All of a sudden receiving Unknown Error
Sun Apr 23, 2023 1:52 pm
BruceP offline
Lutron IP Gateway: Unknown Error: [Errno 60] Operation timed out
I have a house full of RR2 and the plugin was working very well
This has started all of a sudden. Months of no issues, and no changes many devices are not controlled.
Anyone else having this issue??
Sun Apr 23, 2023 2:50 pm
Re: All of a sudden receiving Unknown Error
That's almost certainly a network error on your home network. Check to make sure the IP address of your repeater hasn't somehow changed.
I'd reboot the router, the repeater, and then restart the plugin.
Mon Apr 24, 2023 6:05 am
BruceP offline
Just did a full reset of the house.
Will advise
Thank you
Tue Apr 25, 2023 5:39 am
BruceP offline
Back to the same issue.
Here is a weird timeline.
4/24 reflector connection failed at, but reconnected on its own:
17:18
18:29
21:20
4/25/23
4:41
4/25 at 7:07 the original issue error message arrives
Restart plugin
Lutron IP gateway connecting via IP 10.0.0.33.23
FING app reports the following:
10.0.1.33 is controller Lutron and is off-line (however I can control lighting via the Lutron app)
10.0.1.34 on-connect Lutron 01f02C49 and it also is listed as offline
Most of this is out of my wheel house
Tue Apr 25, 2023 6:03 am
This is. RRa2, correct? Do you have a Connect Bridge? Do both of those devices have reserved IP address in your router so that their IP addresses can't change?
Tue Apr 25, 2023 6:07 am
Fing is saying the address of the RRa2 repeater is 10.0.1.33? Earlier in your post you wrote:
So which is it? 10.0.1.33 or 10.0.0.33?
Tue Apr 25, 2023 6:49 am
BruceP offline
Screen shot from Fing
All wireless was set up by someone else, I will ask. May take a while to get an answer.
Screen Shot 2023-04-25 at 8.44.18 AM.png (143.07 KiB) Viewed 1890 times
Tue Apr 25, 2023 8:34 am
Enable debug level logging in the Lutron plugin, restart the plugin, then paste the log entries to reply in this thread.
Tue Apr 25, 2023 9:30 am
BruceP offline
Here you go
Apr 25, 2023 at 11:08:10 AM
   Lutron RRA2/Caséta Debug        New logLevel = 5
   Reloading plugin "Lutron RRA2/Caséta 2022.1.2" using API v3.0
   Stopping plugin "Lutron RRA2/Caséta 2022.1.2" (pid 88983)
   Lutron RRA2/Caséta Debug        stop_concurrent_thread called
   Lutron RRA2/Caséta Debug        Removing Trigger Lutron Button Push test (1225649574)
   Lutron RRA2/Caséta              Lutron IP Gateway: Running IP Stop
   Lutron RRA2/Caséta              Shutting down Lutron
   Stopped plugin "Lutron RRA2/Caséta 2022.1.2"
   Starting plugin "Lutron RRA2/Caséta 2022.1.2" (pid 90063)
   Lutron RRA2/Caséta Debug        logLevel = 5
   Started plugin "Lutron RRA2/Caséta 2022.1.2"
   Lutron RRA2/Caséta              Starting up Lutron RRA2/Caséta
   Lutron RRA2/Caséta              Lutron IP Gateway: Running IP Start
   Lutron RRA2/Caséta              Lutron IP Gateway: Connecting via IP to 10.0.1.33:23
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.connIP.read: b'login: '
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: Sending username
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.connIP.read: b'password: '
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: Sending password
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: Login process complete, connected
   Lutron RRA2/Caséta Debug        Starting Trigger 'Lutron Button Push test', pluginProps = com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
     buttonID : 1521085578 (string)
     clicks : 1 (string)
     gateway : 1539370365 (string)
     room : Entry (string)
   Lutron RRA2/Caséta Debug        Adding keypadButtonPress Trigger 'Lutron Button Push test', buttonID = 1521085578
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 2 characters read:
b'\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'\r''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'''
   Lutron RRA2/Caséta Debug        Received command:  from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 6 characters read:
b'GNET> '
Tue Apr 25, 2023 10:11 am
BruceP offline
Apr 25, 2023 at 11:46:27 AM
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 19 characters read:
b'~OUTPUT,27,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'GNET> ~OUTPUT,27,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'GNET> ~OUTPUT,27,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: GNET> ~OUTPUT,27,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: GNET> ~OUTPUT,27,1,0.00
   Lutron RRA2/Caséta Debug        Received: Dimmer Duff's Office - Dimmer 27 - Guest Down Lts level set to 0.0
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 17 characters read:
b'~OUTPUT,27,29,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,27,29,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,27,29,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,27,29,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,27,29,0
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 22 characters read:
b'~OUTPUT,27,30,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,27,30,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,27,30,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,27,30,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,27,30,1,0.00
