 'axes.unicode_minus': True, 'figure.frameon': True, 'text.hinting_factor': 8, 'ps.distiller.res': 6000, 'pdf.compression': 6, 'pdf.fonttype': 3, 'ytick.minor.pad': 4, 'pdf.inheritcolor': False, 'axes.color_cycle': ['b', 'g', 'r', 'c', 'm', 'y', 'k'], 'lines.dash_capstyle': 'butt', 'ytick.direction': 'in', 'figure.subplot.top': 0.9, 'pdf.use14corefonts': False, 'legend.markerscale': 1.0, 'patch.antialiased': True, 'backend_fallback': True, 'font.style': 'normal', 'keymap.forward': ['right', 'v'], 'grid.linewidth': 0.5, 'legend.fancybox': False, 'grid.linestyle': ':', 'axes.labelcolor': 'k', 'text.color': 'k', 'xtick.minor.width': 0.5, 'ps.useafm': False, 'legend.loc': 'upper right', 'interactive': False, 'lines.antialiased': True, 'webagg.port': 8988, 'savefig.orientation': 'portrait', 'axes.axisbelow': False, 'ytick.major.size': 4, 'axes.grid': False, 'pgf.debug': False, 'plugins.directory': '.matplotlib_plugins', 'grid.color': 'k', 'ytick.major.pad': 5.0, 'timezone': 'UTC', 'pgf.rcfonts': True, 'legend.borderpad': 0.4, 'lines.dash_joinstyle': 'round', 'axes.labelweight': 'normal', 'datapath': '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/mpl-data', 'text.latex.unicode': False, 'legend.handleheight': 0.7, 'image.lut': 256, 'animation.avconv_path': 'avconv', 'animation.codec': 'mpeg4', 'text.latex.preamble': [''], 'legend.numpoints': 2, 'legend.handlelength': 2.0, 'keymap.grid': 'g', 'font.sans-serif': ['Bitstream Vera Sans', 'DejaVu Sans', 'Lucida Grande', 'Verdana', 'Geneva', 'Lucid', 'Arial', 'Helvetica', 'Avant Garde', 'sans-serif'], 'verbose.fileo': 'sys.stdout', 'xtick.major.width': 0.5, 'axes.labelsize': 'medium', 'patch.linewidth': 1.0, 'legend.borderaxespad': 0.5, 'mathtext.sf': 'sans\\-serif', 'axes.hold': True, 'verbose.level': 'silent', 'mathtext.default': 'it', 'figure.subplot.left': 0.125, 'legend.columnspacing': 2.0, 'webagg.open_in_browser': True, 'text.latex.preview': False, 'font.weight': 'normal', 'lines.color': 'b', 'keymap.yscale': 'l', 'image.resample': False, 'font.monospace': ['Bitstream Vera Sans Mono', 'DejaVu Sans Mono', 'Andale Mono', 'Nimbus Mono L', 'Courier New', 'Courier', 'Fixed', 'Terminal', 'monospace'], 'agg.path.chunksize': 0, 'path.simplify_threshold': 0.1111111111111111, 'ytick.labelsize': 'medium', 'ps.papersize': 'letter', 'keymap.back': ['left', 'c', 'backspace'], 'svg.embed_char_paths': True}
2019-03-02 20:25:03.421 THREADDEBUG Plugin.pluginEnvironmentLogger Initial Plugin Prefs: {u'snappyConfigMenus': False, u'sqChartSize': 100, u'spineColorOther': u'#888888', u'faceColor': u'#000000', u'rectChartLabel': u'', u'infoLabel1': u'', u'fontColorOther': u'#FFFFFF', u'space7': u'', u'dataPath': u'/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/', u'gridColorOther': u'#888888', u'showDebugLevel': 50, u'chartPropsSeparator': u'', u'lineWeight': u'1.0', u'promoteCustomLineSegments': True, u'tickColor': u'#888888', u'fontColor': u'#FFFFFF', u'annotationColorOther': u'#FFFFFF', u'enableCustomLineSegments': True, u'rectChartWideLabel': u'', u'tickSize': 4, u'updaterLastCheck': 1549813376.0, u'rectChartWideSeparator': u'', u'verboseLogging': False, u'updaterEmail': u'indigo@mdhome.net', u'debugHeaderSpace': u'', u'backgroundColorOther': u'#000000', u'rectChartWideWidth': 1000, u'space07': u'', u'mainFontSize': u'10', u'space05': u'', u'enableCustomColors': False, u'space06': u'', u'gridColor': u'#888888', u'rectChartSeparator': u'', u'backgroundColor': u'#000000', u'notificationsLabel': u'', u'faceColorOther': u'#000000', u'sqChartSeparator': u'', u'space00': u'', u'infoLabel0': u'', u'chartResolution': 100, u'rectChartWideHeight': 