Feature Requests
Posted: Tue May 01, 2018 5:55 am
Please add all new feature requests for the matplotlib plugin to this thread.
Software Support and Home Automation Forum
https://forums.indigodomo.com/
autolog wrote:In the CSV Engine you can specify the number of Observations that you wish to keep in your CSV file.
It would also be useful to able to specify a user specified data retention period (e.g. 24 hours) so that older entries get dropped off. This would then make it easy to display graphs for the last 24 hours for example.
autolog wrote:A minor usability feature request: When you select an item (ID: field), it lists all devices and variables and then list is displayed at the bottom of the variable list. This means (in my case) there is an awful lot of scrolling to do before getting to the devices. It would be useful to be able to select from a device list or variable list.
As I said, very minor.
autolog wrote:It would also be useful to able to specify a user specified data retention period (e.g. 24 hours) so that older entries get dropped off. This would then make it easy to display graphs for the last 24 hours for example.
autolog wrote:It would be useful to be able to select from a device list or variable list.
autolog wrote:Hi Dave,
Thanks for the feature additions - It's much appreciated.
autolog wrote:I would like to be able to specify a different scale on the Y2 axis - Is this possible, if not can I request another feature addition?
My use case is mapping thermostat values; multiple Temperatures and Heat Setpoints. I use the range -5 deg C to 35 deg C for the Y1 axis. I would like to map the thermostat valve opening value on the Y2 scale from 0% (fully closed) to 100% (fully open). I would then be able to easily correlate the valve opening against the temperature.
norcoscia wrote:Can't wait - BTW, my charts are working great now!!!!!! Made it all week w/o any data drop outs!!!!!
PS. Maybe you could add a check for bad paths - I think that was my problem for a long time, it would eventually hang up the recording of new data points!!!!
