Unable to create devices from RRA2 Repeater
Sun May 29, 2022 5:11 pm
SMUSEBY offline
I'm not able to reload the updated Lutron dBase into Indigo.
In the devices list, the Lutron IP Gateway shows as connected.
I've tried multiple times, and occasionally, receive the following message:
2022-05-29 15:00:01.080 Lutron RRA2/Caséta Error Lutron IP Gateway: EOFError: telnet connection closed
Mostly, there is no indication in the event log that anything is happening at all.
In Lutron, I have changes some of the room names. I have tried deleting the old, related names in Indigo devices, but that didn't help.
I've rebooted, reloaded Indigo, reloaded the lutron plug-in, and cleared the erros in the Lutron transfer process.
Another anomaly which may or may not be related: established Indigo triggers that are working do not display, in Triggers > Edit Event Settings... > Configure Button Presses - the Presses and Room fields are populated, but the Button: field is blank. Nevertheless, the triggers are working.
Note: using plugin v22.0.1 and Indigo v2022.1
Any suggestion?
Sun May 29, 2022 6:01 pm
Re: Unable to create devices from RRA2 Repeater
Enable debug logging, restart the plugin, then try the import process again.
Sun May 29, 2022 6:26 pm
SMUSEBY offline
May 29, 2022 at 5:24:29 PM
   Lutron RRA2/Caséta Debug        Starting device fetch thread...
   Lutron RRA2/Caséta Debug        Device fetch thread running, valuesDict = UiValuesDict : (dict)
     create_event_triggers : false (bool)
     create_group_triggers : false (bool)
     create_unused_keypad : false (bool)
     create_unused_note :  (string)
     create_unused_phantom : false (bool)
     gateway : 68394 (string)
     group_by : Type (string)
     local_note :  (string)
     separator0 :  (string)
     separator1 :  (string)
     separator2 :  (string)
     use_local : false (bool)
     warning_note :  (string)
     xmlFileName : ~/DbXmlInfo.xml (string)
   Lutron RRA2/Caséta              Creating RRA2 Devices from gateway 68394, Grouping = Type, Create unprogrammed keypad buttons = False, Create unprogrammed phantom buttons = False
   Lutron RRA2/Caséta              Creating Devices - starting data fetch...
   Lutron RRA2/Caséta              Creating Devices fetch completed, parsing data...
   Lutron RRA2/Caséta              Finding devices in '1 gar'
   Lutron RRA2/Caséta Debug        Output: garCeiling (15) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 gar - Dimmer 15 - garCeiling' (68394:15)
   Lutron RRA2/Caséta Debug        Device: kPd (70,HYBRID_SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Component: 1 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 2 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 3 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 4 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 5 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 6 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 18 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 19 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 81 (LED)
   Lutron RRA2/Caséta Debug        Component: 82 (LED)
   Lutron RRA2/Caséta Debug        Component: 83 (LED)
   Lutron RRA2/Caséta Debug        Component: 84 (LED)
   Lutron RRA2/Caséta Debug        Component: 85 (LED)
   Lutron RRA2/Caséta Debug        Component: 86 (LED)
   Lutron RRA2/Caséta              Finding devices in 'b Office/TV'
   Lutron RRA2/Caséta Debug        Output: trackW (13) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Office/TV - Dimmer 13 - trackW' (68394:13)
   Lutron RRA2/Caséta Debug        Output: tracksN&S (9) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Office/TV - Dimmer 9 - tracksN&S' (68394:9)
   Lutron RRA2/Caséta Debug        Output: trackE (8) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Office/TV - Dimmer 8 - trackE' (68394:8)
   Lutron RRA2/Caséta Debug        Output: Ceiling (7) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Office/TV - Dimmer 7 - Ceiling' (68394:7)
   Lutron RRA2/Caséta Debug        Device: kPd (64,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Office/TV - kPd - Button 064.05 - Path Up' (68394:64.5)
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Office/TV - kPd - Button 064.05 - Path Up LED' (68394:64.85)
   Lutron RRA2/Caséta              Finding devices in '2 nBed'
   Lutron RRA2/Caséta Debug        Output: wallWashers (82) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nBed - Dimmer 82 - wallWashers' (68394:82)
   Lutron RRA2/Caséta Debug        Output: Ceiling (81) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nBed - Dimmer 81 - Ceiling' (68394:81)
   Lutron RRA2/Caséta              Finding devices in 'b Hall'
   Lutron RRA2/Caséta Debug        Output: underDeck (58) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: 'b Hall - Dimmer 58 - underDeck' (68394:58)
   Lutron RRA2/Caséta              Finding devices in '1 gHall'
   Lutron RRA2/Caséta Debug        Output: postOffice (78) NON_DIM
