I have to run out but I'll try this when I get back, thanks for the help
Feature request - drop down select boxes for State Names and ID's
norcoscia wrote:Feature request - drop down select boxes for State Names and ID's
DaveL17 wrote:Okay, that all looks good (unless you're flipping the state names with the device IDs which I doubt).
This is a long shot, but are you by any chance cutting and pasting the entries into the fields from somewhere else? Sometimes hidden characters or an extra space can come along with the paste. (A hidden character or extra space in the title probably won't hurt anything, but it won't work with an ID or state name).
Please check the path in the plugin configuration dialog to make sure that's entered correctly (both starts and ends with a forward slash).
Please also make sure that you click the "Add Item" button with each entry before you select Save. (If you don't add the item first, the changes won't commit.)
Lastly, please try this test: add a new CSV entry using a variable ID and in the Source State field enter the word 'value' (with no single quotes) and see if that works. You can always delete it later.
x = "{0}".format(u"àbç")
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.fogbert.indigoplugin.matplotlib/plugin.log
norcoscia wrote:So somehow I was able to get one item in the CSV engine to work - I'm not sure why it works. (it was an item I had tried before and it did not work) I then added a second item (another variable) and it failed just like all the others.
Something odd I noticed when I went to edit the items in the CSV engine - the working item does not show up in the list - the only way I can see the working item in the engine is to double click on the working item and then when I edit it is shows up - maybe that is normal behavior but figured I would let you know.
Anyway - thanks for trying - I don't think we have a good mechanism to troubleshoot this since nothing I see in the log looks like it will help.
I'm hate to give up but w/o a good next test step I don't want to burn any more calories on this - Maybe after you do a few updates I'll give it a try again - take care and I wish we could have got it to work...
indigo.server.log(u"{0}".format(indigo.devices[CSV_ENGINE_ID]))
columnDict : {u'k3': (u'barometric pressure', u'1149686816', u'pressure'), u'k2': (u'wunderground humidity', u'1149686816', u'relativeHumidity'), u'k1': (u'wunderground temp', u'1149686816', u'temp')} (string)
