Moved house - run into some chart issues
Sun Jan 13, 2019 2:01 pm
Busta999 offline
Hi
Really enjoying using MatPlotlib!!
On running the Mac mini back up in the new house I am getting issues.
Now to add to the confusion I moved the Indigo to an iMac.
So lots of potential for my goof ups.
Can you give me any insight into how to fix these:-
13 Jan 2019, 19:50:44
   Matplotlib Critical Error       [Chart - Alt Temperature] list index out of range
13 Jan 2019, 19:51:00
   Matplotlib Critical Error       [Chart - Downstairs Temperature 1] list index out of range
   Matplotlib Critical Error       [Chart - Downstairs Temperature 2] list index out of range
   Matplotlib Critical Error       [Chart - Fridge Temperature] list index out of range
   Matplotlib Critical Error       [Chart - Key Temperatures] list index out of range
   Matplotlib Critical Error       [Chart - Luminance - Sunroom] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Ensuite] Argument dimensions are incompatible
   Matplotlib Critical Error       [Chart Mini - Trend Freezer] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Fridge] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Guest Bedroom] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Hallway] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Lounge] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Master Bedroom] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Molly Bedroom] list index out of range
   Matplotlib Critical Error       [Chart Mini - Trend Outdoor Temp] list index out of range
Mike
Sun Jan 13, 2019 2:31 pm
Re: Moved house - run into some chart issues
Hello Busta999 -- congratulations on the new house!
Sorry to hear that you've run into issues with the plugin. I believe that an upcoming release will make the plugin more resilient to what I think the problem to be, but that doesn't help you right now. The error you're seeing is likely due to the plugin being unable to see your CSV files or having insufficient access to the files and/or folder where the files are stored. I would first look at the plugin preferences to ensure that it's pointing to the location where the CSV files are saved, and then I would look at the authorities for the CSV folder and files themselves.
There are other possibilities, but this is the most likely scenario.
Mon Jan 14, 2019 3:34 am
Busta999 offline
The more I look into this .....
Looking at the Plugin Log
2019-01-14 09:21:33.772   INFO         Plugin.pluginEnvironmentLogger      ===================================================== Matplotlib Environment =====================================================
2019-01-14 09:21:33.772   INFO         Plugin.pluginEnvironmentLogger      Matplotlib version:             1.3.1
2019-01-14 09:21:33.772   INFO         Plugin.pluginEnvironmentLogger      Numpy version:                  1.8.0rc1
2019-01-14 09:21:33.772   INFO         Plugin.pluginEnvironmentLogger      Matplotlib Plugin version:      0.7.09
2019-01-14 09:21:33.772   INFO         Plugin.pluginEnvironmentLogger      Matplotlib RC Path:             /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/matplotlibrc
2019-01-14 09:21:33.773   INFO         Plugin.pluginEnvironmentLogger      Matplotlib Plugin log location: /Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib
2019-01-14 09:21:33.773   INFO         Plugin.pluginEnvironmentLogger      ==================================================================================================================================
2019-01-14 09:21:34.021   DEBUG        Plugin.startup                      Log Level = 40
2019-01-14 09:21:59.934   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:21:59.935   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:21:59.935   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4048, in get_data
2019-01-14 09:21:59.935   THREADDEBUG   Plugin.pluginErrorHandler           !!!     data_file  = open(data_source, "r")
2019-01-14 09:21:59.935   THREADDEBUG   Plugin.pluginErrorHandler           !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Temp - Utility (Hue).csv'
2019-01-14 09:21:59.936   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:21:59.936   WARNING      Plugin.get_data                     Error downloading CSV data. Skipping: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Temp - Utility (Hue).csv'
2019-01-14 09:21:59.939   CRITICAL     Plugin.processLogQueue              [Chart - Alt Temperature] list index out of range
2019-01-14 09:22:00.246   INFO         Plugin.processLogQueue              [Chart - Broadband Speed Available] updated successfully.
2019-01-14 09:22:00.496   INFO         Plugin.processLogQueue              [Chart - Cleaning Robot Power] updated successfully.
