Matplotlib Warning Invalid Indigo ID. invalid literal for int() with base 10: 'None'
Different Computers wrote:Afraid I don't see anything called a "CSV manager" in the plugin config, the chart device, or the CSV Engine. I can edit the file manually, though.
Matplotlib Critical Error Energy Line Chart: Check path to CSV file (x and y must have same first dimension)
Matplotlib Critical Error ValueError: to_rgba: Invalid rgba arg ""
to_rgb: Invalid rgb arg ""
could not convert string to float:
Different Computers wrote:I am on my way. But of course every time I change something, something new pops up
- Code: Select all
Is that about colors??? And/or is the first critical error due to the timestamps on the two data sources not being the same?
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.fogbert.indigoplugin.matplotlib/plugin.log
2016-12-02 15:17:37.416 DEBUG Plugin.getTheData Data retrieved successfully: /Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.fogbert.indigoplugin.matplotlib/Energy.csv
2016-12-02 15:17:37.416 DEBUG Plugin.getTheData Final data: [['Timestamp', 'Energy'], ['2016-12-01 20:51:06.956000', '1968.12'], ['2016-12-01 20:51:17.610000', '1968.12'], ['2016-12-01 20:51:28.375000', '1968.12'], ['2016-12-01 20:51:39.037000', '1968.12'], ['2016-12-01 20:51:49.665000', '1968.12'], ['2016-12-01 20:52:00.278000', '1968.12'], ['2016-12-01 20:52:10.910000', '1968.12'], ['2016-12-01 20:52:21.619000', '1968.12'], ['2016-12-01 20:52:32.274000', '1968.12'], ['2016-12-01 20:52:42.887000', '1968.12'], ['2016-12-01 20:52:53.496000', '1968.12'], ['2016-12-01 20:53:04.111000', '1968.12'], ['2016-12-01 20:53:14.745000', '1968.12'], ['2016-12-01 20:53:25.363000', '1968.12'], ['2016-12-01 20:53:35.972000', '1968.12'], ['2016-12-01 20:53:46.588000', '1409.76'], ['2016-12-01 20:53:57.187000', '1409.76'], ['2016-12-01 20:54:07.801000', '1409.76'], ['2016-12-01 20:54:18.918000', '1409.76'], ['2016-12-01 20:54:30.042000', '1409.76'], ['2016-12-01 20:54:40.653000', '1409.76'], ['2016-12-01 20:54:51.258000', '1409.76'], ['2016-12-01 20:55:01.874000', '1409.76'], ['2016-12-01 20:55:12.496000', '1409.76'], ['2016-12-01 20:55:23.168000', '1409.76'], ['2016-12-01 20:55:33.806000', '1409.76'], ['2016-12-01 20:55:44.422000', '1409.76'], ['2016-12-01 20:55:55.040000', '1408.11'], ['2016-12-01 20:56:05.658000', '1408.11'], ['2016-12-01 20:56:16.308000', '1408.11'], ['2016-12-01 20:56:26.971000', '1408.11'], ['2016-12-01 20:56:37.578000', '1408.11'], ['2016-12-01 20:56:48.182000', '1408.11'], ['2016-12-01 20:56:58.799000', '1408.11'], ['2016-12-01 20:57:09.430000', '1408.11'], ['2016-12-01 20:58:50.055000', '1408.11'], ['2016-12-01 21:09:46.692000', '1407.12'], ['2016-12-01 21:25:12.498000', '1416.91'], ['2016-12-01 21:30:47.576000', '1434.95'], ['2016-12-01 22:00:49.751000', '1413.61'], ['2016-12-01 22:30:50.327000', '303.6'], ['2016-12-01 23:00:50.805000', '751.08'], ['2016-12-01 23:30:51.244000', '97.35'], ['2016-12-02 00:00:51.726000', '98.12'], ['2016-12-02 00:30:52.261000', '95.7'], ['2016-12-02 01:00:52.918000', '1413.72'], ['2016-12-02 01:30:53.424000', '1453.65'], ['2016-12-02 02:00:53.925000', '4216.85'], ['2016-12-02 02:30:54.408000', '3797.2'], ['2016-12-02 03:00:54.939000', '3792.58'], ['2016-12-02 03:30:55.467000', '7447.22'], ['2016-12-02 04:00:56.046000', '1584.0'], ['2016-12-02 04:30:56.612000', '1566.29'], ['2016-12-02 05:00:57.112000', '1852.73'], ['2016-12-02 05:30:57.657000', '7665.02'], ['2016-12-02 06:00:58.291000', '3746.27'], ['2016-12-02 06:30:58.875000', '3739.89'], ['2016-12-02 07:00:59.458000', '3623.62'], ['2016-12-02 