Jul 4, 2022 at 11:43:13 AM
Installing and enabling plugin Alarm.com v2022.0.0
Loading plugin "Alarm.com 2022.0.0" using API v3.1
Starting plugin "Alarm.com 2022.0.0" (pid 99042)
Reloading plugin "Web Server 2022.1.1" using API v2.5
Stopping plugin "Web Server 2022.1.1" (pid 18722)
Web Server Stopping Indigo Web Server...
Alarm.com Error Error in plugin execution InitializeMain:
File "plugin.py", line 10, in <module>
type: No module named 'aiofiles'
Stopping plugin "Alarm.com 2022.0.0" (pid 99042)
Stopped plugin "Alarm.com 2022.0.0"
pip3 install pyalarmdotcomajax aiohttp aiofiles
Alarm.com Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 247, in get_partition_list
type: local variable 'partitions' referenced before assignment
Alarm.com Debug LogLevel = 5
Alarm.com Debug updateFrequency = 300.0
Reloading plugin "Alarm.com 2022.0.1" using API v3.1
Stopping plugin "Alarm.com 2022.0.1" (pid 1385)
Alarm.com Debug stop_concurrent_thread called
Stopped plugin "Alarm.com 2022.0.1"
Starting plugin "Alarm.com 2022.0.1" (pid 7725)
Started plugin "Alarm.com 2022.0.1"
Alarm.com Debug startup
Alarm.com Debug run_async_thread starting
Alarm.com Debug startup complete
Alarm.com Debug async_main starting
Alarm.com Alarm.com authentication successful
Alarm.com Debug Alarm.com Provider: Strada Security
[Removed email address here]
Alarm.com Debug async_system_refresh_loop: starting
Alarm.com Debug Systems (1)
Alarm.com Debug Name: House, id_: 2650920, unit_id: None
Alarm.com Debug Partitions (1)
Alarm.com Debug Name: Panel (92613667-127), State: DeviceState.DISARMED, System: 2650920
Alarm.com Debug Sensors (12)
Alarm.com Debug Name: Dining Room (92613667-4), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Front BR (92613667-5), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Front Door (92613667-12), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Garage Door (92613667-1), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Glass break (92613667-11), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: MBath (92613667-7), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: MBR 1 (92613667-9), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: MBR 2 (92613667-10), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Motion (2) (92613667-2), State: DeviceState.ACTIVE, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Office (92613667-6), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Sliders (92613667-3), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug Name: Smoke/Heat (8) (92613667-8), State: DeviceState.CLOSED, System: 2650920, Partition: 92613667-127
Alarm.com Debug known_systems: {'2650920': <pyalarmdotcomajax.devices.System object at 0x106788af0>}
Alarm.com Debug known_partitions: {'2650920': {'92613667-127': <pyalarmdotcomajax.devices.Partition object at 0x106a09870>}}
Alarm.com Debug known_sensors: {'2650920': {'92613667-127': {'92613667-4': <pyalarmdotcomajax.devices.Sensor object at 0x106a0b9a0>, '92613667-5': <pyalarmdotcomajax.devices.Sensor object at 0x106a09810>, '92613667-12': <pyalarmdotcomajax.devices.Sensor object at 0x106a092d0>, '92613667-1': <pyalarmdotcomajax.devices.Sensor object at 0x106a096f0>, '92613667-11': <pyalarmdotcomajax.devices.Sensor object at 0x106a099c0>, '92613667-7': <pyalarmdotcomajax.devices.Sensor object at 0x106a0bb20>, '92613667-9': <pyalarmdotcomajax.devices.Sensor object at 0x106a09720>, '92613667-10': <pyalarmdotcomajax.devices.Sensor object at 0x106a098a0>, '92613667-2': <pyalarmdotcomajax.devices.Sensor object at 0x106a09780>, '92613667-6': <pyalarmdotcomajax.devices.Sensor object at 0x106a097b0>, '92613667-3': <pyalarmdotcomajax.devices.Sensor object at 0x106a09750>, '92613667-8': <pyalarmdotcomajax.devices.Sensor object at 0x106a096c0>}}}
Alarm.com Debug active_systems: {}
Alarm.com Debug active_partitions: {}
Alarm.com Debug active_sensors: {}
Alarm.com Debug async_system_refresh_loop: starting timer for 300.0 seconds
