Manage Linked Devices menu option error
Tue Nov 01, 2022 9:16 pm
neetorama offline
I'm in the process of getting the Lutron plugin setup and I'm running into an error from the Managed Linked Devices menu option.
Clicking the Controlling Keypad Room drop down within Managed Linked Devices shows the following message:
Failed to Get UI List from Plugin:
InvalidParameterError: plugin does not define method roomListGenerator
This is what I'm seeing in the logs:
Lutron RRA2/Caséta Debug        menuChanged, typeId = manageLinkedDevices, valuesDict = UiValuesDict : (dict)
     addLinkedDevice :  (string)
     buttonDevice :  (string)
     controlledDevice :  (string)
     deleteLinkedDevices :  (string)
     linkName :  (string)
     linkedDeviceList : (list)
     publishedLabel :  (string)
     room : InvalidParameterError: plugin does not define method roomListGenerator (string)
     sep1 :  (string)
   Lutron RRA2/Caséta Debug        controllableDevices, typeId = manageLinkedDevices, targetId = 0, valuesDict = UiValuesDict : (dict)
     linkName :  (string)
     sep1 :  (string)
   Lutron RRA2/Caséta Debug        pickKeypadButton, typeId = manageLinkedDevices, targetId = 0, valuesDict = UiValuesDict : (dict)
     linkName :  (string)
     sep1 :  (string)
The plugin seems to be working fine otherwise. I was able to successfully create the Caseta L-BDGPRO2 gateway device and import my Lutron devices (Pico remotes, Plug-In Dimmer) to Indigo using the Create Devices from Caseta Smart Bridge Pro option. Lutron events such as keypad button presses and plug-in dimmer states are registering in Indigo.
Am I missing a step somewhere?
Screen Shot 2022-11-01 at 10.53.04 PM.png (56.76 KiB) Viewed 2918 times
Screen Shot 2022-11-01 at 10.54.20 PM.png (141.84 KiB) Viewed 2918 times
Wed Nov 02, 2022 7:56 am
Re: Manage Linked Devices menu option error
You found a bug. Fixed in 2022.0.7, should be available in plugin store.
Wed Nov 02, 2022 9:29 am
neetorama offline
That worked! Thank you!
Wed Nov 02, 2022 9:41 am
neetorama offline
Spoke too soon. Lutron Rooms are now populating under Managed Linked Devices, but the Controlling Keypad Button drop down is blank for each room.
Wed Nov 02, 2022 9:50 am
Are the keypad buttons actually assigned to a room? That could be a problem for Caseta devices.
Wed Nov 02, 2022 10:08 am
neetorama offline
The keypads are assigned to rooms. I don’t see an option to assign individual buttons to specific rooms. Is there a difference between assigning keypads to a room and assigning buttons to a room?
I’m new to Lutron, so please bear with me.
Wed Nov 02, 2022 10:21 am
I meant the Indigo devices representing the buttons, not the actual devices (in the Lutron app).
Wed Nov 02, 2022 10:40 am
neetorama offline
Yes. Indigo devices are assigned to rooms.
Screen Shot 2022-11-02 at 12.38.11 PM.png (50.7 KiB) Viewed 2862 times
Screen Shot 2022-11-02 at 12.37.06 PM.png (78.47 KiB) Viewed 2862 times
Wed Nov 02, 2022 10:44 am
Hmm. OK. That feature was originally designed for RRa2 keypads, not Picos, so there might be some other bug. Can you open an issue on the GitHub repository and put those screenshots and a debug-level log in it? Turn on debug logging, attempt to create a linked device entry, then turn off logging and put the log text in the issue.
Wed Nov 02, 2022 10:47 am
neetorama offline
You got it. Thanks for your help.
