New Plugin - BMW Connected Drive
Wed Apr 14, 2021 9:31 am
ryanbuckner offline
Re: New Plugin - BMW Connected Drive
Last login: Wed Apr 14 11:08:05 on ttys000
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
HomeAutonServer:~ ryanbuckner$ /usr/bin/python3 --version
Python 3.8.2
Wed Apr 14, 2021 9:35 am
Darn. That looks right. Something must be getting messed up in the venv when copying it to another machine. I'm going to have to look into that.
Thu Apr 15, 2021 1:10 pm
Here's the current status:
The newest branch of the plugin tries to include a Python virtual environment as part of the plugin package, so that users don't need to install a bunch of additional libraries manually. Turns out that copying the venv files to another computer as part of the plugin install breaks it. So until I figure out a way to fix that, we'll have to go back to the older method which DOES require all the additional libraries.
Actions aren't working for me at all, and I'm not sure if it's a problem with the library, with BMW's servers, or what. At my house, I can't even use the mobile app to run any remote services. I don't know what mobile service BMW is using, but it doesn't work here. When I went to the grocery store earlier today, I WAS able to use the remote services from my phone. So I set up action groups I can activate with Indigo touch, and next time I'm somewhere the mobile app works, I'll try those to execute actions from Indigo.
Do any of the testers have the Python 3 version (not the venv branch) working?
Thu Apr 15, 2021 2:08 pm
OK, I think I got the venv thing fixed. Please try: https://github.com/FlyingDiver/Indigo-B ... /tag/1.0.3
Sat Apr 17, 2021 1:48 pm
ryanbuckner offline
Everything worked great. Didn't get to try ventilate because I got a Too Many Requests error. I did have to send Unlock 3 times to unlock all the doors. First attempt unlocked driver side. Second did nothing. Third unlocked all.
Starting shell for plugin BMW ConnectedDrive.indigoPlugin.
To access the plugin instance use the global named self.
Python 2.7.16 (default, Jun  5 2020, 22:59:21)
[GCC 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.29.20) (-macos10.15-objc-
Connected to Indigo Server v7.5.0, api v2.4 (localhost:1176)
Started Plugin BMW Connected Drive v1.0.2
>>> Traceback (most recent call last):
  File "./wrapper.py", line 103, in <module>
    asyncio.run(main(sys.argv))
  File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/asyncio/runners.py", line 43, in run
    return loop.run_until_complete(main)
  File "/Applications/Xcode.app/Contents/Developer/Library/Frameworks/Python3.framework/Versions/3.8/lib/python3.8/asyncio/base_events.py", line 616, in run_until_complete
    return future.result()
  File "./wrapper.py", line 76, in main
    status = vehicle.remote_services.trigger_remote_door_unlock()
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bimmer_connected/remote_services.py", line 174, in trigger_remote_door_unlock
    result = self._block_until_done(_Services.REMOTE_DOOR_UNLOCK)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bimmer_connected/remote_services.py", line 217, in _block_until_done
    status = self._get_remote_service_status(service)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bimmer_connected/remote_services.py", line 237, in _get_remote_service_status
    response = self._account.send_request(url)
  File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bimmer_connected/account.py", line 156, in send_request
    raise IOError(msg)
OSError: The BMW Connected Drive portal returned an error: TOO_MANY_REQUESTS (received status code 429 and expected 200).
Sat Apr 17, 2021 1:50 pm
The too many requests is a bug in the library, IMO. It retries too many times and then the server errors out. I'm going to trap that error so that it doesn't kill the process.
Sat Apr 17, 2021 2:19 pm
Try this one: https://github.com/FlyingDiver/Indigo-B ... /tag/1.0.4
It should handle those library retry errors a little better.
Sat Apr 17, 2021 3:56 pm
ryanbuckner offline
1.0.4 seems to be pretty stable. I'll keep playing with it
Sat Apr 17, 2021 5:41 pm
ryanbuckner offline
Just noticed that the status of the BMW turned to "plugin stopped" and this in the event log:
The Account device is also in error.
   BMW Connected Drive Error       BMW Account: [u'The BMW Connected Drive portal returned an error: TOO_MANY_REQUESTS (received status code 429 and expected 200).']
I haven't sent any commands. This is just from updates.
Sat Apr 17, 2021 6:02 pm
Are the updates still working? IOW, is the plugin actually stopped or is it just the status that's wrong?
Sat Apr 17, 2021 7:54 pm
ryanbuckner offline
Updates completely stopped. I get the error every 5 minutes now. and the only device attribute is status = UNLOCKED which is the key I chose in plugin preferences.
Sat Apr 17, 2021 7:56 pm
Disable the plugin so it stops attempting to update. Then re-enable it tomorrow and see how long it works.
Sun Apr 18, 2021 9:38 am
ryanbuckner offline
so far it's working today. I haven't tried sending commands tho
Sun Apr 18, 2021 9:40 am
I think you got locked out because of the too many retries error. I'm working on fixes for that now.
Sun Apr 18, 2021 4:21 pm
ryanbuckner offline
Added a fun section to my control page dashboard.
BMW Control.png (123.51 KiB) Viewed 26694 times