07:31:00.018000', '7733.11'], ['2016-12-02 08:01:00.681000', '1837.77'], ['2016-12-02 08:31:01.553000', '1166.33'], ['2016-12-02 09:01:02.203000', '315.92'], ['2016-12-02 09:31:02.861000', '95.04'], ['2016-12-02 10:01:03.452000', '520.08'], ['2016-12-02 10:31:03.796000', '82.5'], ['2016-12-02 11:01:04.099000', '81.07'], ['2016-12-02 11:31:04.414000', '1287.0'], ['2016-12-02 12:01:04.754000', '1332.32'], ['2016-12-02 12:31:07.921000', '1353.0'], ['2016-12-02 13:01:10.354000', '310.75'], ['2016-12-02 13:31:10.682000', '276.1'], ['2016-12-02 14:01:11.051000', '125.62'], ['2016-12-02 14:31:11.406000', '288.97'], ['2016-12-02 15:01:11.706000', '863.61']]
2016-12-02 15:17:37.422 DEBUG Plugin.plotCustomLineSegments Custom line segments (False): None
2016-12-02 15:17:37.423 THREADDEBUG Plugin.chartSimpleLine Y Max: 7733.11 Y Min: 81.07 Y Diff: 7652.04
2016-12-02 15:17:37.423 THREADDEBUG Plugin.setAxisScaleX Constructing the bins for the X axis.
2016-12-02 15:17:37.427 DEBUG Plugin.chartSimpleLine Display legend: False
2016-12-02 15:17:37.427 DEBUG Plugin.chartSimpleLine Display grids [X/Y]: False / False
2016-12-02 15:17:37.463 THREADDEBUG Plugin.refreshTheCharts Output chart: /Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/ChartEnergyLine.png
2016-12-02 15:17:37.463 THREADDEBUG Plugin.refreshTheCharts Output kwargs: {'bbox_extra_artists': None, 'pad_inches': None, 'orientation': None, 'edgecolor': u'#000000', 'format': None, 'papertype': None, 'bbox_inches': None, 'frameon': None, 'transparent': False, 'facecolor': u'#000000'}
2016-12-02 15:17:37.646 THREADDEBUG Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2016-12-02 15:17:37.646 THREADDEBUG Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! File "plugin.py", line 963, in refreshTheCharts
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! plt.savefig(u"{0}{1}".format(self.pluginPrefs['chartPath'], p_dict['fileName']), **k_dict['k_plot_fig'])
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/pyplot.py", line 561, in savefig
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! return fig.savefig(*args, **kwargs)
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/figure.py", line 1421, in savefig
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! self.canvas.print_figure(*args, **kwargs)
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backend_bases.py", line 2220, in print_figure
2016-12-02 15:17:37.647 THREADDEBUG Plugin.pluginErrorHandler !!! **kwargs)
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backends/backend_agg.py", line 505, in print_png
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! FigureCanvasAgg.draw(self)
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backends/backend_agg.py", line 451, in draw
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! self.figure.draw(self.renderer)
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/artist.py", line 55, in draw_wrapper
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! draw(artist, renderer, *args, **kwargs)
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/figure.py", line 1034, in draw
2016-12-02 15:17:37.648 THREADDEBUG Plugin.pluginErrorHandler !!! func(*args)
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! draw(artist, renderer, *args, **kwargs)
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/axes.py", line 2086, in draw
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! a.draw(renderer)
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/artist.py", line 55, in draw_wrapper
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/lines.py", line 529, in draw
