Matplotlib Plugin for Indigo 7 - New!
Sun Oct 29, 2017 5:21 am
Busta999 offline
Re: Matplotlib Plugin for Indigo 7 - New!
Ok absolutely no reason to spend anytime on this - but I found it puzzling....
I have a graph that tracks daily power consumption of the Fridge and the Freezer, retentive I know, but having found a rogue fridge freezer using nearly 3Kw a day - Three times more than it should , I keep an eye on them now :-)
Suddenly the graph was going weird.
I cannot get it to report Fridge Daily Power Usage and the Freezer Daily Power usage is plain wrong.
So I recreated the graph again and that, test one, works fine.
I cannot for the life of me work out what I have done to make this no longer work, oh and I am sure it is operator error, just can't find it.
See attached pics...
Config for replacement graph
Fridge Freezer Daily Power Usage Graph - Test.jpeg (146.8 KiB) Viewed 1441 times
Config for original graph
Fridge Freezer Daily Power Usage Graph.jpeg (155.83 KiB) Viewed 1441 times
Replacement Graph - showing correctly
Chart - Test Fridge Daily Power Usage.png (21.26 KiB) Viewed 1441 times
Original Graph - now wrong
Chart - Fridge Freezer Daily Power Usage.png (21.37 KiB) Viewed 1441 times
Can you see where I am going wrong?
Sun Oct 29, 2017 5:34 am
Not sure if this is the sum total of the issue, but in the first example line 1 is 'Fridge Daily Power Usage' and line 2 is 'Freezer Daily Power Usage'. In the second example, line 1 and line 2 are both plotting 'Fridge Daily Power Usage'.
Sun Oct 29, 2017 6:12 am
Busta999 offline
And there you have it - a fresh pair of eyes sees all - I have been going over and over that again and again and did not see the elephant! Darn it. I tweaked that 2nd line at some point yesterday because the graph was scaling from 1 to -10 - which is odd for energy usage - there was no negative data and the lines were occurring in the top sliver of the graph. So I changed the line data to force it to recalibrate - and somehow put back the wrong data - at least I was right it was operator error. - Thans for spotting that.
Sun Oct 29, 2017 6:48 am
I completely understand. For example, see my discussion of two bugs in the WUnderground plugin from Friday. :)
Sat Jan 06, 2018 5:38 pm
deuan offline
First off, I have to say this is a great plugin. Having graphs on my control pages makes the page look so much more interesting.
I do have a problem, I have 5 CSV engines collecting data from various devices and everything appears to be working perfectly then without warning it just stops collecting data for all 5. When I restart the plugin it resumes collecting the data and everything is working again. Is this normal? Should I restart the plugin each day?
Deuan
Sun Jan 07, 2018 6:34 am
Glad you like the plugin! This behavior is definitely not normal.
  1. You say that you have 5 CSV engines. Do you mean that you have five separate CSV engine devices running? This *should* work without any errors, but that doesn't mean that it will. I'd recommend trying just one CSV engine device and have that one device manage the five data sources.
  2. Do you see any helpful information in the log file when the plugin stops working? Depending on your Indigo version there may be a log file located in this folder (Indigo 7 as example) which might provide some more insight because things are saved there that aren't written to the Indigo event log.
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.fogbert.indigoplugin.matplotlib/plugin.log
Any insight you can give me at the point the plugin fails will help me isolate the issue you're seeing. As always, please check any log data for personal information before posting it.
Mon Jan 08, 2018 4:03 am
deuan offline
Thanks Dave,
I will give this a try with just one engine and see what happens.
Mon Jan 08, 2018 9:25 pm
deuan offline
Hi Dave,
I am now just running one CSV collector with one device value and it's been running for a few hours now which is longer than before.
However I do see these errors
2018-01-09 14:17:15.557 Error client connection ID (CFBundleIdentifier) not unique: com.fogbert.indigoplugin.matplotlib
2018-01-09 14:17:18.323 Error plugin "Matplotlib 0.5.01" (pid 36540) failed to start -- restarting in 5 seconds
and after a while of the plugin running I can no longer edit the chart as It appears the plugin is not responding.
