New Plugin - Occupatum - Occupancy/Presence detection
Sat May 28, 2022 1:31 pm
durosity offline
Re: New Plugin - Occupatum - Occupancy/Presence detection
Oh sorry I didn’t see your post regarding it! My system is all disconnected at the moment as I’m doing a big upgrade but as soon as that’s done I’ll take it for a spin!
Sun May 29, 2022 4:34 am
tazswe offline
The link to the version that you posted a couple od days ago dont work.
I tried the 2022.0.2 and are getting the following error.
 Occupatum Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 68, in runConcurrentThread
type: name 'device' is not defined
   Occupatum Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sun May 29, 2022 4:45 am
tazswe offline
something wired about the versions.
Is there a 2022.0.3 version ?
Stopped plugin "Occupatum 2022.0.3"
   Debugging plugin "Occupatum 2022.0.3" (pid 24931)
   Started plugin "Occupatum 2022.0.3"
When i downloaded the version at the plugin store it says that i have downgraded to 2022.0.2
 Downgrading plugin Occupatum to older version 2022.0.2 (previous version moved to trash)
   Loading plugin "Occupatum 2022.0.2" using API v3.0
   Starting plugin "Occupatum 2022.0.2" (pid 24940)
   Started plugin "Occupatum 2022.0.2"
By the way, the version in the pluginstore works like a charm.
Sun May 29, 2022 7:03 am
Updated plugin store to the correct 2022.0.3, with that bug fix included.
Sun May 29, 2022 8:36 am
tazswe offline
Thanks a lot Joe,
The first test with 2022.0.3 has exceeded expectations.
Nice that the long-awaited timer that counts down the remaining time is included.
Tue Jul 12, 2022 10:05 am
tazswe offline
When you cancel the timer in a action group it will only show “cancel timer for zone” but it will not show which zone in the list that show all the actions. It should be nice if it also showed the zone.
I can see that there is the same problem with the timed devices plugin so I’m not sure if it’s a problem in the plugin or in Indigo.
Sent from my iPad with Tapatalk
Tue Jul 12, 2022 10:09 am
Not sure what you mean. Can you post a screenshot?
Tue Jul 12, 2022 10:19 am
tazswe offline
Tue Jul 12, 2022 10:34 am
OK, yeah. That's an Indigo issue, it builds that list. I don't think it shows the associated device for any plugin action.
Tue Aug 23, 2022 9:06 am
durosity offline
I just wanted to say this plugin has really transformed my use of Indigo.. it really has made certain things flow in a much more logical way. I have a few ideas of things that may enhance that but I'll save that for a rainy day.
Grand work lad!
Thu Sep 08, 2022 4:32 am
Londonmark offline
What is the difference between an occupancy zone and an activity zone?
Thu Sep 08, 2022 4:43 am
Occupancy zones are defined by a logical group of occupancy-type sensors. based on the current values of all the group sensors.
Activity zones are based on how active the sensors are, like "5 activations in the span of 10 minutes".
This discussion might help: https://github.com/FlyingDiver/Indigo-O ... m/issues/9
Thu Sep 08, 2022 3:47 pm
Londonmark offline
Ah thanks. Figured there must be an explanation somewhere!
Thu Sep 08, 2022 4:32 pm
Documentation is not my strong point.
Fri Sep 16, 2022 12:48 am
MarcoGT offline
I have every few minutes this error:
Occupatum Error                 Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 56, in deviceUpdated
  File "plugin.py", line 174, in checkSensors
  File "plugin.py", line 174, in <listcomp>
type: key id 1951874049 not found in database
I think because I deleted some devices, right?
But it is hard to find which one :mrgreen:
