colovin wrote:The error is back. As luck would have it, I just turned the debugging log off yesterday.
Oct 31, 2018, 7:48:36 AM
Received INSTEON "Garage I/O Fire - Mail" off
Trigger Running
MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[4582762944203516256]</body></html>
Received INSTEON "Garage I/O Fire - Mail" on
colovin wrote:I believe the problem is that MyQ doesn't like some of the IP address my VPN spits out. I dropped out of VPN and it connected with the server. Left the VPN off this AM and garage door opened as it should. It's not all the VPN IP address but some seem to get rejected. When I'm banking I always drop out of VPN to prevent hassles. While I'm using a Phoenix server and when you use a IP address locator it shows up in Phoenix, when I was having banking issues they said the IP was showing out of Russia. Don't know if there's bouncing going on, but that seems to be the source of the JSON Decode Error. I just need to test the IP address when I change to a different address.