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 gHall - Switch 78 - postOffice' (68394:78)
   Lutron RRA2/Caséta Debug        Output: gHall (67) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 gHall - Dimmer 67 - gHall' (68394:67)
   Lutron RRA2/Caséta Debug        Output: fYard path (66) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 gHall - Dimmer 66 - fYard path' (68394:66)
   Lutron RRA2/Caséta Debug        Output: fYard WallWashers (65) NON_DIM
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 gHall - Switch 65 - fYard WallWashers' (68394:65)
   Lutron RRA2/Caséta              Finding devices in '2 mBath'
   Lutron RRA2/Caséta Debug        Output: Sink (51) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBath - Dimmer 51 - Sink' (68394:51)
   Lutron RRA2/Caséta Debug        Output: Shower&toilet (50) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBath - Dimmer 50 - Shower&toilet' (68394:50)
   Lutron RRA2/Caséta Debug        Output: Fan (49) NON_DIM
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBath - Switch 49 - Fan' (68394:49)
   Lutron RRA2/Caséta Debug        Device: kPd (48,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBath - kPd - Button 048.01 - High' (68394:48.1)
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBath - kPd - Button 048.01 - High LED' (68394:48.81)
   Lutron RRA2/Caséta              Finding devices in '2 nOff'
   Lutron RRA2/Caséta Debug        Output: underCabsW (85) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nOff - Dimmer 85 - underCabsW' (68394:85)
   Lutron RRA2/Caséta Debug        Output: wallWashersW (84) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nOff - Dimmer 84 - wallWashersW' (68394:84)
   Lutron RRA2/Caséta Debug        Output: CeilingW (83) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nOff - Dimmer 83 - CeilingW' (68394:83)
   Lutron RRA2/Caséta Debug        Output: wall washers (44) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nOff - Dimmer 44 - wall washers' (68394:44)
   Lutron RRA2/Caséta Debug        Output: ceiling (43) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 nOff - Dimmer 43 - ceiling' (68394:43)
   Lutron RRA2/Caséta Debug        Device: kPd (45,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta              Finding devices in '2 bBath'
   Lutron RRA2/Caséta Debug        Output: sink (40) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 bBath - Dimmer 40 - sink' (68394:40)
   Lutron RRA2/Caséta Debug        Output: tub (39) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 bBath - Dimmer 39 - tub' (68394:39)
   Lutron RRA2/Caséta Debug        Output: heat (38) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 bBath - Dimmer 38 - heat' (68394:38)
   Lutron RRA2/Caséta Debug        Output: hWtr (37) NON_DIM
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 bBath - Switch 37 - hWtr' (68394:37)
   Lutron RRA2/Caséta              Finding devices in '1 fHall'
   Lutron RRA2/Caséta Debug        Output: fHall WallWashers (59) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 fHall - Dimmer 59 - fHall WallWashers' (68394:59)
   Lutron RRA2/Caséta Debug        Output: fHall Chandelier (23) NON_DIM
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 fHall - Switch 23 - fHall Chandelier' (68394:23)
   Lutron RRA2/Caséta Debug        Device: kPd (46,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 fHall - kPd - Button 046.01 - Hall' (68394:46.1)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 fHall - kPd - Button 046.01 - Hall LED' (68394:46.81)
   Lutron RRA2/Caséta              Finding devices in '1 k'
   Lutron RRA2/Caséta Debug        Output: k Ceiling fixtures (73) NON_DIM
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 k - Switch 73 - k Ceiling fixtures' (68394:73)
   Lutron RRA2/Caséta Debug        Output: k uCab LED strips S (22) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 k - Dimmer 22 - k uCab LED strips S' (68394:22)
   Lutron RRA2/Caséta Debug        Output: Chandelier (88) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 k - Dimmer 88 - Chandelier' (68394:88)
   Lutron RRA2/Caséta Debug        Output: uCab N (79) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 k - Dimmer 79 - uCab N' (68394:79)
   Lutron RRA2/Caséta Debug        Output: Stove/Sink (76) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 k - Dimmer 76 - Stove/Sink' (68394:76)
   Lutron RRA2/Caséta Debug        Device: k uCab LED strips S (63,HYBRID_SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Device: brkfst kPd (71,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Device: kPd S (77,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta              Finding devices in '1 lRm'
   Lutron RRA2/Caséta Debug        Output: bkRmwallWashers (80) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - Dimmer 80 - bkRmwallWashers' (68394:80)
   Lutron RRA2/Caséta Debug        Output: Corners (34) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - Dimmer 34 - Corners' (68394:34)