250, u'dpiWarningFlag': True, u'tickColorOther': u'#888888', u'updaterEmailsEnabled': True, u'forceOriginLines': True, u'verboseLoggingLabel': u'', u'separator0': u'', u'space0': u'', u'showDebugSettings': False, u'space01': u'', u'fontColorAnnotation': u'#FFFFFF', u'refreshInterval': 900, u'emailLabel': u'', u'legendFontSize': 6, u'tickFontSize': u'8', u'gridStyle': u':', u'debugLabel': u'', u'chartPropsLabel': u'', u'showNotificationSettings': False, u'oldDebugLevel': u'20', u'chartPath': u'/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/images/controls/static/', u'separator02': u'', u'separator03': u'', u'separator00': u'', u'separator01': u'', u'fontMain': u'Arial', u'notificationsHeaderSpace': u'', u'rectChartHeight': 250, u'sqChartLabel': u'', u'logEachChartCompleted': True, u'rectChartWidth': 600, u'spineColor': u'#888888', u'saveSettingsLabel': u'', u'updaterLastVersionEmailed': u'0.7.09'}
2019-03-02 20:25:03.421 INFO Plugin.pluginEnvironmentLogger =======================================================================================================================================
2019-03-02 20:25:24.404 INFO Plugin.csv_refresh_process [Main CSV Engine] CSV data updated successfully.
2019-03-02 20:25:24.466 INFO Plugin.csv_refresh_process [Mini CSV Engine] CSV data updated successfully.
2019-03-02 20:25:24.780 INFO Plugin.csv_refresh_process [Motion CSV Engine] CSV data updated successfully.
2019-03-02 20:25:25.450 INFO Plugin.processLogQueue [Chart - Alt Temperature] chart updated successfully.
2019-03-02 20:25:25.839 INFO Plugin.processLogQueue [Chart - Broadband Speed Available] chart updated successfully.
2019-03-02 20:25:26.286 INFO Plugin.processLogQueue [Chart - Daily Power Usage] chart updated successfully.
2019-03-02 20:25:26.714 INFO Plugin.processLogQueue [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-02 20:25:26.942 INFO Plugin.processLogQueue [Chart - Downstairs Radiators - Batteries] chart updated successfully.
2019-03-02 20:25:27.534 INFO Plugin.processLogQueue [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-02 20:25:28.084 INFO Plugin.processLogQueue [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-02 20:25:28.324 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:25:28.325 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-02 20:25:28.325 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-02 20:25:28.325 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-02 20:25:28.325 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-02 20:25:28.325 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:25:28.325 WARNING Plugin.plot_custom_line_segments There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-02 20:25:28.528 INFO Plugin.processLogQueue [Chart - Fridge Power and Temperature] chart updated successfully.
2019-03-02 20:25:28.901 INFO Plugin.processLogQueue [Chart - Fridge Temperature] chart updated successfully.
2019-03-02 20:25:29.264 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Power Usage] chart updated successfully.
2019-03-02 20:25:29.706 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Temperature] chart updated successfully.
2019-03-02 20:25:29.968 INFO Plugin.processLogQueue [Chart - Heating Demand History] chart updated successfully.
2019-03-02 20:25:30.385 INFO Plugin.processLogQueue [Chart - Heating Hot Water] chart updated successfully.
2019-03-02 20:25:30.812 INFO Plugin.processLogQueue [Chart - Heating Hot Water Tank] chart updated successfully.
2019-03-02 20:25:31.121 INFO Plugin.processLogQueue [Chart - Household Power Usage] chart updated successfully.
2019-03-02 20:25:31.755 INFO Plugin.processLogQueue [Chart - Key Temperatures] chart updated successfully.
