Davis WeatherLink-Vantage Vue Wind Direction?
Sat Apr 17, 2021 9:43 am
ckeyes888 offline
Found a Vantage Vue bundled with a WeatherLink on eBay for $344 so I went for it.
Got it working fine with your excellent plugin but am hoping you could add a text, e.g. WNW, wind direction state?
I see there is an integer state but not too useful, for me anyway.
Carl
Sat Apr 17, 2021 10:28 am
Re: Davis WeatherLink-Vantage Vue Wind Direction?
Sorry, no. The plugin doesn't do any transformations of the data reported by the weather station, and I really don't want to start now. I would recommend that you set a trigger on any change to the wind direction state you want, and run a Python script that sets a variable with the direction text. That way you can set the text exactly the way you want. Something like:
wind_dir_last = indigo.devices[623595257].states["wind_dir_last"]
wind_dir_var = indigo.variables[1550780091] # "WindDir"
if wind_dir_last > 338 or wind_dir_last < 22:
   dir = "North"
elif wind_dir_last > 22 and wind_dir_last < 67:
   dir = "Northeast"
elif wind_dir_last > 67 and wind_dir_last < 112:
   dir = "East"
elif wind_dir_last > 112 and wind_dir_last < 157:
   dir = "Southeast"
elif wind_dir_last > 157 and wind_dir_last < 202:
   dir = "South"
elif wind_dir_last > 202 and wind_dir_last < 247:
   dir = "Southwest"
elif wind_dir_last > 247 and wind_dir_last < 292:
   dir = "West"
elif wind_dir_last > 292 and wind_dir_last < 338:
   dir = "Northwest"
indigo.variable.updateValue(wind_dir_var, dir)
Sat Apr 17, 2021 12:09 pm
ckeyes888 offline
Perfect! Thanks a bunch!
Carl
Sat Apr 17, 2021 2:01 pm
ckeyes888 offline
Decided to trigger the script from a variable but can't seem to make it work.
wind_number = indigo.variables[1377125246] # "Wind_Dir_Number"
wind_text = indigo.variables[1567274241] # "Wind_Dir_Text"
if wind_number > 338 or wind_dir_last < 22:
   dir = "North"
elif wind_number > 22 and wind_dir_last < 67:
   dir = "Northeast"
elif wind_number > 67 and wind_dir_last < 112:
   dir = "East"
elif wind_number > 112 and wind_dir_last < 157:
   dir = "Southeast"
elif wind_number > 157 and wind_dir_last < 202:
   dir = "South"
elif wind_number > 202 and wind_dir_last < 247:
   dir = "Southwest"
elif wind_number > 247 and wind_dir_last < 292:
   dir = "West"
elif wind_number > 292 and wind_dir_last < 338:
   dir = "Northwest"
indigo.variable.updateValue(wind_text, dir)
Any idea why this won't work?
Carl
Sat Apr 17, 2021 2:04 pm
So you're copying the state value into a variable with a different trigger?
You're trying to reference the Indigo variable object directly. You need to get the integer value of it instead.
wind_number = indigo.variables[1377125246].intValue().   # "Wind_Dir_Number"
Sat Apr 17, 2021 2:22 pm
ckeyes888 offline
Now getting "Invalid syntax"
   dir = "North"
   dir = "Northeast"
   dir = "East"
   dir = "Southeast"
   dir = "South"
   dir = "Southwest"
   dir = "West"
   dir = "Northwest"
Carl
Sat Apr 17, 2021 2:24 pm
Remove that trailing period after .intValue()
Sat Apr 17, 2021 2:28 pm
ckeyes888 offline
Now get, 'Variable object has no attribute "IntValue"
Sat Apr 17, 2021 2:29 pm
Do you actually have that I in caps?
Sat Apr 17, 2021 2:31 pm
ckeyes888 offline
Yes. Wind_Dir_Number
No sorry. i don't have the i in caps.
Sat Apr 17, 2021 2:35 pm
Post your current code.
ckeyes888 offline
Yes, I do have another trigger that sets the wind direction number.
Sat Apr 17, 2021 2:37 pm
ckeyes888 offline
wind_number = indigo.variables[1377125246].intValue()   # "Wind_Dir_Number"
   dir = "North"
   dir = "Northeast"
   dir = "East"
   dir = "Southeast"
   dir = "South"
   dir = "Southwest"
   dir = "West"
   dir = "Northwest"
Sat Apr 17, 2021 2:46 pm
My bad, I forgot the correct syntax for getting an integer value from a variable. I don't actually use variables all that much.
Not that you didn't change both instances of wind_dir_last in each if test line.
wind_number = indigo.variables[1332247332].getValue(int)   # "Wind_Dir_Number"
wind_text = indigo.variables[543848099]   # "Wind_Dir_Text"
if wind_number > 338 or wind_number < 22:
   dir = "North"
elif wind_number > 22 and wind_number < 67:
   dir = "Northeast"
elif wind_number > 67 and wind_number < 112:
   dir = "East"
elif wind_number > 112 and wind_number < 157:
   dir = "Southeast"
elif wind_number > 157 and wind_number < 202:
   dir = "South"
elif wind_number > 202 and wind_number < 247:
   dir = "Southwest"
elif wind_number > 247 and wind_number < 292:
   dir = "West"
elif wind_number > 292 and wind_number < 338:
   dir = "Northwest"
Also, the actual error was:
AttributeError: 'Variable' object has no attribute 'intValue'
which is not the same as:
Sat Apr 17, 2021 2:52 pm
ckeyes888 offline
Sorry on the error description. Tried to copy and paste it but no go.
Works great! Many thanks!
Carl