   Lutron RRA2/Caséta Debug        Output: Seating (33) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - Dimmer 33 - Seating' (68394:33)
   Lutron RRA2/Caséta Debug        Output: Walls (32) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - Dimmer 32 - Walls' (68394:32)
   Lutron RRA2/Caséta Debug        Device: kPd (31,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - kPd - Button 031.03' (68394:31.3)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - kPd - Button 031.03 LED' (68394:31.83)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - kPd - Button 031.06 - Off' (68394:31.6)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 lRm - kPd - Button 031.06 - Off LED' (68394:31.86)
   Lutron RRA2/Caséta              Finding devices in '1 dRm'
   Lutron RRA2/Caséta Debug        Output: Door lights: K, dRm, Basement (30) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - Dimmer 30 - Door lights: K, dRm, Basement' (68394:30)
   Lutron RRA2/Caséta Debug        Output: Deck Trellis (29) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - Dimmer 29 - Deck Trellis' (68394:29)
   Lutron RRA2/Caséta Debug        Output: Corners (27) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - Dimmer 27 - Corners' (68394:27)
   Lutron RRA2/Caséta Debug        Output: Chandelier (26) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - Dimmer 26 - Chandelier' (68394:26)
   Lutron RRA2/Caséta Debug        Output: tableL-N (24) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - Dimmer 24 - tableL-N' (68394:24)
   Lutron RRA2/Caséta Debug        Device: kPd W (28,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Device: kPd N (25,HYBRID_SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - kPd N - Button 025.01 - Table' (68394:25.1)
   Lutron RRA2/Caséta Debug        Skipping existing device: '1 dRm - kPd N - Button 025.01 - Table LED' (68394:25.81)
   Lutron RRA2/Caséta              Finding devices in '2 uHall'
   Lutron RRA2/Caséta Debug        Output: stairs, uHallE (72) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 uHall - Dimmer 72 - stairs, uHallE' (68394:72)
   Lutron RRA2/Caséta Debug        Output: S ceiling (6) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 uHall - Dimmer 6 - S ceiling' (68394:6)
   Lutron RRA2/Caséta Debug        Device: kPd (56,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta              Finding devices in '2 sOff'
   Lutron RRA2/Caséta Debug        Output: Ceiling (12) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 sOff - Dimmer 12 - Ceiling' (68394:12)
   Lutron RRA2/Caséta Debug        Output: Wall Washers (11) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 sOff - Dimmer 11 - Wall Washers' (68394:11)
   Lutron RRA2/Caséta              Finding devices in '2 mBed'
   Lutron RRA2/Caséta Debug        Output: Wall washers (61) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - Dimmer 61 - Wall washers' (68394:61)
   Lutron RRA2/Caséta Debug        Output: Ceiling (60) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - Dimmer 60 - Ceiling' (68394:60)
   Lutron RRA2/Caséta Debug        Output: hHot S (42) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - Dimmer 42 - hHot S' (68394:42)
   Lutron RRA2/Caséta Debug        Output: JFH Bureau (14) INC
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - Dimmer 14 - JFH Bureau' (68394:14)
   Lutron RRA2/Caséta Debug        Device: kPd S (41,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - kPd S - Button 041.01 - Night Path' (68394:41.1)
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - kPd S - Button 041.01 - Night Path LED' (68394:41.81)
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - kPd S - Button 041.06 - hse OFF' (68394:41.6)
   Lutron RRA2/Caséta Debug        Skipping existing device: '2 mBed - kPd S - Button 041.06 - hse OFF LED' (68394:41.86)
   Lutron RRA2/Caséta Debug        Device: kPd (62,SEETOUCH_KEYPAD)
   Lutron RRA2/Caséta              Finding devices in '2 wBed'
   Lutron RRA2/Caséta Debug        Device: Enclosure Device 001 (1,MAIN_REPEATER)
   Lutron RRA2/Caséta Debug        Component: 7 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 8 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 9 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 10 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 11 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 12 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 13 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 14 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 15 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 16 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 17 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 20 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 21 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 22 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 23 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 