Matplotlib Plugin Updates
Wed Jan 25, 2023 9:54 am
Re: Matplotlib Plugin Updates
Version v2022.1.5 of the Matplotlib Plugin is now available.
Overview
This release contains a new enhancement to choose a precision level for chart annotations (i.e., 12, 12.3, 12.30) and a significant change to the Theme Manager Save action. It also contains several important bug fixes.
All Indigo 2022+ users are encouraged to apply this update.
Details
  • Charts
    • NEW - Annotation value precision controls added to Area, Bar Flow Vertical, Bar Stock Horizontal, Bar Stock Vertical, Line, Weather Forecast devices.
    • Fixed bug in annotation display for weather forecast devices.
  • Theme Manager
    • REVISION - Changes behavior of Save Theme action to allow updates to existing themes without having to create a new theme.
    • Fixed bug in Theme Manager Rename action.
  • Custom Line Segments
    • Deprecates step, steps-mid, and steps-post line styles which are no longer supported by Matplotlib.
    • Fixed bug that caused custom line segments to not be plotted.
  • Code refinements.
  • Minor UI refinements.
You can download it here.
You can view the plugin instructions here.
Sat Feb 04, 2023 12:47 pm
Version v2022.1.6 of the Matplotlib Plugin is now available.
  • Fixed bug where custom Y axis tick marks and locations were sometimes not plotted properly.
  • Fixed bug where rcParamsDevice devices were not skipped when user elects to redraw all charts from the plugin menu.
  • Code refinements.
If you find, after applying this update, that a Matplotlib Parameters Device status results in `Error`, it is best to delete and recreate the device. Users who don't have a Matplotlib Parameters Device do not need to take any special actions after applying the update.
Wed Mar 08, 2023 5:44 pm
Version v2022.1.7 of the Matplotlib Plugin is now available.
Overview
This update contains a few bug fixes (no new features). You are encouraged to apply the update; however, if you're not seeing errors in your implementation, you can hold off.
Details
  • Fixes bug where Matplotlib Paramters Device incorrectly labelled in error state.
  • Fixes bug PluginAction object has no attribute 'PROPS'.
  • Fixes bug where Refresh CSV Device Action returned an error when no such devices exist.
Wed Dec 27, 2023 8:25 am
Version v2023.0.1 of the Matplotlib Plugin is now available.
Matplotlib Plugin version v2023.0.1 includes changes to prepare for Indigo v2023.2.
Users who expect to update to Indigo v2023.2 should download and install this plugin release BEFORE updating Indigo. Otherwise, you'll be greeted with a sea of red in the Events log. These changes are necessary to accommodate changes to the Matplotlib library and not due to Indigo. This release also has a fair number of code refinements under the hood.
UPDATE -- I should have been clear that users of Indigo v2023.1 are safe to update -- and should update before moving to v2023.2.
