LEAP Installation questions
Fri Dec 01, 2023 5:11 pm
Re: LEAP Installation questions
You need to stop and server and actually look in the folders on the drive and delete any remnant of the plugin. From either plugin folder. There's some remnant that preventing the re-install.
Fri Dec 01, 2023 6:20 pm
tsoulen offline
Here are the folders.
Screenshot 2023-12-01 at 7.15.21 PM.png (94.23 KiB) Viewed 1828 times
Screenshot 2023-12-01 at 7.15.12 PM.png (150.82 KiB) Viewed 1828 times
Fri Dec 01, 2023 7:14 pm
If you're still having problems installing the plugin, it might be a permissions issue. Run the Indigo installer again so it can try and fix permissions. If you still have issues, post in this forum: viewforum.php?f=75
Sun Dec 03, 2023 9:57 am
tsoulen offline
My upgraded system is working perfectly. I redid my Control Pages and am having a problem. I use the Action " Toggle" so that I don't need to use two buttons to designate on and off. This works fine for my Caseta dimmer switches and my plug in modules. It is not working for any of my Caseta non-dimmer switches, the ones Leap labels "Switch (leapSwitch)". I get this in my log.
   Lutron Leap Debug               device_event: bridge_id = 591226190, device_id = 28
   Lutron Leap Debug               Exterior Floods (24): device_event: leap_data = {'device_id': '28', 'current_state': 100, 'fan_speed': None, 'tilt': None, 'zone': '15', 'name': 'Exterior_Floods', 'button_groups': None, 'occupancy_sensors': None, 'type': 'WallSwitch', 'model': 'PD-8ANS-XX', 'serial': 85702805, 'device_name': 'Floods', 'area': '9'}
   Error                           LowLevelBadParameterError -- device value type for state key onOffState must be bool
   Lutron Leap Debug               Exterior Floods (24): Switch set to 100
   Lutron Leap Debug               device_event: bridge_id = 591226190, device_id = 32
   Lutron Leap Debug               Porch and Garage (27): device_event: leap_data = {'device_id': '32', 'current_state': 100, 'fan_speed': None,
Sun Dec 03, 2023 10:01 am
That looks like a bug in the plugin. I'll take a look.
Sun Dec 03, 2023 10:07 am
What device type did the plugin create for the "Exterior Floods" switch? Better yet, right click on that device in the Indigo UI, Print the device details to the log, then post it here.
Sun Dec 03, 2023 10:10 am
Please confirm what version of the LEAP plugin you're using.
Sun Dec 03, 2023 10:13 am
Then turn it on and off using the buttons in the Indigo UI, then try your control page button again.
Sun Dec 03, 2023 11:30 am
tsoulen offline
Leap 2022.1.2
I notice the device state for those devices are incorrect as well.
Dec 3, 2023 at 12:28:29 PM
   Script                          address : 591226190:28
batteryLevel : None
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description : Floods
deviceTypeId : leapSwitch
displayStateId : onOffState
displayStateImageSel : PowerOff
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1988278595
     com.flyingdiver.indigoplugin.lutron-leap : (dict)
          address : 591226190:28 (string)
          bridge : 591226190 (integer)
          device : 28 (string)
          room : Unknown (string)
lastChanged : 2023-12-03 12:27:56
lastSuccessfulComm : 2023-12-03 12:27:56
ledStates : []
model : Switch
name : Exterior Floods (24)
onState : False
ownerProps : com.flyingdiver.indigoplugin.lutron-leap : (dict)
pluginId : com.flyingdiver.indigoplugin.lutron-leap
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     area : 9 (string)
     button_groups :  (string)
     current_state : 0 (integer)
     device_id : 28 (string)
     device_name : Floods (string)
     fan_speed :  (string)
     model : PD-8ANS-XX (string)
     occupancy_sensors :  (string)
     onOffState : 0 (integer)
     serial : 85702805 (integer)
     tilt :  (string)
     type : WallSwitch (string)
     zone : 15 (string)
subModel :
subType :
supportsAllOff : False
supportsOnState : True
supportsStatusRequest : True
version : None
   Lutron Leap Debug               Exterior Floods (24): actionControlDimmerRelay: action = actionValue : 0
configured : True
delayAmount : 900
description : turn on device
deviceAction : TurnOn
deviceId : 607189183
replaceExisting : True
textToSpeak :
configured : True
delayAmount : 900
description : turn off device
deviceAction : TurnOff
textToSpeak :
   Lutron Leap Debug               Exterior Floods (24): device_event: leap_data = {'device_id': '28', 'current_state': 0, 'fan_speed': None, 'tilt': None, 'zone': '15', 'name': 'Exterior_Floods', 'button_groups': None, 'occupancy_sensors': None, 'type': 'WallSwitch', 'model': 'PD-8ANS-XX', 'serial': 85702805, 'device_name': 'Floods', 'area': '9'}
   Lutron Leap Debug               Exterior Floods (24): Switch set to 0
Sun Dec 03, 2023 11:40 am
I can't reproduce the error. Try deleting that device and re-running the menu command that creates the devices. You'll need to edit your control page to reference the new device.