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! ln_color_rgba = self._get_rgba_ln_color()
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/lines.py", line 1038, in _get_rgba_ln_color
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! rgba_ln = colorConverter.to_rgba(ln_color, self._alpha)
2016-12-02 15:17:37.649 THREADDEBUG Plugin.pluginErrorHandler !!! File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/colors.py", line 365, in to_rgba
2016-12-02 15:17:37.650 THREADDEBUG Plugin.pluginErrorHandler !!! 'to_rgba: Invalid rgba arg "%s"\n%s' % (str(arg), exc))
2016-12-02 15:17:37.650 THREADDEBUG Plugin.pluginErrorHandler !!! ValueError: to_rgba: Invalid rgba arg ""
2016-12-02 15:17:37.650 THREADDEBUG Plugin.pluginErrorHandler !!! to_rgb: Invalid rgb arg ""
2016-12-02 15:17:37.650 THREADDEBUG Plugin.pluginErrorHandler !!! could not convert string to float:
2016-12-02 15:17:37.650 THREADDEBUG Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2016-12-02 15:17:37.650 CRITICAL Plugin.refreshTheCharts ValueError: to_rgba: Invalid rgba arg ""
2016-12-02 15:18:30.752 DEBUG Plugin.getDeviceConfigUiValues ********* Plugin Settings Menu *********
indigo.server.log(unicode(indigo.devices[DEVICE_ID_HERE]))
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : wunderground
displayStateId : onOffState
displayStateImageSel : TemperatureSensorOn
displayStateValRaw : True
displayStateValUi : 44 °F
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1418405935
com.fogbert.indigoplugin.wunderground : (dict)
address : KVATROY8 (string)
configMenuUnits : S (string)
deviceVersion : 1 (string)
distanceUnits : mi. (string)
itemListUiUnits : S (string)
percentageUnits : % (string)
pressureUnits : in. (string)
rainUnits : in. (string)
space01 : true (bool)
space03 : true (bool)
space05 : false (bool)
suppressWeatherAlerts : false (bool)
temperatureUnits : ° (string)
weatherSummaryEmail : false (bool)
weatherSummaryEmailSent : false (bool)
windUnits : mph (string)
lastChanged : 2016-12-04 13:09:51
lastSuccessfulComm : 2016-12-04 13:09:51
model : WUnderground Weather
name : Current Conditions
ownerProps : com.fogbert.indigoplugin.wunderground : (dict)
pluginId : com.fogbert.indigoplugin.wunderground
protocol : Plugin
remoteDisplay : False
states : States : (dict)
alertDescription1 : (string)
alertDescription1.ui : (string)
alertDescription2 : (string)
alertDescription2.ui : (string)
alertDescription3 : (string)
alertDescription3.ui : (string)
alertDescription4 : (string)
alertDescription4.ui : (string)
alertDescription5 : (string)
alertDescription5.ui : (string)
alertExpires1 : (string)
alertExpires1.ui : (string)
alertExpires2 : (string)
alertExpires2.ui : (string)
alertExpires3 : (string)
alertExpires3.ui : (string)
alertExpires4 : (string)
alertExpires4.ui : (string)
alertExpires5 : (string)
alertExpires5.ui : (string)
alertMessage1 : (string)
alertMessage1.ui : (string)
alertMessage2 : (string)
alertMessage2.ui : (string)
alertMessage3 : (string)
alertMessage3.ui : (string)
alertMessage4 : (string)
alertMessage4.ui : (string)
alertMessage5 : (string)
alertMessage5.ui : (string)
alertStatus : false (string)
alertStatus.ui : False (string)
alertType1 : (string)
alertType1.ui : (string)
alertType2 : (string)
alertType2.ui : (string)
alertType3 : (string)
alertType3.ui : (string)
alertType4 : (string)
alertType4.ui : (string)
alertType5 : (string)
alertType5.ui : (string)
conditions1 : Overcast (string)
conditions1.ui : Overcast (string)
conditions2 : Partly Cloudy (string)
conditions2.ui : Partly Cloudy (string)