2019-03-02 20:25:32.022 INFO Plugin.processLogQueue [Chart - Power Tool Charger] chart updated successfully.
2019-03-02 20:25:32.401 INFO Plugin.processLogQueue [Chart - Radiator - Bathroom] chart updated successfully.
2019-03-02 20:25:32.755 INFO Plugin.processLogQueue [Chart - Radiator - Guest Bedroom] chart updated successfully.
2019-03-02 20:25:33.123 INFO Plugin.processLogQueue [Chart - Radiator - Guest Ensuite] chart updated successfully.
2019-03-02 20:25:33.595 INFO Plugin.processLogQueue [Chart - Radiator - Kitchen] chart updated successfully.
2019-03-02 20:25:34.084 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Back] chart updated successfully.
2019-03-02 20:25:34.549 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Front] chart updated successfully.
2019-03-02 20:25:35.022 INFO Plugin.processLogQueue [Chart - Radiator - Master Bed] chart updated successfully.
2019-03-02 20:25:35.733 INFO Plugin.processLogQueue [Chart - TRV Battery Chart] chart updated successfully.
2019-03-02 20:25:36.347 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 1] chart updated successfully.
2019-03-02 20:25:36.922 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 2] chart updated successfully.
2019-03-02 20:25:37.107 INFO Plugin.processLogQueue [Chart Mini - Trend Ensuite] chart updated successfully.
2019-03-02 20:25:37.269 INFO Plugin.processLogQueue [Chart Mini - Trend Freezer] chart updated successfully.
2019-03-02 20:25:37.425 INFO Plugin.processLogQueue [Chart Mini - Trend Fridge] chart updated successfully.
2019-03-02 20:25:37.581 INFO Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] chart updated successfully.
2019-03-02 20:25:37.738 INFO Plugin.processLogQueue [Chart Mini - Trend Hallway] chart updated successfully.
2019-03-02 20:25:37.893 INFO Plugin.processLogQueue [Chart Mini - Trend Lounge] chart updated successfully.
2019-03-02 20:25:38.055 INFO Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] chart updated successfully.
2019-03-02 20:25:38.215 INFO Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] chart updated successfully.
2019-03-02 20:25:38.361 INFO Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] chart updated successfully.
2019-03-02 20:25:39.217 INFO Plugin.processLogQueue [Chart Motion - Downstairs - Bar] chart updated successfully.
2019-03-02 20:27:20.001 INFO Plugin.processLogQueue [Chart - Alt Temperature] chart updated successfully.
2019-03-02 20:27:20.380 INFO Plugin.processLogQueue [Chart - Broadband Speed Available] chart updated successfully.
2019-03-02 20:27:20.807 INFO Plugin.processLogQueue [Chart - Daily Power Usage] chart updated successfully.
2019-03-02 20:27:21.233 INFO Plugin.processLogQueue [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-02 20:27:21.452 INFO Plugin.processLogQueue [Chart - Downstairs Radiators - Batteries] chart updated successfully.
2019-03-02 20:27:22.031 INFO Plugin.processLogQueue [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-02 20:27:22.525 INFO Plugin.processLogQueue [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-02 20:27:22.753 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:27:22.754 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-02 20:27:22.754 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-02 20:27:22.754 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-02 20:27:22.754 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-02 20:27:22.755 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:27:22.755 WARNING Plugin.plot_custom_line_segments There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-02 20:27:22.959 INFO Plugin.processLogQueue [Chart - Fridge Power and Temperature] chart updated successfully.
2019-03-02 20:27:23.352 INFO Plugin.processLogQueue [Chart - Fridge Temperature] chart updated successfully.
2019-03-02 20:27:23.721 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Power Usage] chart updated successfully.
2019-03-02 20:27:24.147 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Temperature] chart updated successfully.
2019-03-02 20:27:24.409 INFO Plugin.processLogQueue [Chart - Heating Demand History] chart updated successfully.
2019-03-02 20:27:24.788 INFO Plugin.processLogQueue [Chart - Heating Hot Water] chart updated successfully.
2019-03-02 20:27:25.198 INFO Plugin.processLogQueue [Chart - Heating Hot Water Tank] chart updated successfully.
2019-03-02 20:27:25.512 INFO Plugin.processLogQueue [Chart - Household Power Usage] chart updated successfully.