Sun Dec 03, 2023 12:13 pm
tsoulen offline
Did that. Here is the log from turning it on off from the Indigo interface and from my control page.
Dec 3, 2023 at 1:12:59 PM
   Lutron Leap Debug               Exterior_Floods (28): actionControlDimmerRelay: action = actionValue : 0
configured : True
delayAmount : 900
deviceId : 80468622
textToSpeak :
   Lutron Leap Debug               Exterior_Floods (28): device_event: leap_data = {'device_id': '28', 'current_state': 100, 'fan_speed': None, 'tilt': None, 'zone': '15', 'name': 'Exterior_Floods', 'button_groups': None, 'occupancy_sensors': None, 'type': 'WallSwitch', 'model': 'PD-8ANS-XX', 'serial': 85702805, 'device_name': 'Floods', 'area': '9'}
   Lutron Leap Debug               Exterior_Floods (28): Switch set to 100
configured : True
delayAmount : 900
deviceId : 80468622
textToSpeak :
   Lutron Leap Debug               Exterior_Floods (28): device_event: leap_data = {'device_id': '28', 'current_state': 0, 'fan_speed': None, 'tilt': None, 'zone': '15', 'name': 'Exterior_Floods', 'button_groups': None, 'occupancy_sensors': None, 'type': 'WallSwitch', 'model': 'PD-8ANS-XX', 'serial': 85702805, 'device_name': 'Floods', 'area': '9'}
   Lutron Leap Debug               Exterior_Floods (28): Switch set to 0
   Lutron Leap Debug               Exterior_Door and Garage (32): actionControlDimmerRelay: action = actionValue : 0
configured : True
delayAmount : 900
description : toggle device
deviceAction : Toggle
deviceId : 868318114
textToSpeak :
configured : True
delayAmount : 900
deviceId : 80468622
textToSpeak :
   Lutron Leap Debug               Exterior_Door and Garage (32): device_event: leap_data = {'device_id': '32', 'current_state': 100, 'fan_speed': None, 'tilt': None, 'zone': '17', 'name': 'Exterior_Door and Garage', 'button_groups': None, 'occupancy_sensors': None, 'type': 'WallSwitch', 'model': 'PD-8ANS-XX', 'serial': 85702826, 'device_name': 'Door and Garage', 'area': '9'}
   Lutron Leap Debug               Exterior_Door and Garage (32): Switch set to 100
configured : True
delayAmount : 900
textToSpeak :
configured : True
delayAmount : 900
deviceId : 80468622
textToSpeak :
Sun Dec 03, 2023 12:17 pm
tsoulen offline
My control page button for the floods also turns off the porch lights. I redid that one too, since it's the same type of switch and also wasn't working.
Sun Dec 03, 2023 12:28 pm
What happens when you use the Indigo UI to turn the device on and off? Do you get errors for either one?
Sun Dec 03, 2023 12:31 pm
tsoulen offline
Dec 3, 2023 at 1:31:16 PM
configured : True
delayAmount : 900
deviceId : 80468622
textToSpeak :
configured : True
delayAmount : 900
deviceId : 80468622
textToSpeak :
Sun Dec 03, 2023 12:32 pm
tsoulen offline
It works, but I get this in the log for all the switches that aren't dimmers.
