Re: Unable to create devices from RRA2 Repeater
Posted: Mon May 30, 2022 1:50 pm
Slow down and go through this step by step. First thing to determine is if you're having a Lutron issue or an Indigo/plugin issue.
You need to activate, program, then transfer to the Lutron repeater first. Did you then test the keypads to make sure they're working before doing anything with them in Indigo?
Then, once you're sure everything is working properly standalone, you need to create Indigo devices to match your existing Lutron devices. You can do that manually, or the plugin will do it for you. You showed yesterday that you were trying to get the plugin to do it. If that's where you're stuck, I need that DbXmlInfo.xml file to proceed. I need it as it gets downloaded, not as an html file or anything else. I sent you via PM the email address to send me the file.
Once you have Indigo devices set up to match all the Lutron devices, you test them using the Indigo client.
Only after all that has been tested do you do anything with Triggers.