2019-01-14 09:22:00.816   INFO         Plugin.processLogQueue              [Chart - Daily Power Usage] updated successfully.
2019-01-14 09:22:00.933   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:00.934   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:22:00.934   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4048, in get_data
2019-01-14 09:22:00.934   THREADDEBUG   Plugin.pluginErrorHandler           !!!     data_file  = open(data_source, "r")
2019-01-14 09:22:00.934   THREADDEBUG   Plugin.pluginErrorHandler           !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Sunroom Temp.csv'
2019-01-14 09:22:00.934   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:00.935   WARNING      Plugin.get_data                     Error downloading CSV data. Skipping: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Sunroom Temp.csv'
2019-01-14 09:22:00.938   CRITICAL     Plugin.processLogQueue              [Chart - Downstairs Temperature 1] list index out of range
2019-01-14 09:22:01.004   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:01.004   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:22:01.005   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4048, in get_data
2019-01-14 09:22:01.005   THREADDEBUG   Plugin.pluginErrorHandler           !!!     data_file  = open(data_source, "r")
2019-01-14 09:22:01.005   THREADDEBUG   Plugin.pluginErrorHandler           !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Kitchen MultiSensor Temperature.csv'
2019-01-14 09:22:01.005   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:01.005   WARNING      Plugin.get_data                     Error downloading CSV data. Skipping: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Kitchen MultiSensor Temperature.csv'
2019-01-14 09:22:01.009   CRITICAL     Plugin.processLogQueue              [Chart - Downstairs Temperature 2] list index out of range
2019-01-14 09:22:01.378   INFO         Plugin.processLogQueue              [Chart - Freezer Power and Temperature] updated successfully.
2019-01-14 09:22:01.546   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:01.547   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:22:01.547   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4133, in plot_custom_line_segments
2019-01-14 09:22:01.547   THREADDEBUG   Plugin.pluginErrorHandler           !!!     for element in constants_to_plot:
2019-01-14 09:22:01.547   THREADDEBUG   Plugin.pluginErrorHandler           !!! TypeError: 'int' object is not iterable
2019-01-14 09:22:01.548   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:01.548   WARNING      Plugin.plot_custom_line_segments    There is a problem with the custom segments settings. 'int' object is not iterable
2019-01-14 09:22:01.727   INFO         Plugin.processLogQueue              [Chart - Fridge Power and Temperature] updated successfully.
2019-01-14 09:22:01.818   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:01.819   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:22:01.819   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4048, in get_data
2019-01-14 09:22:01.819   THREADDEBUG   Plugin.pluginErrorHandler           !!!     data_file  = open(data_source, "r")
2019-01-14 09:22:01.819   THREADDEBUG   Plugin.pluginErrorHandler           !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Temp Kitchen (Hue).csv'
2019-01-14 09:22:01.820   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:01.820   WARNING      Plugin.get_data                     Error downloading CSV data. Skipping: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Temp Kitchen (Hue).csv'
2019-01-14 09:22:01.823   CRITICAL     Plugin.processLogQueue              [Chart - Fridge Temperature] list index out of range
2019-01-14 09:22:02.126   INFO         Plugin.processLogQueue              [Chart - Fridge-Freezer Power Usage] updated successfully.
2019-01-14 09:22:02.459   INFO         Plugin.processLogQueue              [Chart - Fridge-Freezer Temperature] updated successfully.
2019-01-14 09:22:02.673   INFO         Plugin.processLogQueue              [Chart - Heating Demand History] updated successfully.
2019-01-14 09:22:02.909   INFO         Plugin.processLogQueue              [Chart - Heating Total Daily Power Usage] updated successfully.