2019-03-02 20:27:26.075 INFO Plugin.processLogQueue [Chart - Key Temperatures] chart updated successfully.
2019-03-02 20:27:26.339 INFO Plugin.processLogQueue [Chart - Power Tool Charger] chart updated successfully.
2019-03-02 20:27:26.791 INFO Plugin.processLogQueue [Chart - Radiator - Bathroom] chart updated successfully.
2019-03-02 20:27:27.148 INFO Plugin.processLogQueue [Chart - Radiator - Guest Bedroom] chart updated successfully.
2019-03-02 20:27:27.501 INFO Plugin.processLogQueue [Chart - Radiator - Guest Ensuite] chart updated successfully.
2019-03-02 20:27:27.973 INFO Plugin.processLogQueue [Chart - Radiator - Kitchen] chart updated successfully.
2019-03-02 20:27:28.451 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Back] chart updated successfully.
2019-03-02 20:27:28.927 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Front] chart updated successfully.
2019-03-02 20:27:29.400 INFO Plugin.processLogQueue [Chart - Radiator - Master Bed] chart updated successfully.
2019-03-02 20:27:30.122 INFO Plugin.processLogQueue [Chart - TRV Battery Chart] chart updated successfully.
2019-03-02 20:27:30.708 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 1] chart updated successfully.
2019-03-02 20:27:31.303 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 2] chart updated successfully.
2019-03-02 20:27:31.483 INFO Plugin.processLogQueue [Chart Mini - Trend Ensuite] chart updated successfully.
2019-03-02 20:27:31.641 INFO Plugin.processLogQueue [Chart Mini - Trend Freezer] chart updated successfully.
2019-03-02 20:27:31.794 INFO Plugin.processLogQueue [Chart Mini - Trend Fridge] chart updated successfully.
2019-03-02 20:27:31.949 INFO Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] chart updated successfully.
2019-03-02 20:27:32.107 INFO Plugin.processLogQueue [Chart Mini - Trend Hallway] chart updated successfully.
2019-03-02 20:27:32.267 INFO Plugin.processLogQueue [Chart Mini - Trend Lounge] chart updated successfully.
2019-03-02 20:27:32.434 INFO Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] chart updated successfully.
2019-03-02 20:27:32.588 INFO Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] chart updated successfully.
2019-03-02 20:27:32.753 INFO Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] chart updated successfully.
2019-03-02 20:27:33.617 INFO Plugin.processLogQueue [Chart Motion - Downstairs - Bar] chart updated successfully.
2019-03-02 20:27:34.009 INFO Plugin.processLogQueue [Chart Motion - Downstairs Scatter] chart updated successfully.
2019-03-02 20:27:34.010 INFO Plugin.refresh_the_charts_now ==================== Redraw Charts Now Menu Action Complete ====================
2019-03-02 20:28:49.266 INFO Plugin.processLogQueue [Chart - Alt Temperature] chart updated successfully.
2019-03-02 20:28:49.625 INFO Plugin.processLogQueue [Chart - Broadband Speed Available] chart updated successfully.
2019-03-02 20:28:50.053 INFO Plugin.processLogQueue [Chart - Daily Power Usage] chart updated successfully.
2019-03-02 20:28:50.499 INFO Plugin.processLogQueue [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-02 20:28:50.729 INFO Plugin.processLogQueue [Chart - Downstairs Radiators - Batteries] chart updated successfully.
2019-03-02 20:28:51.304 INFO Plugin.processLogQueue [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-02 20:28:51.785 INFO Plugin.processLogQueue [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-02 20:28:52.010 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:28:52.011 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-02 20:28:52.011 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-02 20:28:52.011 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-02 20:28:52.011 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-02 20:28:52.011 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:28:52.012 WARNING Plugin.plot_custom_line_segments There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-02 20:28:52.213 INFO Plugin.processLogQueue [Chart - Fridge Power and Temperature] chart updated successfully.
2019-03-02 20:28:52.617 INFO Plugin.processLogQueue [Chart - Fridge Temperature] chart updated successfully.
2019-03-02 20:28:52.990 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Power Usage] chart updated successfully.
2019-03-02 20:28:53.427 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Temperature] chart updated successfully.
