New Plugin - Occupatum - Occupancy/Presence detection
Fri Sep 16, 2022 7:06 am
Re: New Plugin - Occupatum - Occupancy/Presence detection
Did you restart the plugin?
Fri Sep 16, 2022 7:10 am
In any case, if you turn on debug logging and restart, there will be log messages showing which devices are in each Occupatum zone. That should make it easy to see which one is trying to use the missing deviceID.
Wed Sep 21, 2022 6:35 am
durosity offline
A couple of thoughts of nice to haves for the plugin for you to consider:
Having a separate section for devices that can trigger occupancy to on but won't keep the room marked as occupied. An example of this would be a door opening would say the room is now occupied, but leaving the door open wouldn't keep it marked as occupied as it currently does.
Also another really handy option would be to have an action to automatically mark a room as unoccupied, even if the timer count down hasn't hit 0 yet (or indeed maybe a trigger to set the count down timer to 0?) and then allow the plugin to run the unoccupied trigger rather than having to wait it to finish the countdown. An example of this would be when I lock my back door I want it to instantly mark it as unoccupied because I know as soon as that door is locked the garden is empty and the unoccupied trigger should run (eg turning off lights)
Apologies if this is already possible, but I couldn't see a way to to do :)
Wed Sep 21, 2022 6:46 am
There's a cancel timer action that lets you specify the zone state. Isn't that what you want?
The first I think you can do with two zone devices, one that times out after a period, the other uses the first zone as an input.
Wed Sep 21, 2022 8:44 am
durosity offline
Cancel timer does set it as unoccupied, but it doesn't run the unoccupied trigger like it does when it the timer runs down by itself - I thought that was intentional, but perhaps it's a bug?
What's a two zone device? I don't think I've came across that before.
Wed Sep 21, 2022 9:52 am
Hmm. Might be a bug. I’ll need to look at that.
Not a two zone device, but two different zone devices. One just has that one sensor and has a timer to turn off. The second would be your current zone device, modified to use the the first zone device instead of the actual sensor.
Sun Sep 25, 2022 7:06 am
MarcoGT offline
I think I am doing something wrong with the logic behind.
I have set up an occupancy zone which goes on after 10s and off after 0s (immediately);
then I created a trigger
--> when that zone becomes occupied (I think when the "ON" timer expires) and a variable is "false", then send a notification.
I see the zone getting occupied (motion icon gets green), but I never get the notification, and yes, variable is false.
Sun Sep 25, 2022 7:55 am
I’d have to see the trigger definition and the debug log to have an opinion on that.
I’m away for a few weeks so keep that on mind if I don’t reply.
Tue Oct 04, 2022 11:37 am
Londonmark offline
Cancel timer does not seem to be working for me. I am using set zone to off but I get a message saying no timer found and the zone continues counting down. Any thoughts?
Wed Oct 05, 2022 11:28 pm
Create an issue in GitHub. It’s going to be over a week until I can look at it. I’m going to need debug logs.
Thu Jul 13, 2023 9:24 am
MarcoGT offline
I am getting the error
key id “xxx” not found in database
Where can I check where is the problem?
Thu Jul 13, 2023 9:31 am
Not enough info for a detailed answer, that's a very generic error message.
But my guess is you somehow managed to delete or change a device that's included in an Occupatum zone. So you need to check all your Occupatum devices and make sure the sensors they're referencing are all still good.
Tue Jul 18, 2023 1:28 am
MarcoGT offline
With log level set at Debug, I got this
Occupatum Debug Cucina Occupata: watchList updated: {1464433068: [350303466, 611680675, 1720339838], 1132152507: [350303466, 545801923, 309550993], 1012205282: [350303466, 295908663], 1971180444: [350303466, 1512554270], 1227466386: [350303466, 309550993], 1537777849: [350303466, 1102737826, 1720339838], 539442263: [350303466, 1720339838], 1246835527: [350303466, 309550993], 33124796: [350303466], 535468322: [350303466, 1720339838, 1322944162], 94109724: [1720339838]}
Problem is id 94109724.
Is this the ID of an occupancy zone or of a device which goes inside the zone?
Tue Jul 18, 2023 5:46 am
That's a zone ID. It's watching device ID 1720339838
Tue Jul 18, 2023 6:39 am
MarcoGT offline
Yes, then I found it out, I deleted/recreated the zone and it works now :)
