Masquerade Plugin
Mon Jun 03, 2019 7:29 am
Re: Masquerade Plugin
kw123 wrote:
You have 590 ppm co2 in a bed room?
Seems normal per: https://www.kane.co.uk/knowledge-centre ... 2-in-rooms
Now if that was CO, it would be really bad.
Mon Jun 03, 2019 7:41 am
Try https://github.com/FlyingDiver/Indigo-M ... /tag/0.1.6
And thank you for filing a GitHub issue to document this.
Sat Jul 27, 2019 11:00 am
srkinard offline
Would you consider adding a way to masquerade a true/false device from and AD2USB/AD2PI plugin (basically alarm zone status) to an Indigo Door device?
I'd like to eventually have the faulted alarm zones reflect as open or closed doors.
Ross
Sat Jul 27, 2019 11:03 am
Indigo doesn't have a door type. Closest is a lock device.
Mon Jul 06, 2020 11:32 am
shapa offline
Just a cosmetic request
Could you please add "energy" (watt) type of the sensor?
Mon Jul 06, 2020 11:34 am
Can you put that in GitHub so I don't forget?
https://github.com/FlyingDiver/Indigo-Masquerade/issues
Thu Dec 17, 2020 4:52 pm
agame offline
Any thoughts on adding ability to masquerade a relay as a sprinkler zone?
It this were possible it would enable, for example, a, z-wave relay controlling a pump to be grouped as with its associated valves.
Thu Dec 17, 2020 4:53 pm
Never thought of it. Put in an GitHub issue and I'll take a look.
Thu Dec 17, 2020 5:08 pm
agame offline
shall do!
Fri Dec 18, 2020 9:28 am
Release 0.2.0 on the plugin store now.
Sat Dec 19, 2020 6:29 pm
agame offline
amazing, thank you!
I can successfully masquerade any relay as a sprinkler, and I can see the states on the both devices updating correctly regardless of which I use to switch.
They are also working when rolled up into a Sprinkler Group virtual device.
One small anomaly is that - while device states on the parent relay and the virtual sprinkler update correctly when controlling via the Sprinkler Group, this doesn't happen in the other direction (ie, the Sprinkler Group shows 'all zones off' even if one of its constituent sprinklers is switched independently). I don't have the native sprinkler zones to test if this is an indigo 'feature', but I assume not(?).
Sat Dec 19, 2020 7:11 pm
I have no idea. I've never used a Sprinkler Group. Maybe Matt or Jay can come in.
Sat Dec 19, 2020 7:45 pm
agame offline
for clarity, this is the case regardless of whether I switch the sprinkler zone; or the 'parent' relay....the Sprinkler Group state doesn't change. Turning the Sprinkler Group on and Off will realign all the states correctly.
Sun Dec 20, 2020 1:30 pm
The Sprinkler Group indeed assumes that all control will be done via Sprinkler Group device and not on the individual component devices. That is, it is not bidirectional in its state updates. In Indigo Sprinkler devices (currently) always have mutually exclusive zones, so the sprinkler device wouldn't know what to show or how to handle multiple sub-devices being ON at the same time.
Sun Dec 20, 2020 3:56 pm
agame offline
thanks for the clarification.
Regarding the UI challenge I guess the Sprinkler Group UI could be tweaked to show a string of open zone numbers, rather than zone name, or even just 'on' in the case of multiple zones open.
But I can use a Device Group to represent collective status of the relays anyhow.
[I have occasions (very hot/fire danger days) for which I need to retain direct control of zones, including the ability to have some operate simultaneously].
Page 6 of 8 1 ... 3, 4, 5, 6, 7, 8