2019-03-02 20:28:53.679 INFO Plugin.processLogQueue [Chart - Heating Demand History] chart updated successfully.
2019-03-02 20:28:54.079 INFO Plugin.processLogQueue [Chart - Heating Hot Water] chart updated successfully.
2019-03-02 20:28:54.534 INFO Plugin.processLogQueue [Chart - Heating Hot Water Tank] chart updated successfully.
2019-03-02 20:28:54.874 INFO Plugin.processLogQueue [Chart - Household Power Usage] chart updated successfully.
2019-03-02 20:28:55.451 INFO Plugin.processLogQueue [Chart - Key Temperatures] chart updated successfully.
2019-03-02 20:28:55.715 INFO Plugin.processLogQueue [Chart - Power Tool Charger] chart updated successfully.
2019-03-02 20:28:56.060 INFO Plugin.processLogQueue [Chart - Radiator - Bathroom] chart updated successfully.
2019-03-02 20:28:56.408 INFO Plugin.processLogQueue [Chart - Radiator - Guest Bedroom] chart updated successfully.
2019-03-02 20:28:56.805 INFO Plugin.processLogQueue [Chart - Radiator - Guest Ensuite] chart updated successfully.
2019-03-02 20:28:57.309 INFO Plugin.processLogQueue [Chart - Radiator - Kitchen] chart updated successfully.
2019-03-02 20:28:57.815 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Back] chart updated successfully.
2019-03-02 20:28:58.288 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Front] chart updated successfully.
2019-03-02 20:28:58.775 INFO Plugin.processLogQueue [Chart - Radiator - Master Bed] chart updated successfully.
2019-03-02 20:28:59.482 INFO Plugin.processLogQueue [Chart - TRV Battery Chart] chart updated successfully.
2019-03-02 20:29:00.074 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 1] chart updated successfully.
2019-03-02 20:29:00.669 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 2] chart updated successfully.
2019-03-02 20:29:00.859 INFO Plugin.processLogQueue [Chart Mini - Trend Ensuite] chart updated successfully.
2019-03-02 20:29:01.027 INFO Plugin.processLogQueue [Chart Mini - Trend Freezer] chart updated successfully.
2019-03-02 20:29:01.184 INFO Plugin.processLogQueue [Chart Mini - Trend Fridge] chart updated successfully.
2019-03-02 20:29:01.349 INFO Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] chart updated successfully.
2019-03-02 20:29:01.504 INFO Plugin.processLogQueue [Chart Mini - Trend Hallway] chart updated successfully.
2019-03-02 20:29:01.666 INFO Plugin.processLogQueue [Chart Mini - Trend Lounge] chart updated successfully.
2019-03-02 20:29:01.818 INFO Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] chart updated successfully.
2019-03-02 20:29:01.974 INFO Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] chart updated successfully.
2019-03-02 20:29:02.120 INFO Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] chart updated successfully.
2019-03-02 20:29:03.002 INFO Plugin.processLogQueue [Chart Motion - Downstairs - Bar] chart updated successfully.
2019-03-02 20:29:03.441 INFO Plugin.processLogQueue [Chart Motion - Downstairs Scatter] chart updated successfully.
2019-03-02 20:29:03.442 INFO Plugin.refresh_the_charts_now ==================== Redraw Charts Now Menu Action Complete ====================
2019-03-02 20:30:03.215 INFO Plugin.processLogQueue [Chart - Alt Temperature] chart updated successfully.
2019-03-02 20:30:03.579 INFO Plugin.processLogQueue [Chart - Broadband Speed Available] chart updated successfully.
2019-03-02 20:30:04.014 INFO Plugin.processLogQueue [Chart - Daily Power Usage] chart updated successfully.
2019-03-02 20:30:04.443 INFO Plugin.processLogQueue [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-02 20:30:04.665 INFO Plugin.processLogQueue [Chart - Downstairs Radiators - Batteries] chart updated successfully.
2019-03-02 20:30:05.339 INFO Plugin.processLogQueue [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-02 20:30:05.894 INFO Plugin.processLogQueue [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-02 20:30:06.124 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:30:06.125 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-02 20:30:06.125 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-02 20:30:06.125 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-02 20:30:06.126 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-02 20:30:06.126 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:30:06.126 WARNING Plugin.plot_custom_line_segments There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-02 20:30:06.328 INFO Plugin.processLogQueue [Chart - Fridge Power and Temperature] chart updated successfully.