I did see an error, but I cannot find it in the logs now as the logs are very big. I will try to get the error to you later.
Tue Jan 09, 2018 1:16 am
deuan offline
Hi Dave,
This is the error I get after the plugin has been running for a few hours and I try to edit the CSV engine.
Error (client) timeout waiting for plugin response from com.fogbert.indigoplugin.matplotlib for request UiGetValues2
Error (client) timeout waiting for plugin response from com.fogbert.indigoplugin.matplotlib for request CallPluginFunc
Error (client) runDialogForDevice() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
At this point I cannot edit the plugin settings and have to restart it in order to change the configuration of the CSV engine
Hope this helps.
Deuan
Tue Jan 09, 2018 5:09 am
Hmmm. I can't reproduce your error and based on the information above, it looks like your CSV engine has gotten into a bad state.
Please paste the following code into an Indigo scripting window, replace the device ID with the ID of your CSV engine device, and post the result back here. Please be sure to look over the information before posting to mask any sensitive information. If you'd prefer, you can send it to me via a private message.
dev = indigo.devices[445253253]
indigo.server.log(unicode(dev))
Tue Jan 09, 2018 5:54 pm
deuan offline
Thanks Dave,
here is the output from the command
   Script                          address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : csvEngine
displayStateId : onOffState
displayStateImageSel : SensorOn
displayStateValRaw : True
displayStateValUi : Updated
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 389265641
     com.fogbert.indigoplugin.matplotlib : (dict)
          addItemFieldsCompleted : false (bool)
          addKey :  (string)
          addSource :  (string)
          addState :  (string)
          addValue :  (string)
          columnDict : {u'k1': (u'kw', u'1544181775', u'value')} (string)
          columnList :  (string)
          editKey :  (string)
          editSource :  (string)
          editState :  (string)
          editValue :  (string)
          isColumnSelected : false (bool)
          numLinesToKeep : 200 (string)
          previousKey :  (string)
lastChanged : 2018-01-10 08:26:13
lastSuccessfulComm : 2018-01-10 08:26:13
model : CSV Engine
name : Main CSV Engine
ownerProps : com.fogbert.indigoplugin.matplotlib : (dict)
     addKey :  (string)
     addState :  (string)
     addValue :  (string)
     editKey :  (string)
pluginId : com.fogbert.indigoplugin.matplotlib
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     csvLastUpdated : 2018-01-10 08:26:13.022558 (string)
     onOffState : true (bool)
     onOffState.ui : Updated (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Hope it helps
Deuan
Moderator's Note: edited to put device dict in code block.
Wed Jan 10, 2018 7:58 am
Thanks. I was interested in seeing the entry for 'columnDict' which appears to be constructed properly. In fact, nothing I can see about the CSV engine object looks out of place (I must admit that I'm struggling with the flu so I am more delirious than normal so I might miss something....)
I'd like you to try resetting the plugin preferences by taking the following steps.
  1. Disable the plugin in Indigo.
  2. Stop the Indigo server by selecting Stop Server from the Indigo menu.
  3. Delete the following file:
    /Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.fogbert.indigoplugin.matplotlib.indiPref
  4. Restart Indigo
  5. Open the Matplotlib plugin preferences and re-enter the settings as needed.
Hopefully, this will set things right.
Wed Jan 10, 2018 8:14 pm
deuan offline
Thanks Dave,
Sorry to hear you have the Flu, I hope you are feeling better soon. I will not bother you with my little issues until you are feeling better but I will give what you have suggested a go.
Thanks again for all your help.
Deuan
Wed Jan 10, 2018 8:45 pm
Don't worry about that, it's my choice to be here. :D
I'm starting to believe that a plugin may be causing a bottleneck. Another user is seeing similar behavior with the WUnderground plugin and we think it might be a misbehaving plugin. One way to test is to disable all your plugins and re-enable them one at a time to see if you're still having trouble. You might also be able to learn something with Activity Monitor if there's a process that's causing a bottleneck.
