Keypad - multiple taps issue
Sat Nov 16, 2019 11:23 pm
SMUSEBY offline
I am attempting to use a keypad button to run three different scripts, each of which turns on a different audio device, as follows:
1 tap - device A
2 taps - device B
3 taps - device C
The 1 & 2 taps work as hoped; 3 taps however is controlling all three devices. Is this the design? - is there a tapping speed that is required?
Sat Nov 16, 2019 11:35 pm
The multiple tap implementation is pretty basic. If you press three times, all three triggers will fire. I didn’t want to wait for a timeout before firing the single or double triggers.
If you need to do multiple independent actions you’ll need to implement your own timeout.
I could look into alternative implementations. File a feature request.
Sun Nov 17, 2019 12:51 am
SMUSEBY offline
Re: Keypad - multiple taps issue
How does one go about filing a feature request?
Sun Nov 17, 2019 2:26 am
At the GitHub repository for the plugin. The issues tab.
Sun Nov 17, 2019 11:11 am
SMUSEBY offline
could you give me a URL hint?
Sun Nov 17, 2019 3:42 pm
There’s a link to the GitHub repo on the plugin store page for every plugin that’s hosted at GitHub.
Sun Nov 17, 2019 4:07 pm
Here is the page you want to add the issue.