2019-03-02 20:30:06.717 INFO Plugin.processLogQueue [Chart - Fridge Temperature] chart updated successfully.
2019-03-02 20:30:07.092 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Power Usage] chart updated successfully.
2019-03-02 20:30:07.671 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Temperature] chart updated successfully.
2019-03-02 20:30:07.935 INFO Plugin.processLogQueue [Chart - Heating Demand History] chart updated successfully.
2019-03-02 20:30:08.329 INFO Plugin.processLogQueue [Chart - Heating Hot Water] chart updated successfully.
2019-03-02 20:30:08.741 INFO Plugin.processLogQueue [Chart - Heating Hot Water Tank] chart updated successfully.
2019-03-02 20:30:09.066 INFO Plugin.processLogQueue [Chart - Household Power Usage] chart updated successfully.
2019-03-02 20:30:09.709 INFO Plugin.processLogQueue [Chart - Key Temperatures] chart updated successfully.
2019-03-02 20:30:10.007 INFO Plugin.processLogQueue [Chart - Power Tool Charger] chart updated successfully.
2019-03-02 20:30:10.355 INFO Plugin.processLogQueue [Chart - Radiator - Bathroom] chart updated successfully.
2019-03-02 20:30:10.697 INFO Plugin.processLogQueue [Chart - Radiator - Guest Bedroom] chart updated successfully.
2019-03-02 20:30:11.045 INFO Plugin.processLogQueue [Chart - Radiator - Guest Ensuite] chart updated successfully.
2019-03-02 20:30:11.513 INFO Plugin.processLogQueue [Chart - Radiator - Kitchen] chart updated successfully.
2019-03-02 20:30:12.003 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Back] chart updated successfully.
2019-03-02 20:30:12.478 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Front] chart updated successfully.
2019-03-02 20:30:12.964 INFO Plugin.processLogQueue [Chart - Radiator - Master Bed] chart updated successfully.
2019-03-02 20:30:13.788 INFO Plugin.processLogQueue [Chart - TRV Battery Chart] chart updated successfully.
2019-03-02 20:30:14.424 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 1] chart updated successfully.
2019-03-02 20:30:15.000 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 2] chart updated successfully.
2019-03-02 20:30:15.206 INFO Plugin.processLogQueue [Chart Mini - Trend Ensuite] chart updated successfully.
2019-03-02 20:30:15.359 INFO Plugin.processLogQueue [Chart Mini - Trend Freezer] chart updated successfully.
2019-03-02 20:30:15.524 INFO Plugin.processLogQueue [Chart Mini - Trend Fridge] chart updated successfully.
2019-03-02 20:30:15.684 INFO Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] chart updated successfully.
2019-03-02 20:30:15.839 INFO Plugin.processLogQueue [Chart Mini - Trend Hallway] chart updated successfully.
2019-03-02 20:30:15.997 INFO Plugin.processLogQueue [Chart Mini - Trend Lounge] chart updated successfully.
2019-03-02 20:30:16.159 INFO Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] chart updated successfully.
2019-03-02 20:30:16.337 INFO Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] chart updated successfully.
2019-03-02 20:30:16.488 INFO Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] chart updated successfully.
2019-03-02 20:30:17.374 INFO Plugin.processLogQueue [Chart Motion - Downstairs - Bar] chart updated successfully.
2019-03-02 20:30:17.790 INFO Plugin.processLogQueue [Chart Motion - Downstairs Scatter] chart updated successfully.
2019-03-02 20:30:17.791 INFO Plugin.refresh_the_charts_now ==================== Redraw Charts Now Menu Action Complete ====================
2019-03-02 20:32:25.897 INFO Plugin.processLogQueue [Chart - Alt Temperature] chart updated successfully.
2019-03-02 20:32:26.253 INFO Plugin.processLogQueue [Chart - Broadband Speed Available] chart updated successfully.
2019-03-02 20:32:26.717 INFO Plugin.processLogQueue [Chart - Daily Power Usage] chart updated successfully.