2019-01-14 09:22:03.047   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:03.048   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:22:03.048   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4048, in get_data
2019-01-14 09:22:03.048   THREADDEBUG   Plugin.pluginErrorHandler           !!!     data_file  = open(data_source, "r")
2019-01-14 09:22:03.048   THREADDEBUG   Plugin.pluginErrorHandler           !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Temp Kitchen (Hue).csv'
2019-01-14 09:22:03.048   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:03.048   WARNING      Plugin.get_data                     Error downloading CSV data. Skipping: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Temp Kitchen (Hue).csv'
2019-01-14 09:22:03.052   CRITICAL     Plugin.processLogQueue              [Chart - Key Temperatures] list index out of range
2019-01-14 09:22:03.118   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:03.119   THREADDEBUG   Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-01-14 09:22:03.119   THREADDEBUG   Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4048, in get_data
2019-01-14 09:22:03.119   THREADDEBUG   Plugin.pluginErrorHandler           !!!     data_file  = open(data_source, "r")
2019-01-14 09:22:03.119   THREADDEBUG   Plugin.pluginErrorHandler           !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Sunroom Luminance.csv'
2019-01-14 09:22:03.120   THREADDEBUG   Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-01-14 09:22:03.120   WARNING      Plugin.get_data                     Error downloading CSV data. Skipping: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Sunroom Luminance.csv'
2019-01-14 09:22:03.123   CRITICAL     Plugin.processLogQueue              [Chart - Luminance - Sunroom] list index out of range
2019-01-14 09:22:03.351   INFO         Plugin.processLogQueue              [Chart - Mac Mini Corner] updated successfully.
2019-01-14 09:22:03.571   INFO         Plugin.processLogQueue              [Chart - Power Tool Charger] updated successfully.
2019-01-14 09:22:03.930   INFO         Plugin.processLogQueue              [Chart - Upstairs Temperature 1] updated successfully.
2019-01-14 09:22:04.284   INFO         Plugin.processLogQueue              [Chart - Upstairs Temperature 2] updated successfully.
2019-01-14 09:22:04.365   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Ensuite] Argument dimensions are incompatible
2019-01-14 09:22:04.473   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Freezer] Argument dimensions are incompatible
2019-01-14 09:22:04.573   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Fridge] Argument dimensions are incompatible
2019-01-14 09:22:04.677   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Guest Bedroom] Argument dimensions are incompatible
2019-01-14 09:22:04.778   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Hallway] Argument dimensions are incompatible
2019-01-14 09:22:04.882   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Lounge] Argument dimensions are incompatible
2019-01-14 09:22:04.980   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Master Bedroom] Argument dimensions are incompatible
2019-01-14 09:22:05.091   CRITICAL     Plugin.processLogQueue              [Chart Mini - Trend Molly Bedroom] Argument dimensions are incompatible
2019-01-14 09:22:05.338   INFO         Plugin.processLogQueue              [Chart Mini - Trend Outdoor Temp] updated successfully.
2019-01-14 09:22:05.339   INFO         Plugin.refresh_the_charts_now       ========================= Refresh Menu Action Complete =========================
The Plugin is creating the csvs ok
The files are in the right place..
But complaining about reading them
All the files are 777 so should be ok
I know I am missing something obvious......... :-)
Mike
Mon Jan 14, 2019 3:48 am
I can't tell from the screen print but you are creating the files in the path with the indigo 7.2 folder as opposed to Indigo 7 folder?
Mon Jan 14, 2019 4:12 am
There may be a couple things going on.
Jon may be on to one possibility. Please go into the plugin preferences file and check the first two settings--the data folder path and the output chart path and ensure that they are proper for your version of Indigo (or your preferred location if it was originally somewhere else).
A second thing which may be related -- when I look at the plugin log output I notice the following about the tracebacks that are listed as compared to the screenshot of the folder you provided:
  • Temp - Utility (Hue).csv (not in list of files)
  • Sunroom Temp.csv (not in list of files)
  • Kitchen MultiSensor Temperature.csv (not in list of files)
  • Temp Kitchen (Hue).csv (in list of files, but apparently called: Temp - Kitchen (Hue).csv)
  • Sunroom Luminance.csv (not in list of files)
The CSV files can be stored anywhere you like, so long as Indigo has authority to read the location (777 should do it.) The *default* location for the data and chart files is relative to Indigo 7 (and not Indigo 7.2) -- I'm going to make a change to that for the future.
Mon Jan 14, 2019 1:19 pm
Busta999 offline
It is in Indigo 7.2 because when updating from 7 to 7.2 the upgrade moved it to the 7.2 folder.
