Caseta setup noob question
Sun Jan 06, 2019 3:04 pm
rehafer offline
Is there a detailed instruction page for setting up caseta devices with this plugin? I have my bridge set up and a dimmer switch installed and the plugin configured (I think), When I try to setup a new device in Indigo, there are drop down choices for RadioRa devices but not Caseta. I must be missing something simple.
Also when I query devices from the plugin menu I get:
 Lutron RRA2/Caséta Debug       Sending network command:  ?OUTPUT,Overhead,1,
   Lutron RRA2/Caséta Warning     Error sending IP command, resetting connection:  'Plugin' object has no attribute 'connIP'
   Lutron RRA2/Caséta Error       Error in plugin execution ExecuteAction:
  File "plugin.py", line 1313, in actionControlDimmerRelay
  File "plugin.py", line 842, in _sendCommand
AttributeError: 'Plugin' object has no attribute 'connIP'
I'd appreciate a pointer.
Sun Jan 06, 2019 3:12 pm
Re: Caseta setup noob question
First, make sure you have the Smart Bridge Pro (L-BDGPRO2). The plugin doesn't work with the non-Pro bridge.
Then make sure you have the correct IP address for the bridge in the plugin config panel. Then restart the plugin to be sure. If there are errors in the log at that point, post them here.
The device names refer to RRA2, but that's really for historical reasons. Just pick the right device type and ignore the prefix.
Finally, the easiest way to create devices is to follow these instructions: https://github.com/FlyingDiver/Indigo-r ... on-for-Caséta-and-RRA2-Select-Systems
Sun Jan 06, 2019 10:11 pm
rehafer offline
Fixing a typo in the IP address and emailing myself the integration report got the device setup. Thanks
But, when I try to turn on the switch from Indigo, I get the error:
Lutron RRA2/Caséta Debug       Sending network command:  #OUTPUT,2,1,100
getting closer
Mon Jan 07, 2019 6:49 am
Still sounds like the plugin configuration dialog isn't set up right. Post a screen shot of it, and the log output when you restart the plugin.
Mon Jan 07, 2019 12:52 pm
rehafer offline
Double checked to IP address and resorted the mac, no change
Here is log after reloading:
Jan 7, 2019, 12:49:19 PM
   Lutron RRA2/Caséta Debug       validatePrefsConfigUi: IP Config, no changes
   Lutron RRA2/Caséta Debug       closedPrefsConfigUi: Setting self.runstartup = False
   Reloading plugin "Lutron RRA2/Caséta 7.2.3"
   Stopping plugin "Lutron RRA2/Caséta 7.2.3" (pid 1042)
   Lutron RRA2/Caséta             Shutting down Lutron
   Lutron RRA2/Caséta Error       Error in plugin execution shutdown:
  File "plugin.py", line 160, in shutdown
   Stopped plugin "Lutron RRA2/Caséta 7.2.3"
   Starting plugin "Lutron RRA2/Caséta 7.2.3" (pid 1140)
   Lutron RRA2/Caséta Debug       logLevel = 5
   Started plugin "Lutron RRA2/Caséta 7.2.3"
   Lutron RRA2/Caséta             Starting up Lutron
   Lutron RRA2/Caséta             No linked Devices
   Lutron RRA2/Caséta             Running ipStartup
   Lutron RRA2/Caséta             Connecting via IP to 192.168.7.118
Jan 7, 2019, 12:50:07 PM
   Lutron RRA2/Caséta Error       Unable to connect to Lutron gateway. Timed out.
configure screen image attached
Configure Screen.jpg (78.79 KiB) Viewed 2666 times
Mon Jan 07, 2019 12:55 pm
OK, so the connection to the Bridge is failing. I'm assuming you've triple checked that IP address. What are you using for the login info? It's NOT your Lutron account login. It should be username "lutron", password "integration". This is the Lutron default, and I'm not sure there's any way to change it.
Mon Jan 07, 2019 1:45 pm
rehafer offline
I was using my Lutron account login. Changed it restarted and I still get;
Jan 7, 2019, 1:41:47 PM
   Stopping plugin "Lutron RRA2/Caséta 7.2.3" (pid 861)
   Starting plugin "Lutron RRA2/Caséta 7.2.3" (pid 875)
Jan 7, 2019, 1:42:25 PM
   Lutron RRA2/Caséta Debug       Sending network command:  ?OUTPUT,2,1,
Control is working via Lutron app and HomeKit, don't know why the bridge won't talk to Indigo
Mon Jan 07, 2019 1:51 pm
gt3mike offline
Can you successfully ping 192.168.7.118 from a terminal session on the Mac? What about Telnet?
Mon Jan 07, 2019 1:52 pm
Well, the three things I can think of that would do this are:
  1. Not having the Pro version of the Bridge
  2. Error in IP address
  3. Error in username/password
Mon Jan 07, 2019 1:53 pm
I expect ping works, butI'm really curious about telnet.
Mon Jan 07, 2019 2:11 pm
gt3mike offline
If you don't have Telnet, you can use "nc -c" and specify the port. Here's what a session looks like with my RR2 main repeater. (Caseta Smart Bridge Pro session might look different.)
$ nc -c 192.168.0.4 23
login: lutron
password: integration
GNET> getsunset
16:49:00
GNET> logout
Mon Jan 07, 2019 4:38 pm
rehafer offline
I tried the ‘nc -c’ command and got
nc: port range not valid
Do I need to set a port somewhere?
Mon Jan 07, 2019 4:40 pm
Show your Terminal window output when you tried this.
Mon Jan 07, 2019 4:46 pm
rehafer offline
Did this:
Server-3:~ rehafer$ nc -c 192.168.7.118 login:lutron password:integration
Server-3:~ rehafer$
Mon Jan 07, 2019 4:48 pm
gt3mike offline
The syntax you are using is incorrect. Try my example above. Substitute your IP for mine and give it a shot.
You should be using "nc -c 192.168.7.118 23" by itself.
If that works, you will receive a login prompt.
