New Plugin - BMW Connected Drive
Sun May 10, 2020 6:00 am
Re: New Plugin - BMW Connected Drive
It's on my to-do list, but I want to get the first version of my new Stream Deck plugin out first.
Maybe you could file an enhancement request on GitHub to keep me reminded?
Sun May 10, 2020 6:14 am
Turribeach offline
I am interested in actions too, I keep refining the script I posted and it already saved me from leaving the car open one day. I went to store some supermarket bags in the boot and I got distracted so I forgot to lock it. Clearly not using the car as much makes me forget simple things like locking it. Once I am happy with my script it's not providing any false alters I will move to the next stage which is to trigger the action to lock the car automatically when the alert is detected.
Sun May 10, 2020 6:22 am
Turribeach offline
Issue 3 raised but I don't believe I can label it as I don't have write access to the repo.
Sun Jun 07, 2020 7:39 pm
ryanbuckner offline
FlyingDiver wrote:
ryanbuckner wrote:
Sierra 10.12.6
It had been working fine up until today. I tested my credentials on the website and they passed.
You're running into the SSL/TLS issue. They must have just upgraded their servers.
   BMW Connected Drive Error       get_tokens AUTH Error, exception = [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
The only fix is to upgrade to at least High Sierra.
Found some time to update to Catalina and the plugin is working again !
Sat Sep 26, 2020 7:58 pm
HEGarrard offline
BMW Connected Drive Plugin
I am trying to use some of the information in the BMW Connected Drive to use in Triggers.
Specifically I was wanting to use the Fuel Percent or Remaining Fuel "Devices" and use the Device State to populate a couple of variables.
The devices I have setup are shown below ...
If I use the python script ...
MyVar = indigo.devices[410812393] # This is the Connected Vehicle Device with Fuel Percent
indigo.variable.updateValue(1572747575, value=str(MyVar))
The variable is updated with the device address and not the "state" 38.5%
Variable List.jpg (31.95 KiB) Viewed 26852 times
I tried using .value or .state to get the "state" of the device - however, neither of those two worked.
My next attempt was using the following python script ...
bmw = indigo.devices[1387282993] # This is the Connected Account Device
FuelPercent = bmw.states["fuelPercent"]
indigo.variable.updateValue(1572747575, value=str(FuelPercent))
If I run this script I get an error ...
Script Error 1.jpg (48.67 KiB) Viewed 26852 times
bmw = indigo.devices[410812393] # This is the Connected Vehicle Device with Fuel Percent
If I run this script ... I get the same error as above.
This is the "Vehicle Data to Log"
Vehicle Data to Log.jpg (233.06 KiB) Viewed 26852 times
Any suggestions on how to get the values for the BMW Connected Drive Devices as defined in my device list and write them to variables????
Thank you!
Sat Sep 26, 2020 8:11 pm
Re: BMW Connected Drive Plugin
You're making this much harder than it actually is. And some bad assumptions. You don't need all those different vehicles devices. You only need one. The choice of status value is purely to give a choice in the Indigo UI. You need to look at the complete list of available states to see the names.
Screen Shot 2020-09-26 at 10.02.02 PM.png (823.32 KiB) Viewed 26845 times
And you don't need a script to put a device state into a variable.
Screen Shot 2020-09-26 at 10.10.10 PM.png (471.34 KiB) Viewed 26845 times
Sat Sep 26, 2020 8:12 pm
The states starting with "s_" are in the "status" data from the BMW servers. The "v_" states are from the "vehicle" data. Vehicle data is static, I think, what status data is dynamic.
Sat Sep 26, 2020 8:15 pm
HEGarrard offline
Thank you very much for the quick reply!
I saw a thread that used something similar to the s_fuelPercent ... I just did not know how to get it!
Thanks again!
Wed Oct 28, 2020 7:41 am
macpro offline
You can rename this plugin to "BMW/Mini Connected Drive". :D
Tue Nov 17, 2020 2:31 am
Turribeach offline
Started to get error 400 when trying to authenticate. Something changed on the BMW side? :? :(
   Reloading plugin "BMW Connected Drive 0.0.6"
   Stopping plugin "BMW Connected Drive 0.0.6" (pid 863)
   BMW Connected Drive Debug       runConcurrentThread ending
   BMW Connected Drive             BMW Connected Drive Account: Stopping cdAccount Device xxxxxx
   BMW Connected Drive             BMW X1: Stopping cdVehicle Device xxxxxxx
   BMW Connected Drive             Stopping Connected Drive
   Stopped plugin "BMW Connected Drive 0.0.6"
   Starting plugin "BMW Connected Drive 0.0.6" (pid 50532)
   BMW Connected Drive Debug       logLevel = 10
   Started plugin "BMW Connected Drive 0.0.6"
   BMW Connected Drive             Starting Connected Drive
   BMW Connected Drive Debug       updateFrequency = 300.0
   BMW Connected Drive             BMW Connected Drive Account: Starting cdAccount Device
   BMW Connected Drive Error       get_tokens AUTH call failed, response code = 400
   BMW Connected Drive             BMW X1: Starting cdVehicle Device
   BMW Connected Drive Debug       runConcurrentThread starting
   BMW Connected Drive Debug       ConnectedDrive account xxxxxxx not authenticated, skipping update
   BMW Connected Drive Debug       ConnectedDrive get_vehicle_data: xxxxxxxx
   BMW Connected Drive Error       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 140, in runConcurrentThread
  File "plugin.py", line 177, in updateVehicle
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bmwcdapi.py", line 149, in get_vehicle_data
TypeError: 'NoneType' object has no attribute '__getitem__'
Tue Nov 17, 2020 5:15 am
Fri Nov 20, 2020 5:37 am
tomet offline
Hi Flyingdiver,
I use a few of your plugins and love them. Thank you.
Just reporting that I am seeing the same thing here with the 400 error and NoneType issue in Australia. Seems to have started around the 19th of this month +/- a few days.
Cheers
Tom
Fri Nov 20, 2020 7:52 am
I have not had time to look into the issue this week. I will as soon as I can.
Fri Nov 20, 2020 4:21 pm
Release 0.0.7 is on the plugin store.
Fri Nov 20, 2020 11:43 pm
tomet offline
Thanks mate. Worked perfectly.
Page 5 of 12 1, 2, 3, 4, 5, 6, 7, 8 ... 12
