Anyone using the serial connect option for Lutron?
Fri Jun 21, 2019 6:48 pm
I'm working on a version of the plugin that supports multiple independent systems. For that, I need to write conversion code that migrates from the plugin-wide configuration to a device based configuration.
For that, I need a preferences file from an install that uses serial-based communications. Anyone got one to contribute?
Fri Jun 21, 2019 7:13 pm
lalisingh offline
Re: Anyone using the serial connect option for Lutron?
where would you find a serial commuication preferences file on a radio ra 2 main repeater?
Fri Jun 21, 2019 7:25 pm
It's not on the repeater, it's the plugin preferences file. I guess I wasn't very clear about that.
It's in this folder: /Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/Plugins
This file: com.jimandnoreen.indigoplugin.lutron-radiora2.indiPref
