Polling keypad LED status
Thu Nov 21, 2019 11:57 pm
SMUSEBY offline
I would like to write a script with logic based on the status of a Lutron keypad LED.
After focusing on my Python skills as the source of the issue, I finally tested the system behavior with the following script:
indigo.device.turnOn(1017239549) # turn on LED#1
led1 = indigo.devices[1017239549] # dRm kPdW LED#1
#LOG DEVICE STATUS
indigo.device.statusRequest(1017239549)
indigo.script.sleep(15)
if led1.onState:
   indigo.server.log("15 secs led1 is on")
   indigo.server.log("15 secs led1 is off")
While the script turns on the LED, the value obtained in the event log is F.
What I learned was that changing the delay did not impact the result. What does impact the result is running the script a second time: while running the script a second time does not change the LED status, the value in the LOG is now T. I obtained the same result even when I commented out the sleep line.
Note: I also observed the same behavior with the status request following the sleep step.
Anyone else observe this? - any thoughts on how to deal with it?
Fri Nov 22, 2019 3:31 am
Re: Polling keypad LED status
This isn’t specific to the Lutron plugin.
The status request call should not be necessary. But your call to get the led1 device needs to happen after the turn on request is completed. So putting a sleep call right after the turn on command should fix it. You’ll only need 2-3 seconds at most.
Fri Nov 22, 2019 10:28 am
When you get a reference to an Indigo device:
you're getting a copy of the device (or any other Indigo object) as it stands at that instant (you really want to read the Introduction section of the IOM docs as this is probably the most important concept you need to know about Indigo objects). Any changes to the device on the server side won't automatically be reflected in the instance. You can, however, force the instance to update itself from it's current state on the server:
led1.refreshFromServer()
So you'd want to do that directly after you sleep before using led1 in the conditional tests.
