MyQ Login failures starting at 1:37PM CDT
Thu May 02, 2019 6:12 am
Re: MyQ Login failures starting at 1:37PM CDT
DaveL17 wrote:
FlyingDiver wrote:
How many MyQ devices do you have? And do you already have Indigo devices created for them?
Uno.
The single device is the same one that was working fine (as far as I know) under 7.3.0 until the recent API change.
You didn't answer the second question. If you have one opener, and already have an Indigo device for it, what do you expect to see in that popup? There's no other MyQ device for you to select. Yeah. maybe it should show the current device. But it's still referencing the opener you have.
Thu May 02, 2019 6:18 am
That's what I meant by saying that the "single device is the same one"--it's created and has been for a long time.
That's the bit I was missing. Under the config dialog, I'd expect to see the list of available devices (even if there's only one) and the current opener device listed if it's configured. That clears up my confusion. Thanks!
Feature request: show the configured opener device in the device config dialog. :D
And by the way, thanks as always for the great plugin!
Thu May 02, 2019 6:19 am
Put it in GitHub. :D
Thu May 02, 2019 6:23 am
Done.
Thu May 02, 2019 4:43 pm
mswall offline
Upgrade to 732 - getting python errors. Created new devices for our two chamberlain doors - does not show them in the popup menu list in configure. Seems to accept the login (dialog auto-dismisses), but something seems to be sick still.
File "plugin.py", line 86, in runConcurrentThread
File "plugin.py", line 429, in getDevices
ValueError: invalid literal for int() with base 10: ''
Thu May 02, 2019 4:53 pm
Please turn on debug logging and restart the plugin, then post.
I tested creating devices from scratch, so I'm not sure what's going on there.
Thu May 02, 2019 4:58 pm
mswall offline
joe - sorry jumped the gun. I deleted my old devices (chamberlain door devices) then reloaded 732, logged in, then when I created the new devices, the Chamberlain.com names for my doors were there. seems to be working and the py errors are gone. thanks for your efforts.
Wed Jun 19, 2019 10:39 am
colovin offline
Wasn't working this morning. I checked to make sure I wasn't in VPN, sometimes it doesn't like the VPN server I'm on. Did a reload of the plugin and comes up with this error
Starting MyQ
MyQ Error myqLogin failure, RequestException: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:590)
Are there some changes with the API?
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
Wed Jun 19, 2019 10:55 am
Starting MyQ
What version of MacOS are you running? That looks like the SSL/TLS issue reported for many other web services. Looks like MyQ has upgraded their servers to require the newer version of TLS that requires Mojave or High Sierra.
Wed Jun 19, 2019 11:28 am
colovin offline
I thought I was running the latest version which turns out I was running 7.3.1. So I downloaded and updated to 7.3.2 to no avail.
Stopping plugin MyQ (pid 58666)
MyQ Shutting down MyQ
Stopped plugin MyQ
Upgrading plugin MyQ to newer version 7.3.2 (previous version moved to trash)
Loading plugin "MyQ 7.3.2"
Starting plugin "MyQ 7.3.2" (pid 62114)
Started plugin "MyQ 7.3.2"
MyQ Starting MyQ
My MacOS is Sierra so I'm going to have to update to High Sierra?
Wed Jun 19, 2019 11:33 am
It’s not an Indigo issue. Yes it’s MacOS. You need to upgrade to High Sierra.
Wed Jun 19, 2019 12:00 pm
colovin offline
I hate it when that happens. OS updates tend to break more things and impose more nanny state situations than improvements that I use. Hence I'm generally 2 or 3 OS's behind.
Wed Jun 19, 2019 12:28 pm
This issue has been popping up regularly for the last year or so, for a number of plugins that communicate with web services. It's a security issue with the SSL library in the older versions of MacOS.
Fri Jun 21, 2019 10:53 am
eullman offline
Ugh. Looks like this is the thing that is going to get me to upgrade my server. I almost made it 10 years with a Mac mini (Early 2009). That's pretty cool, actually.
Thanks for the guidance on the SSL handshake failure!