conditions3 : Rain (string)
conditions3.ui : Rain (string)
conditions4 : Clear (string)
conditions4.ui : Clear (string)
currentObservation : Last Updated on December 4, 1:08 PM EST (string)
currentObservation.ui : Last Updated on December 4, 1:08 PM EST (string)
currentObservationEpoch : 1480874922 (string)
currentObservationEpoch.ui : 1480874922 (string)
currentWeather : Clear (string)
currentWeather.ui : Clear (string)
dewpoint : 32 (real)
dewpoint.ui : 32° (string)
estimated : false (bool)
estimated.ui : False (string)
feelslike : 44 (real)
feelslike.ui : 44° (string)
foreDay1 : Sunday (string)
foreDay1.ui : Sunday (string)
foreDay2 : Monday (string)
foreDay2.ui : Monday (string)
foreDay3 : Tuesday (string)
foreDay3.ui : Tuesday (string)
foreDay4 : Wednesday (string)
foreDay4.ui : Wednesday (string)
foreHigh1 : 45 (real)
foreHigh1.ui : 45° (string)
foreHigh2 : 59 (real)
foreHigh2.ui : 59° (string)
foreHigh3 : 42 (real)
foreHigh3.ui : 42° (string)
foreHigh4 : 55 (real)
foreHigh4.ui : 55° (string)
foreHum1 : 87 (real)
foreHum1.ui : 87% (string)
foreHum2 : 99 (real)
foreHum2.ui : 99% (string)
foreHum3 : 100 (real)
foreHum3.ui : 100% (string)
foreHum4 : 100 (real)
foreHum4.ui : 100% (string)
foreLow1 : 38 (real)
foreLow1.ui : 38° (string)
foreLow2 : 36 (real)
foreLow2.ui : 36° (string)
foreLow3 : 35 (real)
foreLow3.ui : 35° (string)
foreLow4 : 36 (real)
foreLow4.ui : 36° (string)
forePop1 : 10 (real)
forePop1.ui : 10% (string)
forePop2 : 10 (real)
forePop2.ui : 10% (string)
forePop3 : 100 (real)
forePop3.ui : 100% (string)
forePop4 : 10 (real)
forePop4.ui : 10% (string)
foreText1 : Generally cloudy. High around 45F. Winds light and variable. (string)
foreText1.ui : Generally cloudy. High around 45F. Winds light and variable. (string)
foreText2 : Occasional light rain. Low 38F. Winds light and variable. Chance of rain 90%. (string)
foreText2.ui : Occasional light rain. Low 38F. Winds light and variable. Chance of rain 90%. (string)
foreText3 : Cloudy skies early, then partly cloudy in the afternoon. High 59F. Winds light and variable. (string)
foreText3.ui : Cloudy skies early, then partly cloudy in the afternoon. High 59F. Winds light and variable. (string)
foreText4 : Partly cloudy skies early followed by increasing clouds with showers developing later at night. Low 36F. Winds light and variable. Chance of rain 50%. (string)
foreText4.ui : Partly cloudy skies early followed by increasing clouds with showers developing later at night. Low 36F. Winds light and variable. Chance of rain 50%. (string)
foreText5 : Rain likely. High 42F. Winds light and variable. Chance of rain 100%. Rainfall may reach one inch. (string)
foreText5.ui : Rain likely. High 42F. Winds light and variable. Chance of rain 100%. Rainfall may reach one inch. (string)
foreText6 : Cloudy skies early will become partly cloudy later at night. Low near 35F. Winds light and variable. (string)
foreText6.ui : Cloudy skies early will become partly cloudy later at night. Low near 35F. Winds light and variable. (string)
foreText7 : Generally sunny despite a few afternoon clouds. High near 55F. Winds light and variable. (string)
foreText7.ui : Generally sunny despite a few afternoon clouds. High near 55F. Winds light and variable. (string)
foreText8 : Partly cloudy skies in the evening, then becoming cloudy overnight. Low 36F. Winds light and variable. (string)
foreText8.ui : Partly cloudy skies in the evening, then becoming cloudy overnight. Low 36F. Winds light and variable. (string)
foreTextLong : Today is forecast to be about the same as yesterday. (string)
