Masquerade Plugin
Sun Nov 19, 2017 10:27 am
Re: Masquerade Plugin
Now includes new (float) value sensor, with the ability to set the sensor as Temperature (F), Temperature (C), Humidity, or Ambient Light.
https://github.com/FlyingDiver/Indigo-M ... /tag/0.1.2
Sun Nov 19, 2017 3:37 pm
BonfireVA offline
Thanks for the updates Joe. Could you update the ambient light sensor option to use "lux" as the unit of measure and could you also add an option for motion sensors? Attached are screen grabs of how these items are displayed using masquerade and how they are displayed using an Aeonlabs multi sensor.
Thanks again for the updates, this combined with the MQTT plugin is exactly what I needed to start using my own arduino based sensors.
-Eric
masquerade.tiff
masquerade.tiff (29.49 KiB) Viewed 472 times
aeonlabs.tiff
aeonlabs.tiff (28.24 KiB) Viewed 472 times
Sun Nov 19, 2017 3:58 pm
Clarification on the motion sensor type - what's the value range you get from the sensor? And type (float, integer)?
Sun Nov 19, 2017 4:03 pm
BonfireVA offline
Currently I am sending the int "0" for no motion and the int "1" when motion is detected ( I am pretty sure that is what the Aeonlabs sensors do). But technically I can set that to anything as I am just reading in the content of the MQTT topic.
-Eric
Sun Nov 19, 2017 4:18 pm
Try updating to 0.1.3. Note that the motion sensor is a subtype of On/Off sensor, not Value Sensor.
Sun Nov 19, 2017 5:25 pm
BonfireVA offline
Looks great!
This is extremely useful, thank you!
masquerade 1.3.png (55.93 KiB) Viewed 444 times
Mon Feb 26, 2018 1:53 pm
siclark offline
This is amazing, and wish I'd found this sooner. Together with the virtual energy plugin this let's me monitor the energy use of my electric underfloor heating that are controlled with the Heatmiser plugin.
Something else I can take off my to do list once I learn python
Mon Feb 26, 2018 2:05 pm
Glad to hear it. If there's any other device types I need to add, let me know.
Mon Feb 26, 2018 2:40 pm
siclark offline
No. It picked up the plugin and device with no problem. Once I'd worked out the capitalisation the device uses, True vs true, it was all simple.
Thu Mar 01, 2018 3:18 pm
Asconasny offline
Thanks for this plugin.
i have a feature req :)
I have some sensor via the mqttgateway plugin that give me large number of desimals, like 345.00000000.
OCD is killing me with this one :)
What would be great is an option to choose how many desimals that would be shown in the value sensor device.
Thu Mar 01, 2018 3:30 pm
You're using a valueSensor with a sensor type of Generic? Yeah, that one doesn't do any formatting.
Not sure when I'll get to it. Best if you create a ticket for it at https://github.com/FlyingDiver/Indigo-Masquerade/issues . That way I won't forget.