No idea how or why.
I'll clear out the missing files they are based upon rooms that don't exist in this house - so will clear that out and re-asses.
Open to ideas on how to move everything form 7.2 to just Indigo - which would be my preference.
Mike
Mon Jan 14, 2019 6:26 pm
I think Matt and Jay made the decision to move to the 7.2 naming convention and file system structure purposefully. I'd recommend not getting too creative to work around that.
What about it do you find unworkable?
Mon Jan 14, 2019 7:30 pm
The Indigo 7.2 installer should have copied over the files from the Indigo 7 folder to the 7.2 path. Each upgrade version (7.3, 7.x, 8.0, etc.) will now have its own folder tree. A bit of a pain, but required because users have to be able to revert to previous versions from a trial version.
Wed Jan 16, 2019 1:15 pm
Busta999 offline
@Dave17 I'm not finding unworkable at all - just working on your statement "The *default* location for the data and chart files is relative to Indigo 7 (and not Indigo 7.2)"
If that is not an issue then no issue for me :-)
Wed Jan 16, 2019 2:39 pm
Sorry, I could have been more clear.
For new users, installing the plugin for the first time, the default location that would come up in the configuration preferences would be set relative to the Indigo 7 (not Indigo 7.2) folder tree. This would create understandable confusion for anyone not using Inidgo 7. You should definitely set that path relative to your version of Indigo.
Future versions of the plugin will not have that limitation.
Sun Jan 20, 2019 4:23 pm
Busta999 offline
Ok I have been tidying up some.
A common Issue I am getting is
It is setup
Setup
Chart Mini - Trend Ensuite.jpeg (166.86 KiB) Viewed 3414 times
Ensuite Temp Trend.csv contains
timestamp,Ensuite Temp Trend
2019-01-20 19:33:24.461000,20.6
2019-01-20 19:48:35.746000,20.8
2019-01-20 20:03:46.965000,20.8
2019-01-20 20:18:58.071000,20.8
2019-01-20 20:34:09.096000,20.8
2019-01-20 20:49:20.035000,20.8
2019-01-20 21:04:31.305000,20.9
2019-01-20 21:19:43.342000,20.8
2019-01-20 21:34:56.090000,20.8
2019-01-20 21:50:07.254000,20.8
2019-01-20 22:05:10.761000,20.5
2019-01-20 22:20:22.406000,20.6
What blindingly obvious mistake am missing?
Thanks for any attempt to diagnose
Sun Jan 20, 2019 5:32 pm
Yeah, it seems that there is an issue when filling is turned on--it appears that all of the source CSV files need to have the same number of observations when filling. I believe that In each case where this has come up, turning off fill has silenced the error. I'm working to find a patch to address this.
Mon Jan 21, 2019 6:35 am
Busta999 offline
Dave
Thanks but I don't think that is Fill that is causing the problem.
I recreated the chart. Using exactly the same config and it works fine - with Fill turned on.
Looks like I just need to recreate all my 25+ graphs.
Mike
Mon Jan 21, 2019 6:42 am
Sorry that you have to go through that exercise -- it shouldn't be necessary if your new setup is configured the way the old one was (emphasis on the shouldn't, not to say it isn't). I did notice in your latest screen shot that you displayed only line 2's settings. Was there a line 1 as well? I assume there was, but thought I'd ask.
Mon Jan 21, 2019 9:16 am
Busta999 offline
I set it to use Line 1 - same issue.
As far as I can see the Chart Mini - Trend Ensuite and Test Chart Mini - Trend Ensuite are identical in config. One errors (old one), recreate it and it works fine.
Here is the config - I am pretty sure I am missing something obvious - so please excuse me if I missed it.
[img]
[/img]
[img]
[/img]
and the output form the working one
[img]
[/img]
I am being really thick here and cannot see why one works and the other does not
Screenshot 2019-01-21 at 15.07.26.png (154.4 KiB) Viewed 3350 times
Screenshot 2019-01-21 at 15.08.10.png (154.89 KiB) Viewed 3350 times
Test Chart Mini = Trend Ensuite.png (1.61 KiB) Viewed 3350 times