24 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 25 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 26 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 27 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 28 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 29 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 30 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 31 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 32 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 33 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 34 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 35 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 36 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 37 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 38 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 39 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 40 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 41 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 42 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 43 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 44 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 45 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 46 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 47 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 48 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 49 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 50 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 51 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 52 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 53 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 54 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 55 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 56 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 57 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 58 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 59 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 60 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 61 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 62 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 63 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 64 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 65 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 66 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 67 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 68 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 69 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 70 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 71 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 72 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 73 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 74 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 75 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 76 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 77 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 78 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 79 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 80 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 81 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 82 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 83 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 84 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 85 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 86 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 87 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 88 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 89 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 90 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 91 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 92 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 93 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 94 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 95 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 96 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 97 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 98 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 99 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 100 (BUTTON)
   Lutron RRA2/Caséta Debug        Component: 101 (LED)
   Lutron RRA2/Caséta Debug        Component: 102 (LED)
   Lutron RRA2/Caséta Debug        Component: 103 (LED)
   Lutron RRA2/Caséta Debug        Component: 104 (LED)
   Lutron RRA2/Caséta Debug        Component: 105 (LED)
   Lutron RRA2/Caséta Debug        Component: 106 (LED)
   Lutron RRA2/Caséta Debug        Component: 107 (LED)
   Lutron RRA2/Caséta Debug        Component: 108 (LED)
   Lutron RRA2/Caséta Debug        Component: 109 (LED)
   Lutron RRA2/Caséta Debug        Component: 110 (LED)
   Lutron RRA2/Caséta Debug        Component: 111 (LED)
   Lutron RRA2/Caséta Debug        Component: 112 (LED)
