MyQ and door sensors?
Sun Dec 04, 2016 12:03 pm
roquej offline
Re: MyQ and door sensors?
Ok - Uninstalled the plugin, and reinstalled it and the chamberlain error went away. Now everything seems to work now!
Thank you!
JP
Sun Dec 04, 2016 12:06 pm
Thank you!
JP
Did you get the latest (7.1.3) that I posted today?
Sun Dec 04, 2016 12:14 pm
Bollar offline
Re: MyQ Plugin discussion
roquej wrote:
Ended up calling Liftmaster support and they did something that got rid of the 2017 error. The plugin is now working ,but getting the following error in the log, when it executes:
Script Error embedded script: 'key name chamberlainAppID not found in database'
embedded script, line 6, at top level
KeyError: 'key name chamberlainAppID not found in database'
I use chamberlainAppID in the scripts I wrote for MyQ. Perhaps you're still calling one of them?
viewtopic.php?p=116771#p116771
Sun Dec 04, 2016 12:16 pm
roquej offline
It could have been. Deleted every script and variables.
Everything works now.
Thank you.
JP
Sun Dec 04, 2016 3:41 pm
v0.0.2 of Masquerade available now: viewtopic.php?f=216&t=17402
Sat Oct 20, 2018 7:10 am
dnomode offline
I selected an I/O-Linc as a sensor device, however the status of the garage door does not change until the plugin updates which is every 5 minutes. Is this normal?
Is there a way I can create a trigger to update the device status when the I/O-Linc Binary Input changes? Or when motion is detected in the garage?
Thanks for the help
Edmond
Sat Oct 20, 2018 7:52 am
Yes, that's normal. The MyQ devices only update based on the poll of the MyQ servers. You're better off using the I/O-Linc state as the door state if you need it to be updated real time.
You could create a trigger that would do a status request for the door, which would force a poll of the MyQ servers. That's under "Device Actions" -> "Universal Controls" -> "Request Full Status Update".
