Read from CSV file?
Mon Apr 03, 2017 3:09 pm
aderrington offline
Read from CSV file?
Great plugin, I'm using it all the time.
One query / request, Would it be possible to read from a CSV file to get data? I have an app called PeakHour, it monitors my SNMP devices and exports the data to a CSV file.
I'd like to be able to monitor the total upload/download that my house uses every day and log that to a chart.
Would this be possible?
Andrew
Mon Apr 03, 2017 3:30 pm
Re: Read from CSV file?
Hi Andrew - the plugin expects data that's in two columns. The first column is a time stamp, and the second column is the data element to be plotted. If your data is in that form, you can save it to the target data directory and the plugin should be able to read it. If it's in multiple columns, that's not going to work. I looked at doing multiple columns but it gets complicated quickly if columns move around, get renamed, etc.
If you can parse data elements into their own files, it should work no problem.
