MyQ API changes
Tue Feb 14, 2017 11:36 am
FlyingDiver online
MyQ API changes
MyQ made some changes that broke the plugin. I'm working on fixes now.
Pre-release version for testing: https://github.com/FlyingDiver/Indigo-M ... tag/v7.1.6
Since this is a pre-release, the built-in updater will not work. Please install manually.
For me, this fixes login and get door status, but I am unable to command door changes. But the error code I'm getting is sometimes gateway specific. I need testing of this version to see if it works for other people.
Tue Feb 14, 2017 12:58 pm
roquej offline
Re: MyQ API changes
version 7.1.6 does the same for me: no errors and status works.
JP
Tue Feb 14, 2017 1:02 pm
FlyingDiver online
Re: MyQ API changes
JP
But open/close does not?
Tue Feb 14, 2017 1:05 pm
roquej offline
Re: MyQ API changes
yes, not open nor close
JP
Tue Feb 14, 2017 1:06 pm
FlyingDiver online
Re: MyQ API changes
Can you turn on debug logging and see if you're getting the same 217 error I'm getting?
   MyQ Debug                       changeDevice: Bad return code: Error processing request (217)
Tue Feb 14, 2017 1:10 pm
roquej offline
Re: MyQ API changes
Yes,
JP
Tue Feb 14, 2017 1:38 pm
polycron offline
Re: MyQ API changes
I am also getting the (217) error.
Jeff
Tue Feb 14, 2017 8:26 pm
flakenstein offline
Re: MyQ API changes
Pre-release works for login and status check. No actions work, but send status request did the right thing.
Thu Feb 16, 2017 12:41 pm
blysik offline
Re: MyQ API changes
I don't know if it's accurate, but this project supposedly has a fix for the API changes:
https://github.com/Einstein42/myq-garage/pull/10
Thu Feb 16, 2017 12:44 pm
FlyingDiver online
Re: MyQ API changes
I'm using that code now, and it doesn't work for open/close. Just for login and status. At least in the plugin.
No idea what the issue is.
Thu Feb 16, 2017 4:00 pm
blysik offline
Re: MyQ API changes
Looking at the diff here for another project:
https://github.com/arraylabs/myq/commit ... d1d83dd64f
It looks like some of the urls changed case a bit?
Not sure if it matters.
Thu Feb 16, 2017 4:02 pm
FlyingDiver online
Re: MyQ API changes
As far as I can tell, I'm using the exact same URLs that project is. But it doesn't work the same.
I'm tired of banging my head on this. I'm taking a break from it for a couple days.
Sat Feb 18, 2017 1:49 pm
gskarp offline
Re: MyQ API changes
Works like you say.Status but no command. No errors so far.
Sun Feb 19, 2017 2:04 pm
FlyingDiver online
Re: MyQ API changes
v7.1.7: https://github.com/FlyingDiver/Indigo-M ... tag/v7.1.7
Should fix issues with commands to the doors not working.
Requires that the MyQ devices be recreated.
This is a pre-release, so the plugin updater will not pick it up.
Sun Feb 19, 2017 2:20 pm
Re: MyQ API changes
Opened then closed the plugin prefs dialog (no changes) and got this:
   MyQ Error                       Error in plugin execution UiClosed1:
  File "plugin.py", line 222, in closedPrefsConfigUi
  File "plugin.py", line 409, in getDevices
ValueError: invalid literal for int() with base 10: ''
Same for trying to lock/unlock...
Actually, it's just similar:
   MyQ Error                       Error in plugin execution ExecuteAction:
  File "plugin.py", line 280, in actionControlDevice
  File "plugin.py", line 491, in changeDevice
