Problem with using fractions in ramp rate
Posted: Wed Dec 18, 2019 4:48 pm
I noticed a change in the plugin that I wantto ask about. The ramp rate no longer accepts fractions and only integers. I get the following error when using a ramp rate for example of 1.2:
File “plugin.py”, line 1615, in fadeDimmer
ValueError: invalid literal for int() with base 10: ‘1.2’
Is this a limitation with Lutron or new requirement in the plugin?. This was working 2 versions before.
Thank you!
Thank you!
