Camect Home - IP Camera NVR
Sat Oct 23, 2021 6:02 pm
New plugin officially released.
https://github.com/FlyingDiver/Indigo-Camect
I'll post the plugin store link when it's approved.
For more info on the Camect, see https://camect.com
Sun Oct 24, 2021 12:34 pm
Re: Camect Home - IP Camera NVR
Sun Oct 24, 2021 1:53 pm
norcoscia offline
Just an FYI to all - looks like Camect will be having a CAMECT masterclass on 5 Nov. via facebook zoom.
They also have a 15% off coupon right now (but they do that a lot).
I have this system and love it - everything is local and I record all of my cameras 24x7x365 on a local HD. It also does smart alerts. Works with about any camera out there.
Detail link below
https://facebook.com/events/s/introduct ... 016443686/
https://camect.com/
15% off with FALLSALE
PS. Flying Diver’s plug-in works great and made the Camect system even better for me :-)
_______
Norm
Sun Oct 24, 2021 1:54 pm
FWIW, I use both SecuritySpy running on a Mac mini, and the Camect. SS is used for archival recording of all of my cameras. The Camect is only monitoring a select set of cameras, just for the alerts.
Thu Oct 28, 2021 9:14 am
norcoscia offline
Not sure if you want this here now since you listed the plug-in in the indigo store - anyway noticed this in my log - triggers are working fine but getting the error message "Error device "Camect" state key last_event_time not defined (ignoring update request)" - not sure why?
   Schedule                        Test Cat detected Driveway RGB lamp bulb Color camect (delayed action)
   Z-Wave                          sent "Living Room Bookcase Lamp RGB LED Bulb" set color to 100 98 46, 100 100
   Schedule                        Test Cat detected door RGB lamp bulb Color Camect (delayed action)
   Received INSTEON                "Outside Front Motion Sensor" off (button 1)
   Camect                          Camect: Front Door just saw a cat.
   Camect                          Camect: Hikvision Front Door Camera just saw a cat.
   Trigger                         Test Cat detected door RGB lamp bulb Color Camect
   Z-Wave                          sent "Living Room Bookcase Lamp RGB LED Bulb" on
   Z-Wave                          sent "Living Room Bookcase Lamp RGB LED Bulb" set color to 98 1 3, 0 0
   Z-Wave                          sent "Living Room Bookcase Lamp RGB LED Bulb" set brightness to 100
_______
Norm
Thu Oct 28, 2021 9:15 am
I added that state since the last pre-release. Just edit the device and save it. It'll go away.
Thu Oct 28, 2021 10:08 am
norcoscia offline
Yup, noticed it got added to the SQL logger when I did that, thanks!
_______
Norm