   Lutron RRA2/Caséta Debug        Component: 113 (LED)
   Lutron RRA2/Caséta Debug        Component: 114 (LED)
   Lutron RRA2/Caséta Debug        Component: 115 (LED)
   Lutron RRA2/Caséta Debug        Component: 116 (LED)
   Lutron RRA2/Caséta Debug        Component: 117 (LED)
   Lutron RRA2/Caséta Debug        Component: 118 (LED)
   Lutron RRA2/Caséta Debug        Component: 119 (LED)
   Lutron RRA2/Caséta Debug        Component: 120 (LED)
   Lutron RRA2/Caséta Debug        Component: 121 (LED)
   Lutron RRA2/Caséta Debug        Component: 122 (LED)
   Lutron RRA2/Caséta Debug        Component: 123 (LED)
   Lutron RRA2/Caséta Debug        Component: 124 (LED)
   Lutron RRA2/Caséta Debug        Component: 125 (LED)
   Lutron RRA2/Caséta Debug        Component: 126 (LED)
   Lutron RRA2/Caséta Debug        Component: 127 (LED)
   Lutron RRA2/Caséta Debug        Component: 128 (LED)
   Lutron RRA2/Caséta Debug        Component: 129 (LED)
   Lutron RRA2/Caséta Debug        Component: 130 (LED)
   Lutron RRA2/Caséta Debug        Component: 131 (LED)
   Lutron RRA2/Caséta Debug        Component: 132 (LED)
   Lutron RRA2/Caséta Debug        Component: 133 (LED)
   Lutron RRA2/Caséta Debug        Component: 134 (LED)
   Lutron RRA2/Caséta Debug        Component: 135 (LED)
   Lutron RRA2/Caséta Debug        Component: 136 (LED)
   Lutron RRA2/Caséta Debug        Component: 137 (LED)
   Lutron RRA2/Caséta Debug        Component: 138 (LED)
   Lutron RRA2/Caséta Debug        Component: 139 (LED)
   Lutron RRA2/Caséta Debug        Component: 140 (LED)
   Lutron RRA2/Caséta Debug        Component: 141 (LED)
   Lutron RRA2/Caséta Debug        Component: 142 (LED)
   Lutron RRA2/Caséta Debug        Component: 143 (LED)
   Lutron RRA2/Caséta Debug        Component: 144 (LED)
   Lutron RRA2/Caséta Debug        Component: 145 (LED)
   Lutron RRA2/Caséta Debug        Component: 146 (LED)
   Lutron RRA2/Caséta Debug        Component: 147 (LED)
   Lutron RRA2/Caséta Debug        Component: 148 (LED)
   Lutron RRA2/Caséta Debug        Component: 149 (LED)
   Lutron RRA2/Caséta Debug        Component: 150 (LED)
   Lutron RRA2/Caséta Debug        Component: 151 (LED)
   Lutron RRA2/Caséta Debug        Component: 152 (LED)
   Lutron RRA2/Caséta Debug        Component: 153 (LED)
   Lutron RRA2/Caséta Debug        Component: 154 (LED)
   Lutron RRA2/Caséta Debug        Component: 155 (LED)
   Lutron RRA2/Caséta Debug        Component: 156 (LED)
   Lutron RRA2/Caséta Debug        Component: 157 (LED)
   Lutron RRA2/Caséta Debug        Component: 158 (LED)
   Lutron RRA2/Caséta Debug        Component: 159 (LED)
   Lutron RRA2/Caséta Debug        Component: 160 (LED)
   Lutron RRA2/Caséta Debug        Component: 161 (LED)
   Lutron RRA2/Caséta Debug        Component: 162 (LED)
   Lutron RRA2/Caséta Debug        Component: 163 (LED)
   Lutron RRA2/Caséta Debug        Component: 164 (LED)
   Lutron RRA2/Caséta Debug        Component: 165 (LED)
   Lutron RRA2/Caséta Debug        Component: 166 (LED)
   Lutron RRA2/Caséta Debug        Component: 167 (LED)
   Lutron RRA2/Caséta Debug        Component: 168 (LED)
   Lutron RRA2/Caséta Debug        Component: 169 (LED)
   Lutron RRA2/Caséta Debug        Component: 170 (LED)
   Lutron RRA2/Caséta Debug        Component: 171 (LED)
   Lutron RRA2/Caséta Debug        Component: 172 (LED)
   Lutron RRA2/Caséta Debug        Component: 173 (LED)
   Lutron RRA2/Caséta Debug        Component: 174 (LED)
   Lutron RRA2/Caséta Debug        Component: 175 (LED)
   Lutron RRA2/Caséta Debug        Component: 176 (LED)
   Lutron RRA2/Caséta Debug        Component: 177 (LED)
   Lutron RRA2/Caséta Debug        Component: 178 (LED)
   Lutron RRA2/Caséta Debug        Component: 179 (LED)
   Lutron RRA2/Caséta Debug        Component: 180 (LED)
   Lutron RRA2/Caséta Debug        Component: 181 (LED)
   Lutron RRA2/Caséta Debug        Component: 182 (LED)
   Lutron RRA2/Caséta Debug        Component: 183 (LED)
   Lutron RRA2/Caséta Debug        Component: 184 (LED)
   Lutron RRA2/Caséta Debug        Component: 185 (LED)
   Lutron RRA2/Caséta Debug        Component: 186 (LED)
   Lutron RRA2/Caséta Debug        Component: 187 (LED)
   Lutron RRA2/Caséta Debug        Component: 188 (LED)
   Lutron RRA2/Caséta Debug        Component: 189 (LED)
   Lutron RRA2/Caséta Debug        Component: 190 (LED)
   Lutron RRA2/Caséta Debug        Component: 191 (LED)
   Lutron RRA2/Caséta Debug        Component: 192 (LED)
   Lutron RRA2/Caséta Debug        Component: 193 (LED)
   Lutron RRA2/Caséta Debug        Component: 194 (LED)
   Lutron RRA2/Caséta Debug        Component: 195 (LED)
   Lutron RRA2/Caséta Debug        Component: 196 (LED)
   Lutron RRA2/Caséta Debug        Component: 197 (LED)
   Lutron RRA2/Caséta Debug        Component: 198 (LED)
   Lutron RRA2/Caséta Debug        Component: 199 (LED)
   Lutron RRA2/Caséta Debug        Component: 200 (LED)
   Lutron RRA2/Caséta              Finding Timeclock events...
