Solved - Matplotlib plugin menu missing "Configure..."
Mon May 28, 2018 6:47 pm
l280 offline
Hi - I hope this helps someone.
I set up a new indigo server - using a case sensitive file system.
Strange - after installing the Matplotlib plugin, it was missing its "Configure..." menu entry.
In the "Server Plugin" folder, the file "pluginConfig.xml" did not follow the indigo naming convention of "PluginConfig.xml"
Renaming the file with the capital "P" restored the "Configure..." menu entry after a server restart.
Or the plugin gods granted me a wish for an hour of head banging on keyboard. :D
Tue May 29, 2018 5:35 am
Re: Solved - Matplotlib plugin menu missing "Configure..."
Whoops - sorry about that. I'm surprised it's taken this long to show up. I've corrected the name of the file and the fix will be available in the next update.
Thanks for reporting the problem.
