Stack trace
Posted: Fri Nov 03, 2017 2:25 pm
Got the following several times in a row this afternoon:
Then, about 5 minutes later (and after I bounced the plugin), I got:
Seems likely that they've got some kind of system/network issue, but you might want to at least catch that first error.
- Code: Select all
MyQ Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 94, in runConcurrentThread
File "plugin.py", line 365, in getDevices
File "plugin.py", line 338, in myqLogin
AttributeError: 'Response' object has no attribute 'status_coderl'
- Code: Select all
MyQ Error myqLogin failure, RequestException: ('Connection aborted.', error(54, 'Connection reset by peer'))