2019-03-02 20:32:27.147 INFO Plugin.processLogQueue [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-02 20:32:27.369 INFO Plugin.processLogQueue [Chart - Downstairs Radiators - Batteries] chart updated successfully.
2019-03-02 20:32:27.990 INFO Plugin.processLogQueue [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-02 20:32:28.475 INFO Plugin.processLogQueue [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-02 20:32:28.701 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:32:28.702 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-02 20:32:28.702 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-02 20:32:28.702 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-02 20:32:28.702 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-02 20:32:28.702 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-02 20:32:28.702 WARNING Plugin.plot_custom_line_segments There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-02 20:32:28.896 INFO Plugin.processLogQueue
Busta999 wrote:Ok a bigger [critical] issue for me is the way that MatPlotLib stops working without any continuous issue reporting in the Indigo logs.
DaveL17 wrote:I would say that is indeed a critical problem. If you should notice this occur again, please take a look at the individual chart images and note the last time they're updated. Just highlight the file and press CMD-I.
This will help us tell if the plugin is truly still outputting chart files successfully.
I know you said that you run three CSV engines--how many data sources are you tracking in total with those? To date, you're the only one reporting this issue so it's going to be a little bit tougher to isolate the cause. I'll add some additional logging measures to the portion of the code that outputs the CSV data to see if that will help us find out what's going on. It'll be helpful to know if it's a general fault (everything stops working) or a component fault (CSV data stops updating but charts continue to update.)
I appreciate you taking the time to report the problem!
P.S. I just want to remind everyone that this is a discussion of an unreleased test build for a plugin that is itself still in beta. There *will* be bugs, it's likely that features will come and go and things may move around from time to time. The version of the plugin available through the Indigo store will most likely always be more stable than the latest build on GitHub--but it's still a beta plugin.
2019-03-03 10:38:18.543 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-03 10:38:18.543 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-03 10:38:18.543 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-03 10:38:18.544 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-03 10:38:18.544 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-03 10:38:18.544 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-03 10:38:18.544 WARNING Plugin.plot_custom_line_segments There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-03 10:38:18.743 INFO Plugin.processLogQueue [Chart - Fridge Power and Temperature] chart updated successfully.
2019-03-03 10:38:19.115 INFO Plugin.processLogQueue [Chart - Fridge Temperature] chart updated successfully.
2019-03-03 10:38:19.476 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Power Usage] chart updated successfully.
2019-03-03 10:38:19.897 INFO Plugin.processLogQueue [Chart - Fridge-Freezer Temperature] chart updated successfully.
2019-03-03 10:38:20.132 INFO Plugin.processLogQueue [Chart - Heating Demand History] chart updated successfully.
2019-03-03 10:38:20.509 INFO Plugin.processLogQueue [Chart - Heating Hot Water] chart updated successfully.
2019-03-03 10:38:20.904 INFO Plugin.processLogQueue [Chart - Heating Hot Water Tank] chart updated successfully.
2019-03-03 10:38:21.206 INFO Plugin.processLogQueue [Chart - Household Power Usage] chart updated successfully.
2019-03-03 10:38:21.802 INFO Plugin.processLogQueue [Chart - Key Temperatures] chart updated successfully.
2019-03-03 10:38:22.403 INFO Plugin.processLogQueue [Chart - Power Tool Charger] chart updated successfully.
2019-03-03 10:38:22.744 INFO Plugin.processLogQueue [Chart - Radiator - Bathroom] chart updated successfully.
2019-03-03 10:38:23.081 INFO Plugin.processLogQueue [Chart - Radiator - Guest Bedroom] chart updated successfully.
2019-03-03 10:38:23.437 INFO Plugin.processLogQueue [Chart - Radiator - Guest Ensuite] chart updated successfully.
2019-03-03 10:38:23.945 INFO Plugin.processLogQueue [Chart - Radiator - Kitchen] chart updated successfully.
2019-03-03 10:38:24.430 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Back] chart updated successfully.
2019-03-03 10:38:24.911 INFO Plugin.processLogQueue [Chart - Radiator - Lounge Front] chart updated successfully.
2019-03-03 10:38:25.401 INFO Plugin.processLogQueue [Chart - Radiator - Master Bed] chart updated successfully.
2019-03-03 10:38:25.739 INFO Plugin.processLogQueue [Chart - Radiator - Molly] chart updated successfully.
