Connected Drive Plugin for Indigo 2022.1
Thu Sep 29, 2022 7:53 pm
Re: Connected Drive Plugin for Indigo 2022.1
Check GitHub. I think I did a version to fix that error, but it might not have made it to the store yet.
Thu Sep 29, 2022 8:46 pm
ryanbuckner offline
Installed it . Same issue:
Sep 29, 2022 at 10:45:48 PM
   Reloading plugin "Connected Drive 2022.1.1" using API v3.1
   Stopping plugin "Connected Drive 2022.1.1" (pid 61601)
   Stopped plugin "Connected Drive 2022.1.1"
   Starting plugin "Connected Drive 2022.1.1" (pid 61610)
   Started plugin "Connected Drive 2022.1.1"
   Connected Drive Error           Error in plugin execution runConcurrentThread:
  File "plugin.py", line 166, in runConcurrentThread
  File "plugin.py", line 220, in _do_update
  File "plugin.py", line 28, in haversine
type: must be real number, not NoneType
   Connected Drive Error           plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Thu Sep 29, 2022 10:22 pm
I won’t be able to look at it until we get home from this trip, and then deal with the hurricane damage.
Best create an issue in GitHub for it. Include the full debug log and the data dump from the menu commands.
Fri Sep 30, 2022 6:32 am
ryanbuckner offline
Will do, thanks !
Sun Oct 02, 2022 8:27 am
ryanbuckner offline
It looks like my Connected-Drive subscription "expired" after I took it to the dealership this week. I resubscribed so we'll see how long it takes for these issues to be fixed. I no longer have the options to enable Remote GPS Location from my iDrive settings in-car, which may or may not be based on the lapse in subscription.
I'll monitor it for a few hours and check back in here. I closed the GitHub ticket because I don't think the plugin is creating this issue in my case.
Sun Oct 02, 2022 9:17 am
ryanbuckner offline
After about 30 minutes the option to enable Vehicle Tracking appeared back in the iDrive settings under Data Privacy and the plugin started to work again.
Mon Oct 03, 2022 1:55 pm
gillekes offline
I'm using the latest version of the plugin and get this message in the log:
Connected Drive Warning BMW Connected Drive account: get_account error: Client error '400 Bad Request' for url 'https://cocoapi.bmwgroup.com/eadrax-vcs/v1/vehicles?apptimezone=60.0&appDateTime=1664826582081&tireGuardMode=ENABLED'
For more information check: https://httpstatuses.com/400
Login and pass are correct.
Gilles
Wed Oct 05, 2022 11:29 pm
Gilles
Put it in GitHub with debug logs.
