Feature Requests
Tue May 01, 2018 5:55 am
Feature Requests
Please add all new feature requests for the matplotlib plugin to this thread.
Tue Dec 18, 2018 4:42 am
CSV Engine Data Retention Period
In the CSV Engine you can specify the number of Observations that you wish to keep in your CSV file.
It would also be useful to able to specify a user specified data retention period (e.g. 24 hours) so that older entries get dropped off. This would then make it easy to display graphs for the last 24 hours for example. :)
Tue Dec 18, 2018 4:46 am
CSV Engine Item Selection
A minor usability feature request: When you select an item (ID: field), it lists all devices and variables and then list is displayed at the bottom of the variable list. This means (in my case) there is an awful lot of scrolling to do before getting to the devices. It would be useful to be able to select from a device list or variable list.
As I said, very minor. :wink:
Tue Dec 18, 2018 12:36 pm
Re: CSV Engine Data Retention Period
This is something that I've wanted to do for some time. Thanks for the suggestion.
Tue Dec 18, 2018 12:40 pm
Re: CSV Engine Item Selection
I think this would be pretty trivial to implement. When adding a new CSV source, the workflow would then become:
  1. add title.
  2. choose whether a source is a device or a variable.
  3. choose from list of only devices or variables based on the answer to number 2.
  4. choose device state or variable value.
Sun Dec 30, 2018 4:12 pm
This feature has been added in release v0.7.18.
Sun Dec 30, 2018 4:13 pm
Sun Dec 30, 2018 4:41 pm
Re: Feature Requests
Hi Dave,
Thanks for the feature additions - It's much appreciated. :D
Sun Dec 30, 2018 5:14 pm
autolog wrote:
Hi Dave,
Likewise my friend. Thank you for helping to test various changes to the plugin.
Cheers, and happy New Year!
Fri Jan 04, 2019 4:53 am
I would like to be able to specify a different scale on the Y2 axis - Is this possible, if not can I request another feature addition? :)
My use case is mapping thermostat values; multiple Temperatures and Heat Setpoints. I use the range -5 deg C to 35 deg C for the Y1 axis. I would like to map the thermostat valve opening value on the Y2 scale from 0% (fully closed) to 100% (fully open). I would then be able to easily correlate the valve opening against the temperature.
Fri Jan 04, 2019 7:01 am
It's not presently possible but it's on the list as they say. I need to be able to spend some time thinking about the best way to accomplish it.
The less-than-perfect hack is to create the first chart as you would normally for source 1 (with its scale on Y1), create a second transparent chart for source 2 (of the same dimensions) with its scale on Y2, and then overlay the second on top of the first on the control page. The rub is -- in order for the correlation to be useful -- both source CSVs have to be on the same timeline.
