JSON Decode Error
Fri Oct 26, 2018 5:50 pm
colovin offline
Re: JSON Decode Error
Looks like everything is back to how it was before. It's been working fine.
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
Wed Oct 31, 2018 8:59 am
colovin offline
The error is back. As luck would have it, I just turned the debugging log off yesterday.
Oct 31, 2018, 7:48:36 AM
Received INSTEON "Garage I/O Fire - Mail" off
Trigger Running
MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[4582762944203516256]</body></html>
Received INSTEON "Garage I/O Fire - Mail" on
Wed Oct 31, 2018 10:01 am
Trigger Running
Does that number in the message mean anything to you? I bolded it. That's coming from the MyQ server, not the plugin.
You said previously the mobile app works. Is the phone on your local wifi network when you used it? Or on cell network? See this thread:
https://myqcommunity.chamberlain.com/ch ... fi-network
Wed Oct 31, 2018 10:47 am
colovin offline
No the bolded number does not mean anything to me. I'm sort of the opposite of the provided link. Since my trigger did not open the door I opened it with my cell phone which is on the local wifi network. It is a deactivated phone that I use for running so there is no cellular data available.
Wed Oct 31, 2018 10:51 am
Have you tried the other manufacturer options in the plugin config? It's a long shot, but maybe one of the other configs might work. Other than that, I got nothing else for you.
Wed Oct 31, 2018 11:06 am
colovin offline
None of the others worked. They all come up with different numbers.
Oct 31, 2018, 10:03:00 AM
MyQ Debug validatePrefsConfigUi called
MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[4582762944228379901]</body></html>
Oct 31, 2018, 10:03:29 AM
MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[4582762944217361820]</body></html>
MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[4582762944217374732]</body></html>
MyQ Error myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[4582762944228431753]</body></html>
Thu Nov 01, 2018 12:25 pm
colovin offline
I believe the problem is that MyQ doesn't like some of the IP address my VPN spits out. I dropped out of VPN and it connected with the server. Left the VPN off this AM and garage door opened as it should. It's not all the VPN IP address but some seem to get rejected. When I'm banking I always drop out of VPN to prevent hassles. While I'm using a Phoenix server and when you use a IP address locator it shows up in Phoenix, when I was having banking issues they said the IP was showing out of Russia. Don't know if there's bouncing going on, but that seems to be the source of the JSON Decode Error. I just need to test the IP address when I change to a different address.
Thu Nov 01, 2018 12:27 pm
So the problem from that link I posted is the same - your VPN IP is blacklisted on their servers.
Tue Apr 30, 2019 9:31 pm
Vig offline
Getting similar error below. MyQ app on iPhone works fine while connected to the same network with the same public IP seen from outside so it's not blacklisted IP issue. Tried changing password, tested with different brands, no luck.
myqLogin failure, JSON Decode Error: <html><head><title>Request Rejected</title></head><body>Your request has been denied.<br><br>[13495076364912072963]</body></html>
Tue Apr 30, 2019 9:47 pm
dkillmer offline
This error started showing up in my event log today at 11:42 am pacific.
