Losing IP connection
Posted: Thu Aug 22, 2019 9:27 am
For the past few weeks I seem to be pretty consistently losing the IP connection to the main repeater. When that happens it basically quietly fails - some error messages in the log, but it doesn't attempt to reconnect or do anything else. I do see error messages like this:
Then, when I restart the plugin I get this similar error message:
Is there any way to detect the failed connection and programmatically restart the plugin from within Indigo? Alternatively, any way for the plugin to detect the connection is hosed and reconnect?
- Code: Select all
Aug 22, 2019 at 8:00:00 AM
Schedule Inga lights off in morning
Schedule Sebastian Lights off in morning
Lutron RRA2/Caséta Girls' Room - Dimmer 116 - Overhead: Set brightness to 0 with fade 3
Lutron RRA2/Caséta Warning Error sending IP command, resetting connection: 'Plugin' object has no attribute 'connIP'
Lutron RRA2/Caséta Error Error in plugin execution ExecuteAction:
File "plugin.py", line 1619, in fadeDimmer
File "plugin.py", line 843, in _sendCommand
AttributeError: 'Plugin' object has no attribute 'connIP'
File "plugin.py", line 1509, in actionControlSpeedControl
Lutron RRA2/Caséta Girls - Inga Nightstand: Set brightness to 0 with fade 3
Lutron RRA2/Caséta Girls - Noemi Nightstand: Set brightness to 0 with fade 3
File "plugin.py", line 1314, in actionControlDimmerRelay
- Code: Select all
Reloading plugin "Lutron RRA2/Caséta 7.2.7"
Stopping plugin "Lutron RRA2/Caséta 7.2.7" (pid 57391)
Lutron RRA2/Caséta Shutting down Lutron
Lutron RRA2/Caséta Error Error in plugin execution shutdown:
File "plugin.py", line 160, in shutdown
Stopped plugin "Lutron RRA2/Caséta 7.2.7"