Apr 25, 2023 at 11:46:55 AM
b'~OUTPUT,31,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,31,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,31,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,31,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,31,1,0.00
   Lutron RRA2/Caséta Debug        Received: Switch Laundry Room - Switch 31 - Recess Lights turned Off
b'~OUTPUT,31,29,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,31,29,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,31,29,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,31,29,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,31,29,0
b'~OUTPUT,31,30,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,31,30,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,31,30,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,31,30,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,31,30,1,0.00
b'~DEVICE,20,84,9,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~DEVICE,20,84,9,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~DEVICE,20,84,9,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~DEVICE,20,84,9,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received a Device message: ~DEVICE,20,84,9,0
   Lutron RRA2/Caséta Debug        Received a keypad button/LED status message: ~DEVICE,20,84,9,0
   Lutron RRA2/Caséta Debug        Updating button status with state of LED (0) for keypadID 1539370365:20.4
b'~OUTPUT,32,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,32,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,32,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,32,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,32,1,0.00
   Lutron RRA2/Caséta Debug        Received: Switch Laundry Room - Switch 32 - Under Cabinet Lights turned Off
b'~OUTPUT,32,29,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,32,29,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,32,29,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,32,29,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,32,29,0
b'~OUTPUT,32,30,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,32,30,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,32,30,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,32,30,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,32,30,1,0.00
Apr 25, 2023 at 12:00:07 PM
   Received INSTEON                "Garage Motion Detector" on (button 2)
Apr 25, 2023 at 12:01:14 PM
   Received INSTEON                "Garage Motion Detector" on (button 1)
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 20 characters read:
b'~OUTPUT,9,1,100.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,9,1,100.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,9,1,100.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,9,1,100.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,9,1,100.00
   Lutron RRA2/Caséta Debug        Received: Switch Garage - Switch 9 - Ceiling Lights turned On
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 16 characters read:
b'~OUTPUT,9,29,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,9,29,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,9,29,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,9,29,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,9,29,0
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 23 characters read:
b'~OUTPUT,9,30,1,100.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,9,30,1,100.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,9,30,1,100.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,9,30,1,100.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,9,30,1,100.00
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 18 characters read:
b'~DEVICE,7,81,9,1\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~DEVICE,7,81,9,1\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~DEVICE,7,81,9,1\r''
   Lutron RRA2/Caséta Debug        Received command: ~DEVICE,7,81,9,1 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received a Device message: ~DEVICE,7,81,9,1
   Lutron RRA2/Caséta Debug        Received a keypad button/LED status message: ~DEVICE,7,81,9,1
   Lutron RRA2/Caséta Debug        Updating button status with state of LED (1) for keypadID 1539370365:7.1
b'~DEVICE,7,82,9,1\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~DEVICE,7,82,9,1\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~DEVICE,7,82,9,1\r''
   Lutron RRA2/Caséta Debug        Received command: ~DEVICE,7,82,9,1 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received a Device message: ~DEVICE,7,82,9,1
   Lutron RRA2/Caséta Debug        Received a keypad button/LED status message: ~DEVICE,7,82,9,1
   Lutron RRA2/Caséta Debug        Updating button status with state of LED (1) for keypadID 1539370365:7.2
Apr 25, 2023 at 12:01:58 PM
b'~OUTPUT,9,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,9,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,9,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,9,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,9,1,0.00
   Lutron RRA2/Caséta Debug        Received: Switch Garage - Switch 9 - Ceiling Lights turned Off
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 21 characters read:
