The upgrade started OK.
Jul 22, 2020 at 7:24:44 AM
Stopping plugin Lutron RRA2/Caséta (pid 843)
Lutron RRA2/Caséta Shutting down Lutron
Stopped plugin Lutron RRA2/Caséta
Upgrading plugin Lutron RRA2/Caséta to newer version 7.3.0 (previous version moved to trash)
Loading plugin "Lutron RRA2/Caséta 7.3.0"
Starting plugin "Lutron RRA2/Caséta 7.3.0" (pid 4093)
Started plugin "Lutron RRA2/Caséta 7.3.0"
Lutron RRA2/Caséta Starting up Lutron
Lutron RRA2/Caséta Converting to multiple gateway system
Lutron RRA2/Caséta Creating new IP Gateway device @ 192.168.0.4:23
Lutron RRA2/Caséta IP Gateway device complete
Lutron RRA2/Caséta Basement - Basement Keypad - Button 023.02 - On: Added Gateway property
Lutron RRA2/Caséta Basement - Basement Keypad - Button 023.04 - Off: Added Gateway property
Lutron RRA2/Caséta Basement - Motion Sensor 77: Added Gateway property
Lutron RRA2/Caséta Basement - Switch 71 - Basement Main Lights: Added Gateway property
Lutron RRA2/Caséta Basement - Switch 73 - Basement Perimeter Lights: Added Gateway property
(snippng pages of added gateway property messages)
Lutron RRA2/Caséta Master Closet - Dimmer 34 - Ceiling Light: Added Gateway property
Lutron RRA2/Caséta Master Closet - Motion Sensor 62: Added Gateway property
Lutron RRA2/Caséta Office Lights: Added Gateway property
Lutron RRA2/Caséta Welcome Home Button: Added Gateway property
Then this happened
Lutron RRA2/Caséta Error keypadButtonPress Trigger House Off - Exit Lights if dark (1224547049) missing buttonID: com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
componentID : 5 (string)
deviceID : 3 (string)
Lutron RRA2/Caséta Error keypadButtonPress Trigger House Off - Exit Lights if not dark (1738087678) missing buttonID: com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
Lutron RRA2/Caséta Error keypadButtonPress Trigger House Off - Master Bedroom Fan Off (425977963) missing buttonID: com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
Startup finished, and then I got an error
Lutron RRA2/Caséta Lutron IP Gateway: Running IP Start
Lutron RRA2/Caséta Lutron IP Gateway: Connecting via IP to 192.168.0.4:23
Jul 22, 2020 at 7:30:05 AM
Lutron RRA2/Caséta Error Error in plugin execution ExecuteAction:
File "plugin.py", line 1922, in sendRawCommand
KeyError: key gateway not found in dict
At this point the Indigo Client became unresponsive and began hogging CPU, so I killed it
Indigo Cocoa client disconnected
Indigo Cocoa client connected
It was still hogging CPU, so I restarted the plugin. It didn't stop smoothly, and the "missing buttonid messages are sill there.
Jul 22, 2020 at 7:35:10 AM
Disabling plugin "Lutron RRA2/Caséta 7.3.0"
Stopping plugin "Lutron RRA2/Caséta 7.3.0" (pid 4093)
Jul 22, 2020 at 7:35:25 AM
Error process (pid 4093) failed to quit after polite request -- forcing it to quit now
Stopped plugin "Lutron RRA2/Caséta 7.3.0"
Jul 22, 2020 at 7:35:44 AM
Enabling plugin "Lutron RRA2/Caséta 7.3.0"
Starting plugin "Lutron RRA2/Caséta 7.3.0" (pid 4184)
Plugin seems to be working - I tried a couple of things that would fire triggers and they worked.
Jul 22, 2020 at 7:37:59 AM
Trigger Master Bath Sink On
Trigger Master Bath Shower On
Jul 22, 2020 at 7:38:18 AM
Trigger MBR Suite Off - Fan Off
Trigger Master Bath Shower Off
Then I started getting these errors every 10 minutes. These are continuing
Jul 22, 2020 at 7:40:00 AM
Jul 22, 2020 at 7:50:00 AM
Jul 22, 2020 at 8:00:00 AM
Also just got this one. Don't know what is causing this one either.
Jul 22, 2020 at 8:00:31 AM
Lutron RRA2/Caséta Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1050, in runConcurrentThread
File "plugin.py", line 1094, in _processCommand
File "plugin.py", line 1233, in _cmdDeviceChange
IndexError: list index out of range
Lutron RRA2/Caséta Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any suggestions on any of this? Please let me know if you'd like me to log any of it in GitHub. .