2019-03-03 10:38:26.018 INFO Plugin.processLogQueue [Chart - Radiators Downstairs - Batteries] chart updated successfully.
2019-03-03 10:38:26.329 INFO Plugin.processLogQueue [Chart - Radiators Upstairs - Batteries] chart updated successfully.
2019-03-03 10:38:27.032 INFO Plugin.processLogQueue [Chart - TRV Battery Chart] chart updated successfully.
2019-03-03 10:38:27.610 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 1] chart updated successfully.
2019-03-03 10:38:28.175 INFO Plugin.processLogQueue [Chart - Upstairs Temperature 2] chart updated successfully.
2019-03-03 10:38:28.360 INFO Plugin.processLogQueue [Chart Mini - Trend Ensuite] chart updated successfully.
2019-03-03 10:38:28.513 INFO Plugin.processLogQueue [Chart Mini - Trend Freezer] chart updated successfully.
2019-03-03 10:38:28.667 INFO Plugin.processLogQueue [Chart Mini - Trend Fridge] chart updated successfully.
2019-03-03 10:38:28.822 INFO Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] chart updated successfully.
2019-03-03 10:38:28.983 INFO Plugin.processLogQueue [Chart Mini - Trend Hallway] chart updated successfully.
2019-03-03 10:38:29.140 INFO Plugin.processLogQueue [Chart Mini - Trend Lounge] chart updated successfully.
2019-03-03 10:38:29.289 INFO Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] chart updated successfully.
2019-03-03 10:38:29.442 INFO Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] chart updated successfully.
2019-03-03 10:38:29.586 INFO Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] chart updated successfully.
2019-03-03 10:38:30.450 INFO Plugin.processLogQueue [Chart Motion - Downstairs - Bar] chart updated successfully.
2019-03-03 10:38:30.845 INFO Plugin.processLogQueue [Chart Motion - Downstairs Scatter] chart updated successfully.
2019-03-03 10:38:30.846 INFO Plugin.refreshTheChartsAction =========================== Refresh Action Complete ============================
2019-03-03 10:38:31.514 INFO Plugin.processLogQueue [Chart - Alt Temperature] chart updated successfully.
2019-03-03 10:38:31.875 INFO Plugin.processLogQueue [Chart - Broadband Speed Available] chart updated successfully.
2019-03-03 10:38:32.289 INFO Plugin.processLogQueue [Chart - Daily Power Usage] chart updated successfully.
2019-03-03 10:38:32.717 INFO Plugin.processLogQueue [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-03 10:38:33.291 INFO Plugin.processLogQueue [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-03 10:38:33.764 INFO Plugin.processLogQueue [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-03 10:38:33.988 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-03 10:38:33.989 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-03-03 10:38:33.989 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4918, in plot_custom_line_segments
2019-03-03 10:38:33.989 CRITICAL Plugin.pluginErrorHandler !!! for element in constants_to_plot:
2019-03-03 10:38:33.989 CRITICAL Plugin.pluginErrorHandler !!! TypeError: 'int' object is not iterable
2019-03-03 10:38:33.990 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-03 11:25:31.268 DEBUG Plugin.csv_refresh_process CSV does not exist. Creating: /Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/TRV - Kitchen - Battery.csv
2019-03-03 11:25:32.269 DEBUG Plugin.csv_refresh_process [Main CSV Engine - TRV - Kitchen - Battery] all CSV data are older than the time limit. Returning original data.
DaveL17 wrote:Thanks, that's helpful. I see in the attached log that the plugin is reporting that the CSV files do not exist. For example,
- Code: Select all
I assume that these files *do* exist, so there's something going on there. Do you have any other scripts or processes that are reading/writing to these files? The code should be able to handle that situation, but I'll take a look to make sure that it's as robust as it can be. I'll also take a look at how the process queues commands. On my production Indigo environment, I have one CSV engine that manages about 25 data sources and the plugin runs forever without a problem. I wonder if the problem you're seeing is related to the sheer number of sources you're managing. To be honest, I wouldn't think that 100 sources would be that heavy of a lift, but it seems like the plugin is struggling to keep up.
DaveL17 wrote:I must admit that I didn't foresee someone maintaining 100+ data sources with the plugin.
