New Plugin - BMW Connected Drive
Sat May 29, 2021 3:51 pm
ryanbuckner offline
Re: New Plugin - BMW Connected Drive
Is there a way to access the timestamp for the last time the connected API call was made? I think this is different than the device states like internalDataTimeUTC which only update when data changes.
Sat May 29, 2021 4:03 pm
It's not available as a state, but it is a property of the account device (all updates are managed through the account device).
acct = indigo.devices[ID OF ACCOUNT DEVICE]
last_update = acct.lastChanged
That gives a string time stamp.
Sat May 29, 2021 5:02 pm
ryanbuckner offline
Perfect, thanks. I feel it's easier to trigger my checks from this value changing since there doesn't appear to be a way to Trigger off any state change for a device.
Tue Jun 01, 2021 12:57 am
macpro offline
Question: is it possible to get the tire pressure from all tires?
Our Mini is complaining about a low tire pressure, but the Mini Connected app doesn't show the tire pressure.
Tue Jun 01, 2021 5:46 am
I don't see tire pressure in the data for my BMW. You can check to be sure by using the menu command "Write Vehicle Data to Log".
Tue Jun 01, 2021 5:51 am
macpro offline
Thanks. It's not there.
Sat Aug 07, 2021 4:29 am
macpro offline
The 400 error is back. :(
7 Aug 2021 at 12:21:45
   BMW Connected Drive Error       get_tokens AUTH call failed, response code = 400
   BMW Connected Drive Error       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 140, in runConcurrentThread
  File "plugin.py", line 177, in updateVehicle
  File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bmwcdapi.py", line 179, in get_vehicle_data
TypeError: 'NoneType' object has no attribute '__getitem__'
   BMW Connected Drive Error       plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sat Aug 07, 2021 5:54 am
neilk offline
I suspect BMW have changed the authentication in the API, people with connected EV chargers reporting similar issues failing to connect to the API to get state of charge of the car.
Sat Aug 07, 2021 8:13 am
Yeah, BMW broke this if and when the Python library I use for this is updated to address the issue, then I'll update the plugin. Until then it's dead.
Sat Aug 07, 2021 8:20 am
Looks like you're using an older version of the plugin that was using the old Python 2 library. That one will never be updated, the author has discontinued it. The more recent versions of the plugin use a Python 3 library, but it's also having an issue due to BMW changes. If/when this gets fixes, it'll be the new Python 3 version only.
Sat Aug 07, 2021 9:17 am
macpro offline
That's the 0.0.7 version of the plugin from the PluginStore. Made by... FlyingDiver.
Sat Aug 07, 2021 9:20 am
It's still an old version. There's multiple 1.0.X pre-release versions based on the new library. In any case, when and if this is fixed, it will only be in the 1.X version.
Sat Aug 07, 2021 9:26 am
macpro offline
I see. But if there is a newer version (which I just found on Github), why is the old version still in the Plugin Store? And why is the new version only available on Github?
That's a bit confusing.
Sat Aug 07, 2021 9:27 am
Because it's a total re-write of the plugin and I was working with beta testers to iron out some issues. There are posts in this thread about testing the new version.
Sat Aug 07, 2021 9:48 am
macpro offline
Ok. Haven’t read the whole thread, so didn’t know that. Thanks for explaining.