b'~OUTPUT,9,30,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,9,30,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,9,30,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,9,30,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,9,30,1,0.00
b'~DEVICE,7,81,9,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~DEVICE,7,81,9,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~DEVICE,7,81,9,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~DEVICE,7,81,9,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received a Device message: ~DEVICE,7,81,9,0
   Lutron RRA2/Caséta Debug        Received a keypad button/LED status message: ~DEVICE,7,81,9,0
   Lutron RRA2/Caséta Debug        Updating button status with state of LED (0) for keypadID 1539370365:7.1
b'~DEVICE,7,82,9,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~DEVICE,7,82,9,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~DEVICE,7,82,9,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~DEVICE,7,82,9,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received a Device message: ~DEVICE,7,82,9,0
   Lutron RRA2/Caséta Debug        Received a keypad button/LED status message: ~DEVICE,7,82,9,0
   Lutron RRA2/Caséta Debug        Updating button status with state of LED (0) for keypadID 1539370365:7.2
b'~OUTPUT,10,1,100.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,10,1,100.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,10,1,100.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,10,1,100.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,10,1,100.00
   Lutron RRA2/Caséta Debug        Received: Switch Garage Work Area Lights turned On
b'~OUTPUT,10,29,0\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,10,29,0\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,10,29,0\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,10,29,0 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,10,29,0
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: 24 characters read:
b'~OUTPUT,10,30,1,100.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,10,30,1,100.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,10,30,1,100.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,10,30,1,100.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,10,30,1,100.00
Apr 25, 2023 at 12:02:29 PM
b'~OUTPUT,10,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,10,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,10,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,10,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,10,1,0.00
   Lutron RRA2/Caséta Debug        Received: Switch Garage Work Area Lights turned Off
b'~OUTPUT,10,30,1,0.00\r\n'
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: self.buffer = 'b'~OUTPUT,10,30,1,0.00\r\n''
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: msg = 'b'~OUTPUT,10,30,1,0.00\r''
   Lutron RRA2/Caséta Debug        Received command: ~OUTPUT,10,30,1,0.00 from Gateway 1539370365
   Lutron RRA2/Caséta Debug        Received an Output message: ~OUTPUT,10,30,1,0.00
Apr 25, 2023 at 12:02:59 PM
   Error                           reflector connection test failed: unable to connect to server
   Warning                         reflector reconnection scheduled in 5 seconds
Apr 25, 2023 at 12:03:34 PM
   Error                           failed to create reflector connection: unable to connect to server
   Warning                         reflector reconnection scheduled in 15 minutes
Apr 25, 2023 at 12:04:20 PM
Tue Apr 25, 2023 10:22 am
I said Debug logging, not Detailed Debug. ;)
Tue Apr 25, 2023 10:23 am
Ok, so you're actually connecting to the repeater at 10.0.1.33, not 10.0.0.33 as you wrote above. Fing was correct.
Tue Apr 25, 2023 10:26 am
I'm not seeing any errors from the Lutron plugin. Reduce the logging level to just "Debug", and then post again when/if you see that error again. Include the logs from around the time of the error.
Wed Apr 26, 2023 5:06 am
BruceP offline
Exterior lighting was to turn off but did not. Hopefully this is what you are looking for.
Other commands following this seem to be working
Apr 26, 2023 at 5:46:01 AM
   Schedule                        Exterior Lighting OFF AM
   Action Group                    Exterior Lighting Off AM
   Lutron RRA2/Caséta Debug        Garden Entry Flood: actionControlDimmerRelay sending: '#OUTPUT,12,1,0' to gateway 1539370365
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: Sending: '#OUTPUT,12,1,0'
   Schedule                        schedule "Exterior Lighting OFF AM" (delayed action)
   Lutron RRA2/Caséta Debug        Garage Coach Light: actionControlDimmerRelay sending: '#OUTPUT,6,1,0' to gateway 1539370365
   Lutron RRA2/Caséta Debug        Lutron IP Gateway: Sending: '#OUTPUT,6,1,0'
Apr 26, 2023 at 5:46:56 AM
   Lutron RRA2/Caséta Error        Lutron IP Gateway: Unknown Error: [Errno 60] Operation timed out
   Lutron RRA2/Caséta Debug        Received: Dimmer Bruce Office level set to 28.18
Wed Apr 26, 2023 6:53 am
This is all pointing towards network errors on your LAN. Or possibly on the Indigo server system. Something is definitely interfering with the network connection between the Indigo server and the Lutron repeater. Also with the reflector endpoint. The plugin is seeing it, as is the Fing app.
