Elgato Stream Deck plugin - early test release
Sun May 10, 2020 7:32 pm
Hap offline
Re: Elgato Stream Deck plugin - early test release
Thanks Joe, let me know what I can do to test.
Mon May 11, 2020 8:26 am
Totally my mistake. Rookie network programming error. Fixed in 0.0.2 - https://github.com/FlyingDiver/indigo-s ... /tag/0.0.2
You only need to update the Indigo plugin. No changes on the Stream Deck side.
Mon May 11, 2020 11:36 am
Hap offline
Thanks. It's working now :D
Very first connection was very slow. It showed a connection twice, nothing happened. Punched the button several times and all the sudden I got a flood of messages in the log. Ever since then, it's been responsive and reliable across 10 cycles.
Mon May 11, 2020 11:46 am
Yeah, there's some delays while it gets the connection info and sets up the web socket, plus collecting data about the deck and the buttons.
Which actions have you tried?
Mon May 11, 2020 11:50 am
Hap offline
Only the action group as that was what I was using with my ad-hoc setup using RESTful. I'll play around with it more tonight after work.
If there is anything specific you would like me to test, just let me know. I'll also test with multiple Stream Decks/Systems.
Mon May 11, 2020 2:31 pm
Hap offline
Tested from a different StreamDeck on a Windows System. Worked fine. I'll play around with the other types tonight.
Mon May 11, 2020 2:34 pm
The trick is going to be communication from the Indigo system back to the Stream Deck controller. Keeping track of which socket connection each deck is on is complicated.
So you tested one deck on two different systems? OK, good. When you get a chance, put two decks on the same system.
Mon May 11, 2020 5:27 pm
Hap offline
The Mac has two and the PC has three. Are you wanting me to test from two StreamDecks on the same Mac simultaneously?
Mon May 11, 2020 5:56 pm
As many as you have. ;)
Mon May 11, 2020 6:49 pm
Hap offline
Windows PC:
2 x Stream Decks
1 x Stream Deck XL
- Tested Action Button functionality on two of the Stream Decks - Pass
Mac
1 x Stream Deck
1 x Stream Deck XL
Tests:
- Action Group (same device) on both Stream Decks, both would Toggle the Action one after another - Pass
- Momentary on XL - Pass
- Variable on XL - Pass
- Device Toggle on XL- Pass
If there is any additional pattern you want me to test, just ask. I didn't run very many from the PC, but I can if you want me to.
Mon May 11, 2020 6:51 pm
That's good for now. Next major update will be to include stuff going the other way. Like changing profiles or updating the Label on a button. Then comes sending new images over.
Thu May 14, 2020 4:03 pm
Well, turns out that changing profiles is a no-go. There's an API call to do so, but it only allows for selecting pre-built profiles provided by the plugin. That's for doing "full screen" interfaces. Which doesn't apply here. And I had the code all working for that, and then found out it wasn't supposed to work. :(
So commands from the Screen Deck to Indigo seem to be working just fine. If there are additional variants that I didn't implement, just let me know.
What's next on the request list? I'm thinking that I should be able to send button icons from Indigo to the Stream Deck. Would that be useful? Anyone want to donate some interesting icons for development purposes? I need 20x20 and 40x40 variants.
Anything else?
Fri May 15, 2020 3:42 pm
Hap offline
I would really like to get status on some of the buttons. Like garage door open/close. Or data from some of the sensors (I have an Z-wave sensor in my wiring closet because the A/C is flakey). I do use Pushover for over limit, but would be nice to have a button change color based on status.
For the garage doors, maybe Red when Open, Blue when Closed (I'm color blind so Red/Green tends not to work well)? Pushing the button toggles the door open/closed.
Just some ideas.
On the icons - I'm the worlds worst artist, I can pull stuff together from various sources, but if it takes creativity - forget it. Sorry.
Fri May 15, 2020 4:01 pm
That's me.
OK, I'll work on getting the buttons to show different icons depending on the on/off status of a linked sensor device. That should handle the cases you mentioned. The specific colors/icons will be determined later. ;)
Wed Nov 18, 2020 12:57 am
koensayr offline
Well shoot. I've stumbled upon this and now I finally have an excuse to get a Stream Deck it seems!
Thank you!
With all of the work you do on Indigo, you truely make it really valuable. If you have a GoFundMe page or something similar, I'll be first in line to donate or send you something nice
