Just set it up. Works great. Quick question...
Thu May 23, 2019 2:26 pm
emergent offline
Re: Just set it up. Works great. Quick question...
Nevermind.
I got it working how it should.
Instead of the keypad button turning them fully on/off, I made the on button start lowering, and the off button start raising. Then a double tap on or a double tap off is set to the stop raising/lowering command. I tried that before, but since the on button was setting it to 100% and the off to 0%, the double tap wasn't doing anything.
Now it works well.
Thanks again.
Thu May 23, 2019 2:28 pm
Sounds good. Though I would suggest that "on" for a shade is fully open, and "off" would be closed. But whatever works for you....
Thu May 23, 2019 3:36 pm
emergent offline
For the Lutron shades "on/100" is fully raised and fully lowered is "off/0".
They are fully open 99% of the time when I'm home. Since the keypad light lights up when it is on, I'd rather have the light come on when the shades are down, since that's less common and it's also darker.