foreTextLong.ui : Today is forecast to be about the same as yesterday. (string)
foreTextShort : about the same (string)
foreTextShort.ui : about the same (string)
foreTitle1 : Sunday (string)
foreTitle1.ui : Sunday (string)
foreTitle2 : Sunday Night (string)
foreTitle2.ui : Sunday Night (string)
foreTitle3 : Monday (string)
foreTitle3.ui : Monday (string)
foreTitle4 : Monday Night (string)
foreTitle4.ui : Monday Night (string)
foreTitle5 : Tuesday (string)
foreTitle5.ui : Tuesday (string)
foreTitle6 : Tuesday Night (string)
foreTitle6.ui : Tuesday Night (string)
foreTitle7 : Wednesday (string)
foreTitle7.ui : Wednesday (string)
foreTitle8 : Wednesday Night (string)
foreTitle8.ui : Wednesday Night (string)
foreWind1 : 2 (real)
foreWind1.ui : 2 mph (string)
foreWind2 : 4 (real)
foreWind2.ui : 4 mph (string)
foreWind3 : 4 (real)
foreWind3.ui : 4 mph (string)
foreWind4 : 5 (real)
foreWind4.ui : 5 mph (string)
heatIndex : NA (string)
heatIndex.ui : NA (string)
historyDate : December 4, 2016 (string)
historyDate.ui : December 4, 2016 (string)
historyHigh : 44.2 (real)
historyHigh.ui : 44° (string)
historyLow : 28.7 (real)
historyLow.ui : 29° (string)
historyPop : 0 (real)
historyPop.ui : 0.0 in. (string)
icon1 : cloudy (string)
icon1.ui : cloudy (string)
icon2 : nt_chancerain (string)
icon2.ui : nt_chancerain (string)
icon3 : partlycloudy (string)
icon3.ui : partlycloudy (string)
icon4 : nt_chancerain (string)
icon4.ui : nt_chancerain (string)
icon5 : rain (string)
icon5.ui : rain (string)
icon6 : nt_partlycloudy (string)
icon6.ui : nt_partlycloudy (string)
icon7 : clear (string)
icon7.ui : clear (string)
icon8 : nt_mostlycloudy (string)
icon8.ui : nt_mostlycloudy (string)
locationCity : Troy (string)
locationCity.ui : Troy (string)
onOffState : true (bool)
onOffState.ui : 44 °F (string)
precip_1hr : 0 (real)
precip_1hr.ui : 0.0 in. (string)
precip_today : 0 (real)
precip_today.ui : 0.0 in. (string)
pressure : 30.24 (real)
pressure.ui : 30.24 in. (string)
pressureIcon : 3024 (integer)
pressureIcon.ui : 3024 (string)
pressureTrend : v (string)
pressureTrend.ui : v (string)
properIconName : clear (string)
properIconName.ui : clear (string)
properIconNameAllDay : clear (string)
properIconNameAllDay.ui : clear (string)
relativeHumidity : 61 (real)
relativeHumidity.ui : 61% (string)
solarradiation : -- (string)
solarradiation.ui : -- (string)
stationID : KVATROY8 (string)
stationID.ui : KVATROY8 (string)
temp : 44.2 (real)
temp.ui : 44° (string)
tempIcon : 44 (real)
tempIcon.ui : 44.0 (string)
uv : 3 (string)
uv.ui : 3 (string)
visibility : 10 (real)
visibility.ui : 10.0 mi. (string)
windDIR : North (string)
windDIR.ui : North (string)
windDegrees : 0 (integer)
windDegrees.ui : 0.0 (string)
windGust : 0.0 (string)
windGust.ui : 0.0 mph (string)
windGustIcon : 0 (integer)
windGustIcon.ui : 00 (string)
windShortString : North at 0.0 (string)
windShortString.ui : North at 0.0 mph (string)
windSpeed : 0.0 (string)
windSpeed.ui : 0.0 mph (string)
windSpeedIcon : 0 (integer)
windSpeedIcon.ui : 00 (string)
windString : From the North at 0.0 MPH Gusting to 00 MPH (string)
windString.ui : From the North at 0.0 MPH Gusting to 00 MPH (string)
windStringMetric : (string)
windchill : 44 (real)
windchill.ui : 44° (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
lastChanged : 2016-12-04 13:15:07
lastSuccessfulComm : 2016-12-04 13:15:07
model : Home Energy Monitor (DSB09104)
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
SupportsBatteryLevel : true (bool)
SupportsEnergyMeter : true (bool)
SupportsEnergyMeterCurPower : true (bool)
SupportsEnergyMeterReset : true (bool)
