Lutron main repeater disconnected
Wed Mar 23, 2022 6:18 pm
docbjr offline
Greetings!
Here is what I see. It's been a couple of days since it worked.
TIA
Mar 23, 2022 at 8:03:43 PM
   Reloading plugin "Lutron RRA2/Caséta 7.4.0"
   Stopping plugin "Lutron RRA2/Caséta 7.4.0" (pid 1064)
   Lutron RRA2/Caséta Debug       IP stop called
   Lutron RRA2/Caséta             Shutting down Lutron
   Stopped plugin "Lutron RRA2/Caséta 7.4.0"
   Starting plugin "Lutron RRA2/Caséta 7.4.0" (pid 1520)
   Lutron RRA2/Caséta Debug       logLevel = 10
   Started plugin "Lutron RRA2/Caséta 7.4.0"
   Lutron RRA2/Caséta             Starting up Lutron
   Lutron RRA2/Caséta             No linked Devices
   Lutron RRA2/Caséta             Lutron Caseta Hub: Running IP Start
   Lutron RRA2/Caséta             Lutron Caseta Hub: Connecting via IP to 192.168.200.79:23
Mar 23, 2022 at 8:04:21 PM
   Lutron RRA2/Caséta Error       Lutron Caseta Hub: Unable to connect to Lutron gateway. Timed out.
   Lutron RRA2/Caséta             Lutron Main Repeater: Running IP Start
   Lutron RRA2/Caséta             Lutron Main Repeater: Connecting via IP to 192.168.200.108:23
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: self.connIP.read: login:
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Sending username
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: self.connIP.read: password:
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Sending password
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Login process complete, connected
Mar 23, 2022 at 8:05:06 PM
   Lutron RRA2/Caséta Debug       Received a pico button status message: GNET> ~DEVICE,9,3,3
   Lutron RRA2/Caséta Debug       buttonTriggerCheck: deviceID: 9, componentID: 3, gatewayID: 1166431303
   Lutron RRA2/Caséta Error       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 1054, in runConcurrentThread
  File "plugin.py", line 159, in poll
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 430, in read_eager
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 576, in fill_rawq
error: [Errno 54] Connection reset by peer
   Lutron RRA2/Caséta Error       plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Lutron RRA2/Caséta Error       Lutron Main Repeater: EOFError: telnet connection closed
   Lutron RRA2/Caséta Debug       buttonMultiPressCheck: Timeout reached for keypadid = 1166431303:9.3, presses = 1
Wed Mar 23, 2022 6:24 pm
Re: Lutron main repeater disconnected
You have both an RRa2 repeater AND a Caseta hub?
Have you rebooted your router, switches, and then power cycled both Lutron devices?
Thu Mar 24, 2022 11:16 am
docbjr offline
Actually, I used to have a Caseta hub. I removed it from Indigo and everything seems to work again.
Thanks.
Thu Mar 24, 2022 11:20 am
What I suspect now is that some other device has the IP address that used to be assigned to the Caseta hub, and connecting to it was confusing everything.
Fri Mar 25, 2022 10:27 am
docbjr offline
Well, I spoke too soon. Still having random disconnects.
Mar 25, 2022 at 11:07:03 AM
   Stopping plugin "Lutron RRA2/Caséta 7.4.0" (pid 3062)
   Starting plugin "Lutron RRA2/Caséta 7.4.0" (pid 3190)
Mar 25, 2022 at 11:19:03 AM
   Lutron RRA2/Caséta Debug       Received a pico button status message: GNET> ~DEVICE,9,4,3
   Lutron RRA2/Caséta Debug       buttonTriggerCheck: deviceID: 9, componentID: 4, gatewayID: 1166431303
   Lutron RRA2/Caséta Debug       Received a pico button status message: ~DEVICE,9,4,4
   Lutron RRA2/Caséta Debug       Received: Dimmer Office Wall level set to 0.0
   Lutron RRA2/Caséta Debug       buttonMultiPressCheck: Timeout reached for keypadid = 1166431303:9.4, presses = 1
   Lutron RRA2/Caséta Debug       Received: Dimmer Office Ceiling level set to 0.0
   Lutron RRA2/Caséta Debug       Received a pico button status message: ~DEVICE,9,3,3
   Lutron RRA2/Caséta Debug       Received a pico button status message: ~DEVICE,9,3,4
   Lutron RRA2/Caséta Debug       Received: Dimmer Office Wall level set to 50.0
   Lutron RRA2/Caséta Debug       Received: Dimmer Office Ceiling level set to 50.0
   Trigger                         Turn on lantern
   Sent INSTEON                    "Train Lantern" on
   Lutron RRA2/Caséta Debug       Office Ceiling: actionControlDimmerRelay sending: '#OUTPUT,6,1,0' to gateway 1166431303
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Sending command: '#OUTPUT,6,1,0'
   Lutron RRA2/Caséta Warning     Lutron Main Repeater: Error sending IP command, resetting connection:
   Lutron RRA2/Caséta Debug       Office Wall: actionControlDimmerRelay sending: '#OUTPUT,7,1,0' to gateway 1166431303
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Sending command: '#OUTPUT,7,1,0'
   Lutron RRA2/Caséta Warning     Lutron Main Repeater: Error sending IP command, resetting connection:  'int' object has no attribute 'sendall'
   Sent INSTEON                    "Train Lantern" off
Mar 25, 2022 at 11:21:14 AM
   Received INSTEON                19.D9.A0 off (button 1)
Fri Mar 25, 2022 11:18 am
Can you check your logs and see what it shows just before the first error each time? In this case it's a trigger that's sending an Insteon command. I think your earlier post may have had something similar, but I edited it to remove all the non-Lutron lines, which may have been a mistake.
Something is causing the network connection between the Indigo server and the Lutron repeater to fail. It's possible the repeater is rebooting, which would be a hardware issue in it. Or a power blip.