   Lutron RRA2/Caséta              Finding HVAC devices...
   Lutron RRA2/Caséta              Creating Devices done.
Sun May 29, 2022 6:33 pm
That sure looks like it's working as expected. What devices are in that database that aren't getting created?
You can also download the database from the Lutron repeater, then compress it and send it to me. Instructions here: https://www.lutron.com/TechnicalDocumen ... on_FAQ.pdf
Sun May 29, 2022 7:02 pm
SMUSEBY offline
I tried to add 4 devices:
1) 1 k Ceiling fixtures: successful
and 3 keypads, all of which are not loading
2) in device location, 2mBdRm N, the device kPd
3) in device location, 1 kE, the device k uCab LED strips S
4) in device location bOffice/TV, the device kPd
When creating devices, I selected "group be device type", in indigo, the device folder "Lutron Keypads" is empty.
I'll load the device database and send it.
Sun May 29, 2022 7:13 pm
SMUSEBY offline
Sun May 29, 2022 7:23 pm
SMUSEBY offline
I have a zipped html file, but no matter how I rename it, the extension is not allowed, including a file named "file".
Stumped.
Sun May 29, 2022 7:26 pm
Sent PM
Mon May 30, 2022 10:50 am
Have not gotten the file yet.
I tested the device importing on my system, and it's working fine. That said, it's possible that a firmware update on the repeater has broken something. What version of Essentials/Inclusive are you running? I'm currently running 12.7.0
Mon May 30, 2022 11:50 am
gt3mike offline
I’m running 12.9 on my main repeater and I just successfully imported some recent changes. It worked fine for me.
Mon May 30, 2022 11:52 am
Thanks for the report. I guess I need to see what the changes are in the last couple versions. I mostly treat the Lutron stuff as "If it's not broke, don't fix it".
Mon May 30, 2022 11:54 am
And.... 12.10 is current. Sigh.
Mon May 30, 2022 1:00 pm
SMUSEBY offline
My version is 12.10.0.
I haven't sent the file. I can't get this Indigo system to accept an attachment. - clicking on attachment, inserting the file works, but when I click on 'add the file' it always bounces it. Is there some other way?
Mon May 30, 2022 1:04 pm
I sent you a PM.
Mon May 30, 2022 1:29 pm
SMUSEBY offline
something has gone horribly wrong. As I mentioned earlier, all the triggers for Lutron keypad buttons dropped the button reference.
Today, I've been focusing on one keypad to try to get a grip on what's happening: in Essentials, I was very careful to verify the keypad was programmed as I want it: buttons 1, 2 & 3 are path-of-light; 4, 5, & 6 are toggles.
I've done the following: Activating, Transfering in Essentials, and then in Indigo, creating devices and reloading in the plug-in - the following results in devices for this one keypad: buttons 1, 2, 3, & 6 look as I would expect them; 4 & 5 are not listed. (with the keypad Indigo address of 68394:31:n - I've used the search box, and the missing two buttons are not in devices).
These problems started yesterday when I tried to add 2 new keypads. In addition to my keypad buttons throughout the house being disabled (they were working without the buttons in the triggers - this suggests that Indigo dropped the screen references, but was able to function until I created the devices with the plug-in), there was a lot of other never-seen-before Indigo behavior that didn't involve Lutron equipment - e.g., outside christmas lights (f of var xmas=true) turning on and off repeatedly with an Indigo outlet; z-wave outlets not responding; other indigo loads turning on, and not responding to all off commands.
My overall purpose was to work toward no Insteon, devices. I was about to double down on Lutron controls, and now I'm not so sure.
Suggestions? - with Time Machine, I could restore the Indigo database, but that would restore triggers with no buttons in the display. I'm not sure that would be helpful as the problem existed before yesterday.