SupportsOnState : false (bool)
SupportsSensorValue : false (bool)
SupportsStatusRequest : true (bool)
address : 12 (integer)
disableStatusLogging : true (bool)
indigoObjVersion : 5 (integer)
propsPushTickler : 2 (string)
tempAlwaysFalse : false (bool)
userConfigVal111 : 600 (integer)
userConfigVal255 : false (bool)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 60 (integer)
version : 3.60 (string)
zwAppVersMajor : 3 (integer)
zwAppVersMinor : 60 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
zwAssociationsMapStr : 1:[1] (string)
zwClassCmdBase : 49 (integer)
zwClassCmdMap : (dict)
c112 : 1 (integer)
c114 : 1 (integer)
c128 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c32 : 1 (integer)
c49 : 2 (integer)
c50 : 2 (integer)
c96 : 2 (integer)
zwClassCmdMapStr : 20v1 80v1 85v1 86v1 60v2 72v1 70v1 31v2 32v2 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 33 (integer)
Item : 1 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Multilevel Sensor (routing) (string)
zwConfigVals : (dict)
p10 : 10 (integer)
p101 : 16141 (integer)
p102 : 0 (integer)
p103 : 0 (integer)
p11 : 10 (integer)
p111 : 600 (integer)
p112 : 600 (integer)
p113 : 600 (integer)
p3 : 0 (integer)
p5 : 50 (integer)
p6 : 50 (integer)
p7 : 50 (integer)
p8 : 10 (integer)
p9 : 10 (integer)
zwConfigValsStr : 3:0 5:50 6:50 7:50 8:10 9:10 10:10 11:10 111:600 112:600 113:600 103:0 102:0 101:16141 (string)
zwDevSubIndex : 0 (integer)
zwEndpointClassMap : (dict)
e1 : (list)
Item : 49 (integer)
Item : 50 (integer)
e2 : (list)
Item : 49 (integer)
Item : 50 (integer)
zwEndpointClassMapStr : 1:[31 32], 2:[31 32] (string)
zwEndpointDevTypeMap : (dict)
e1 : (list)
Item : 33 (integer)
Item : 1 (integer)
e2 : (list)
Item : 33 (integer)
Item : 1 (integer)
zwEndpointDevTypeMapStr : 1:(21 : 01), 2:(21 : 01) (string)
zwFeatureListStr : routing, battery, beaming, frequentWaking, energyMeter (string)
zwLibType : 3 (integer)
zwManufactureId : 134 (integer)
zwManufactureName : Aeon Labs (string)
zwMeterSubTypeFlags : 5 (integer)
zwMeterSupportsReset : true (bool)
zwMeterType : 1 (integer)
zwModelDefnVers : 3 (integer)
zwModelId : 131081 (integer)
zwModelName : Home Energy Monitor (DSB09104) (string)
zwNodeNeighbors : (list)
Item : 6 (integer)
Item : 11 (integer)
Item : 14 (integer)
Item : 15 (integer)
zwNodeNeighborsStr : 6, 11, 14, 15 (string)
zwProtoVersMajor : 2 (integer)
zwProtoVersMinor : 78 (integer)
zwShowMainUI : true (bool)
zwShowPollingUI : false (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
accumEnergyTimeDelta : 306816 (integer)
accumEnergyTimeDelta.ui : 306816 seconds (string)
accumEnergyTotal : 0 (real)
accumEnergyTotal.ui : 0.0 kWh (string)
batteryLevel : 33 (integer)
batteryLevel.ui : 33% (string)
curEnergyLevel : 1801.14 (real)
curEnergyLevel.ui : 1801.140 W (string)
subModel : Meter Total
supportsStatusRequest : True
version : 3.60
Script address :
batteryLevel : None
configured : True
description :
deviceTypeId : lineChartingDevice
displayStateImageSel : SensorOn
displayStateValUi : Enabled
enabled : True
errorState :
folderId : 251697344
com.fogbert.indigoplugin.matplotlib : (dict)
bar1Color : #FFFFFF (string)
bar1ColorOther : #FFFFFF (string)
bar1Source : None (string)
bar2Color : #FFFFFF (string)
bar2ColorOther : #FFFFFF (string)
bar2Source : None (string)
bar3Color : #FFFFFF (string)
bar3ColorOther : #FFFFFF (string)
bar3Source : None (string)
bar4Color : #FFFFFF (string)
bar4ColorOther : #FFFFFF (string)
bar4Source : None (string)
barLabel1 : false (bool)
barLabel2 : false (bool)
barLabel3 : false (bool)
barLabel4 : false (bool)
