Masquerade Plugin
Thu Dec 31, 2020 3:59 pm
dduff617 offline
Treat IOLinc as an On/Off sensor device
I have a bunch of door sensors on doors on my house that have simple behavior that they are On when open and Off when closed. I also have two garage doors hooked to IOLincs. I'd like to encapsulate the IOLincs so they behave like the other sensors and ideally be able to include these encapsulated devices in a Device Group.
I'm encouraged by the one-line summary of Masquerade plugin, which states "This plugin allows non-sensor devices (IOLincs, Alarm zones, etc) [to] look like Sensor devices." Sounds pretty close to what I'm after... When I try to create a device using the plugin (example: On/Off Sensor Device), the first thing it asks me is to select a plugin. But my IOLinc devices are "native" Indigo devices (no plugin) - so I'm not sure how to proceed.
Help/advice appreciated.
Thu Dec 31, 2020 4:27 pm
Re: Masquerade Plugin
Well, I can tell you this. The original version of the plugin had support for all the native Indigo device types (Z-Wave, Insteon, etc). Somewhere around version 0.1.0 I took that out. I have no idea why. I can't find anything in this thread or GitHub that documents why. And that was four years ago, so I have no memory of actually doing it. There must have been a reason, but for the life of me I can't remember it.
Getting old sucks.
I'll go back and look at the old code and see what it would take to restore it.
Thu Dec 31, 2020 4:30 pm
dduff617 offline
Thanks for the quick response! Glad to know I wasn't missing something obvious.
It seemed a bit mysterious that there was (as far as i could find) no mention of "IOLinc" anywhere in this thread beyond the first post.
Mon Feb 08, 2021 2:16 pm
Mon Aug 02, 2021 1:26 am
Bildhauer offline
Re: Bug Reports and Feature Requests
Hello setting up an humidity.ui I'm facing the following errors:
Masquerade Error                Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 169, in deviceUpdated
  File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1278, in deviceUpdated
  File "plugin.py", line 64, in deviceStartComm
  File "plugin.py", line 212, in updateDevice
ValueError: invalid literal for float(): 62 %
Thanks in advance for your suppoer.
Best regards
Bildhauer
Mon Aug 02, 2021 1:34 am
That's a Masquerade plugin error. This is the MyQ forum. Moving it.
Mon Aug 02, 2021 1:38 am
You can't use humidity.ui, it's not a valid float number to convert. You need to use just humidity.
Mon Apr 25, 2022 11:48 pm
srkinard offline
Hey Joe...seems like the URL in the About Masquerade v0.3.2 in the plugin and the Get Support link in the plugin store both link to the MyQ forum, not this one.
I was looking up something to see if Masquerade could do it and the links carried me to the MyQ forum.
Just FYI
Ross
Tue Apr 26, 2022 3:00 am
Will fix.
Wed May 11, 2022 5:28 am
Indigo 2022.1 release
Sun Sep 18, 2022 2:22 pm
Londonmark offline
Hi. I have a virtual device called 'Mark home' which gets switched on and off via HomeKit according to whether I am home or not. I want to use it in Occupatum so have set up a Masquerade device to make it show as a motion sensor. But nothing happens...
Am mystified... I've tried leaving the match string empty and tried including it. I manually switch on and off the source device, but the masquerade device does nothing at all.
What am I doing wrong?
Screenshot 2022-09-18 at 21.20.30.png (293.52 KiB) Viewed 2363 times
Sun Sep 18, 2022 2:32 pm
The onOffState of a virtual device is only usable when you have "Supports Status" checked, AND your on/off action groups set the status variable's value appropriately.
Screen Shot 2022-09-18 at 4.32.19 PM.png (231.9 KiB) Viewed 2360 times
Sun Sep 18, 2022 2:37 pm
And then use "True" as the match string, since the state is actually a boolean.
Mon Sep 19, 2022 2:47 am
Londonmark offline
That works - thanks. Was literally the next thing I was going to try but then though better to ask. Will be braver next time...
Thu Aug 10, 2023 6:48 am
durosity offline
Howdy! I'm trying to use Masquerade to publish an on/off relay to Occupatum. I can get the Masquerade plugin to update its state from 0 to 1 depending on the on/off state of the device, but the Occupatum device doesn't follow its changes. Now I think it's because in the device details the On State isn't updating, but I can't find any way to get it to update, nor am I 100% sure that this is what would mark that room as occupied in Occupatum.
Here's the device output:
10 Aug 2023 at 13:26:14
   Script                          address :
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : masqValueSensor
displayStateId : sensorValue
displayStateImageSel : NoImage
displayStateValRaw : 1.0
displayStateValUi : 1.000000
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 231565974
     com.flyingdiver.indigoplugin.masquerade : (dict)
          SupportsOnState : true (bool)
          SupportsSensorValue : true (bool)
          baseDevice : 1209817393 (string)
          deviceClass : plugin (string)
          devicePlugin : nl.rjdekok.indigoplugin.RFXCOM (string)
          masqSensorSubtype : Generic (string)
          masqState : onOffState (string)
          matchString :  (string)
          reverse : false (bool)
lastChanged : 2023-08-10 13:13:50
lastSuccessfulComm : 2023-08-10 13:13:50
model : Value Sensor Device
name : Garage - Occupied Lock Masquerade
onState : False
ownerProps : com.flyingdiver.indigoplugin.masquerade : (dict)
pluginId : com.flyingdiver.indigoplugin.masquerade
protocol : Plugin
remoteDisplay : True
sensorValue : 1.0
states : States : (dict)
     sensorValue : 1.000000 (real)
subModel :
subType :
supportsAllOff : False
supportsOnState : True
supportsSensorValue : True
supportsStatusRequest : False
version : None
Here's the print out of the device itself (although I have tried it with other on/off devices too)
10 Aug 2023 at 13:46:27
   Script                          address : 000000
batteryLevel : None
buttonConfiguredCount : 0
configured : True
description :
deviceTypeId : EMW100Appliance
displayStateId : onOffState
displayStateImageSel : PowerOn
displayStateValRaw : True
displayStateValUi : on
enabled : True
errorState :
     nl.rjdekok.indigoplugin.RFXCOM : (dict)
          address : 000000 (string)
          unit : 1 (string)
ledStates : []
model : EMW100 Appliance
name : Garage - Occupancy Hold
onState : True
ownerProps : nl.rjdekok.indigoplugin.RFXCOM : (dict)
     unit : 1 (string)
pluginId : nl.rjdekok.indigoplugin.RFXCOM
protocol : Plugin
     onOffState : on (on/off bool)
subModel :
subType :
supportsStatusRequest : True
version : None
I've attached a couple of screenshots of the states and config in case they help. Also I've tried it with different device types (such as a z-wave relay) but with the same results. I suspect I've just not got something configured correctly, but I'm drawing a blank on what that is. Any ideas?
device config.png (43.83 KiB) Viewed 1566 times
device state.png (32.39 KiB) Viewed 1566 times
