Losing IP connection
Thu Aug 22, 2019 9:27 am
rapamatic offline
For the past few weeks I seem to be pretty consistently losing the IP connection to the main repeater. When that happens it basically quietly fails - some error messages in the log, but it doesn't attempt to reconnect or do anything else. I do see error messages like this:
Aug 22, 2019 at 8:00:00 AM
   Schedule                        Inga lights off in morning
   Schedule                        Sebastian Lights off in morning
   Lutron RRA2/Caséta             Girls' Room - Dimmer 116 - Overhead: Set brightness to 0 with fade 3
   Lutron RRA2/Caséta Warning     Error sending IP command, resetting connection:  'Plugin' object has no attribute 'connIP'
   Lutron RRA2/Caséta Error       Error in plugin execution ExecuteAction:
  File "plugin.py", line 1619, in fadeDimmer
  File "plugin.py", line 843, in _sendCommand
AttributeError: 'Plugin' object has no attribute 'connIP'
  File "plugin.py", line 1509, in actionControlSpeedControl
   Lutron RRA2/Caséta             Girls - Inga Nightstand: Set brightness to 0 with fade 3
   Lutron RRA2/Caséta             Girls - Noemi Nightstand: Set brightness to 0 with fade 3
  File "plugin.py", line 1314, in actionControlDimmerRelay
Then, when I restart the plugin I get this similar error message:
   Reloading plugin "Lutron RRA2/Caséta 7.2.7"
   Stopping plugin "Lutron RRA2/Caséta 7.2.7" (pid 57391)
   Lutron RRA2/Caséta             Shutting down Lutron
   Lutron RRA2/Caséta Error       Error in plugin execution shutdown:
  File "plugin.py", line 160, in shutdown
   Stopped plugin "Lutron RRA2/Caséta 7.2.7"
Is there any way to detect the failed connection and programmatically restart the plugin from within Indigo? Alternatively, any way for the plugin to detect the connection is hosed and reconnect?
Thu Aug 22, 2019 9:34 am
Re: Losing IP connection
Turn on debug level logging and let's see if there's more info to go by.
Thu Aug 22, 2019 9:42 am
rapamatic offline
Alright, did that, will post once I get another connection drop. I wonder if its the crappy TCP/IP stack on an old Mac Pro running High Sierra?
Thu Aug 22, 2019 9:44 am
I have a Mac Pro running HS doing Security Spy and Plex and some other stuff. It seems fine. Unless you just have a hardware issue.
Thu Aug 22, 2019 11:43 am
Open terminal and run ping, let it run for a day and check for timeouts.
I had a bad Ethernet cable once That created timeouts and lost connections.
Thu Aug 22, 2019 11:52 am
rapamatic offline
I can try that, but its probably a good idea for the plugin to catch a connection going down and re-establish it, or at least to figure out a way to create a trigger in indigo to reload the plugin when that happens... Connections go down for various reasons (Ethernet cable pulled, main repeater rebooting on programming update, power outages, etc. etc.)
Thu Aug 22, 2019 11:59 am
Oh, it's supposed to be reconnecting. But I just found a stupid error in the code. When I get an error on the write to the telnet connection, I try to close the connection before I set the restart flag. And the close is failing, which aborts the routine totally. Oops.
Thu Aug 22, 2019 12:04 pm
Thu Aug 22, 2019 12:13 pm
rapamatic offline
Alright, I'm running 7.2.8 now, will see how that works.
On a side note, just running ping for na hour or two I had around 4% packet loss to my router. I am using a MoCA coax bridge up to my office where this mac is located, maybe that is a bit flaky... I do have a spare UBNT wireless bridge I can try using instead of the coax bridge... I would think TCP/IP would be robust enough to deal with 4% packet loss pretty transparently though....
Thu Aug 22, 2019 1:10 pm
My experience with MoCA is that it's extremely unreliable and not in a consistent way (works well for hours, then fails randomly for a while). Of course, that was just with a couple of TiVO boxes, so it may just be their implementation...
Thu Aug 22, 2019 2:02 pm
The 4% is not the issue if it is evenly distributed. But normally 4% indictats that there are chunks of time where it does not work. My experience was that 7seconds of no connection can create a dropped indigo client connection.
Thu Aug 22, 2019 2:56 pm
rapamatic offline
Alright, I guess it's time for me to do some testing and make sure my network is in good working order. The 4% did seem to be in chunks of 5-10 seconds without a ping, which seems enough to kill a connection
Mon Aug 26, 2019 7:17 am
rapamatic offline
FlyingDiver wrote:
7.2.8 Seems more stable... I haven't had any issues, but will keep an eye on it. Thanks!