chartTitle : Title (string)
customAxisLabelX : X Axis (string)
customAxisLabelY : Y Axis (string)
customLineSegments : None (string)
customLineStyle : : (string)
customSizeChart : false (bool)
customSizeFont : false (bool)
customSizeHeight : None (string)
customSizeWidth : None (string)
customTickFontSize : 8 (string)
customTitleFontSize : 10 (string)
enableCustomLineSegmentsSetting : true (bool)
fileName : chart_line (string)
line1Annotate : false (bool)
line1Color : #4B0082 (string)
line1ColorOther : #FFFFFF (string)
line1Fill : false (bool)
line1Marker : None (string)
line1MarkerColor : #FFFFFF (string)
line1MarkerColorOther : #FFFFFF (string)
line1Source : outdoor humidity.csv (string)
line1Style : - (string)
line2Annotate : false (bool)
line2Color : #FFFFFF (string)
line2ColorOther : #FFFFFF (string)
line2Fill : false (bool)
line2Marker : None (string)
line2MarkerColor : #FFFFFF (string)
line2MarkerColorOther : #FFFFFF (string)
line2Source : None (string)
line2Style : - (string)
line3Annotate : false (bool)
line3Color : #FF0000 (string)
line3ColorOther : #FFFFFF (string)
line3Fill : false (bool)
line3Marker : None (string)
line3MarkerColor : #FFFFFF (string)
line3MarkerColorOther : #FFFFFF (string)
line3Source : None (string)
line3Style : - (string)
line4Annotate : false (bool)
line4Color : #FFFFFF (string)
line4ColorOther : #FFFFFF (string)
line4Fill : false (bool)
line4Marker : None (string)
line4MarkerColor : #FFFFFF (string)
line4MarkerColorOther : #FFFFFF (string)
line4Source : None (string)
line4Style : - (string)
lineLabel1 : false (bool)
lineLabel2 : false (bool)
lineLabel3 : false (bool)
lineLabel4 : false (bool)
plotLine1Max : false (bool)
plotLine1Min : false (bool)
plotLine2Max : false (bool)
plotLine2Min : false (bool)
plotLine3Max : false (bool)
plotLine3Min : false (bool)
plotLine4Max : false (bool)
plotLine4Min : false (bool)
rectWide : true (bool)
showLegend : false (bool)
showxAxisGrid : false (bool)
showyAxisGrid : false (bool)
xAxisBins : half-hourly (string)
xAxisLabel : false (bool)
xAxisLabelFormat : %I:%M (string)
y2AxisLabel : false (bool)
yAxisLabel : false (bool)
yAxisMax : None (string)
yAxisMin : None (string)
yAxisPrecision : 0 (string)
lastChanged : 2016-12-04 20:57:51
lastSuccessfulComm : 2016-12-04 20:57:51
model : Line Chart
ownerProps : com.fogbert.indigoplugin.matplotlib : (dict)
pluginId : com.fogbert.indigoplugin.matplotlib
protocol : Plugin
chartLastUpdated : 2016-12-04 20:57:50.945519 (string)
onOffState.ui : Enabled (string)
subModel :
version : None
lastChanged : 2016-12-04 18:08:21
lastSuccessfulComm : 2016-12-04 18:08:21
model : Line Chart
name : Energy Line Chart
chartTitle : Energy Usage vs. temps (string)
customAxisLabelX : Time (string)
customAxisLabelY : Watts (string)
customLineStyle : - (string)
customSizeChart : true (bool)
customSizeHeight : 400 (string)
customSizeWidth : 840 (string)
customTickFontSize : (string)
customTitleFontSize : (string)
enableCustomLineSegmentsSetting : false (bool)
fileName : ChartEnergyLine.png (string)
line1Color : (string)
line1Fill : true (bool)
line1Marker : . (string)
line1Source : Energy.csv (string)
line2Marker : o (string)
line2Source : Weather (temp).csv (string)
line3Color : #FFFFFF (string)
line3Style : None (string)
line4MarkerColor : (string)
line4Style : None (string)
plotLine1Max : true (bool)
plotLine1Min : true (bool)
rectWide : false (bool)
showLegend : true (bool)
xAxisBins : hourly (string)
xAxisLabelFormat : %A (string)
yAxisLabel : true (bool)
protocol : Plugin
chartLastUpdated : 2016-12-02 15:34:04.988353 (string)
subModel :
version : None
